domasleo’s Old Lumens Contest Entry - Modded Category
12 posts / 0 new
domasleo
domasleo's picture
Last seen: 8 min 31 sec ago
Hello,
I’m domasleo. I am pretty new to the flashlight community. I only purchased my first good flashlight (Emisar D4v2) back in June. Since then I’ve purchased a few more lights and done a bit of experimenting with customizing lights. Until now, I haven’t actually done anything serious though.
I wanted something much more powerful than my D4v2 but I didn’t want to buy something stock. I wasn’t sure if I wanted to build a fully custom light or mod a light.
A couple of months ago I was in an antique shop and I saw this super cool lantern from around 1950.
When I saw it I knew I had to have it. It was a bit expensive at $35, but I didn’t care. After getting this light I decided I wanted to mod it and make it have a really bright high-CRI warm white beam. I wasn’t sure how to do this as I had never modded a light before so I did a lot of research. I ended up deciding to purchase the internal components of an Emisar D18 and use those in this light.
In this post I’ll document the process of modding this light. It’ll go from around 10 lumens output to 10,000. I think a one-thousand-fold increase in brightness is pretty good Big Smile .
Parts List:
The first part is the flashlight host that I pictured above. I’ll need to modify this a lot in order to fit all of the components into it and prevent them from overheating.
Next is the MCPCB with the emitters. I went with 3000k SST-20 emitters for a nice warm white light. I chose this because I wanted it to be similar to the original light’s color temperature.
The next part is the driver board. If the PCB with the emitters is the heart of the flashlight, this is the brain. The driver controls the light, and even though the D18 doesn’t have auxiliary colored emitters, the board has pads to connect aux LEDs to so I may end up adding nice aux LEDs to this light.
The optics and reflector are obviously important parts of any light that you don’t want to have a flood beam. The light I am modding does have a reflector, but the beam was a bit floody so I’m thinking I may use 6 of the optics but leave the other 12 emitters bare so I have a slightly floody beam with a nice soft hotspot in the center. This is subject to change once I build the light and see how the beam looks, but this is the plan for now.
For wiring I’m using 22 AWG copper wire from Intl Outdoor. This wiring can handle up to 200 degrees so I don’t need to worry about it overheating and shorting-out.
I need something to hold the batteries, and for that I’m using these cheap 18650 holders from Amazon.
I could probably modify the switch on the host to work as an e-switch, but since it’s a toggle switch, it would be a bit of a pain to use. I decided to get a nice big 22 mm stainless steel momentary switch. The switch was like $10, but it seems to be really well made so I’m okay with the price. At this point, I’m not sure if the switch is too long and will interfere with the reflector; if it is I’ll have to mod it somehow.
I originally planned to remove the batteries from the light and put them in a charger every time I needed to charge them, but I’ve since decided to try to wire up the light so I can recharge it with a micro USB cable. I disassembled an old power bank I had to remove the circuit board from it. This should work just fine to charge the batteries, since the power bank used 18650s, the same type of batteries the light is going to use. In a pinch I could even use the flashlight as a battery bank to charge my phone.
In order to prevent the emitters and driver board from overheating, I need a heatsink. For the heatsink I decided to use aluminum, because by weight it’s a better conductor than copper, and it is quite inexpensive. I was able to get two 3.25×1.13 inch aluminum rods for about $20 on eBay. This isn’t cheap, but it’s a lot less than copper would have been. I’ll probably only one one of these, but I got an extra just in case I need it. I can always use it for a future project if I don’t use it for this one.
I’m sure as I work on this project I’ll need more parts and materials such as thermal paste. I’ll update this list as I get those things.
The Build:
The first step was to verify that the driver board and the LEDs hadn’t been damaged in shipping. This was pretty easily accomplished. I needed to solder a couple of short wires to the LED PCB to connect a few pads together and then solder the PCB to the driver board. After doing this I was able to hold everything together while being careful not to short anything. I tapped the wires that will connect to the switch together and it came to life!
I was so relieved that I hadn’t damaged anything and it all functioned as expected. Here’s a cool photo my dad snapped for me before I had to turn off the light to prevent it from overheating.
I’m super excited about this build. The light will be extremely bright, I only had it on for a few seconds and it was enough to make me see spots for a few minutes afterwards. I wasn’t even looking at the light, it was just in the corner of my eye.
