[Review] Wurkkos HD20 aka Sofirn HD20 (dual light, 21700, Type-C, magnet, HiCRI, 5000K)
31 posts / 0 new
Lumeniac
Lumeniac's picture
Last seen: 12 hours 34 min ago
As long as B in BLF stands for budget, i believe that my review of Wurkkos HD20 \ Sofirn HD20 will be of interest here, as this model is a really good update of Sofirn SP40. The last quickly became undoubtful besteller for anyone who wants to buy bright and affordable headlamp from Aliexpress.
Reasons are simple. For only 20 bucks, buyer gets neutral light, built-in charger and a magnet in the tailcap. The next model with same characteristics – Skilhunt H04 – costs at least 40$, and everything that is cheaper than Sofirn SP40 is catastrophically inferior to it in everything. In fact, the only functional drawback of Sofirn SP40 is the lack of full stabilization, and, partly, lack of instant ultralow. IMO.
And for 20 bucks all this can definitely be forgiven. So, a couple of months after the SP40 was released, I began to persistently advice to manufacturer to make a 21700 version of SP40. The list of advantages from such a transition was tangible enough that Sofirn were interested in my proposal and began to develop such a model.
For some obscure reason, they decided to sell the finished model to Wurkkos. However, de facto it is Sofirn.
Many people would like to buy an inexpensive and bright headlamp with a 21700 battery and separate spot + flood LEDs, so it should come as no surprise that the announcement of the Wurkkos HD20 definitely caused a stir here at BLF (read thread). Unlike other brands, (Wurkkos) Sofirn reached out to their end customer to assist with LED selection and