While I was waiting for more parts to arrive I decided to start to disassemble the host so it would be ready to clean and add the components to. I was able to remove the wooden handle, the switch, and the lens/reflector. You can see in this photo that it’s fairly dirty, but what else can you expect from a light that’s about 70 years old? Big Smile
Next I soldered longer wires to the driver board to connect it to the switch. I hooked the switch in so I could give it a quick test and it worked as expected. This switch is going to be really satisfying to use, its big and nice and clicky.
After this I soldered the wires for the battery holders together to the wires that will connect the batteries to the driver board.
I also cut part of the holders off so the batteries could be removed from them easier. I’m not planning on removing the batteries often since the light will be USB rechargeable, but I’d still like to be able to remove them fairly easily just in case I have a reason to remove them. (I temporarily covered the solder joints with duct tape so they wouldn’t short, I’m going to replace it with electrical tape once I get some.)
Now onto the heatsink. I needed to drill a hole through the center for the wires to go through. The hole in the LED PCB is about 3/8th of an inch but I decided to make the hole through the aluminum 1/4 inch so the wires wouldn’t be pinched at all.
Here’s a couple of photos from after drilling this hole. In the one photo I’m holding a Folomov EDC C1 for size comparison. This is a 10440 light, so it’s pretty small, but it still shows how this is a pretty large piece of aluminum.
Next I needed to drill four small holes in the aluminum for the screws for the PCB to go into. For this I used a 1/16 inch drill bit since the screws I’m using are very small.
Here’s a photo showing the PCB sitting on the heatsink with arrows showing where the screws will go.
This is what I’ve done so far. I’ll update this thread as I make progress!
Edited by: domasleo on 09/20/2020 - 15:36
MRsDNF
MRsDNF's picture
Last seen: 21 hours 6 min ago
Hi and welcome to the comp domasleo.
You have certainly used an unusual host for your mod. Looking good. Beer
domasleo
domasleo's picture
Quote:
Looking good. Beer
Thanks! Any feedback or suggestions? I wanna make this as awesome as possible.
MRsDNF
MRsDNF's picture
Others may have suggestions. I’d suggest to mount the leds to an aluminium or copper base making sure it was touching the housing.
domasleo
domasleo's picture
I’m going to use a large piece of aluminum rod, I’ll try to have it touching the walls of the host. Even if it’s not touching the host’s walls, it’s going to be a much larger heatsink than the one on the D18.
Tally-ho
Tally-ho's picture
Last seen: 1 hour 6 min ago
The aluminum rod is a heatsink but if it doesn’t touch the housing, the heat will be trapped inside the body (except if you have another plan to dissipate it), so MRsDNF suggested that it touches the housing to have heat dissipation from the external of the housing to the ambient air by convection…a bit like flashlights using a drop-in.
domasleo
domasleo's picture
Yeah I’m going to try to have it touching the housing, but I don’t have any metalworking tools so I’ll have to see if I can make it work or not. If I can make it fit perfectly that would be awesome, but if not it won’t be a huge deal.
I know the heat won’t be dissipated very well if it’s not touching the walls, but I’m rarely going to use this light on turbo or even high, it’ll probably used on medium most of the time.
CNCman
CNCman's picture
Last seen: 2 min 36 sec ago
domasleo very nice mod Thumbs Up
And Welcome to BLF Big Smile
CNC & Manual Machinist. Think outside the box too long , cannot find your way back in.
Never give up, Never surrender. Make someone Smile today.
Scallywag
Scallywag's picture
Last seen: 1 day 16 hours ago
Looks good. That disassembled test looks familiar, like I’ve seen it before somewhere…
Looking forward to the build!
Old Lumens Contest 2020 - Hand-made light category
ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20 | Baton S1
Boruit D10 w/ Quadrupel Fet+1/Anduril | EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S15 Ti | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special | Thrunite T10Tv2
Supfire M6 3xXHP50.2, Sofirn C8F, Unfinished: Sofirn SP70, IYP07/Tool AAA hot-rods, Jetbeam E3S
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
MtnDon
MtnDon's picture
Last seen: 50 min 50 sec ago
Cool to see the parts gathering. Thumbs Up
domasleo
domasleo's picture
Made another update to the post with more parts/progress!
Skylight
Skylight's picture
Last seen: 1 day 1 hour ago
Great start for your build, domasleo. Crown
The host looks quite nice for being 70 years old. It has that Emisar blue of the D4 and D4SV2 that everybody desires but is discontinued.
In case you are looking for a D18 aux led board, Lexel sells one: http://budgetlightforum.com/node/68146
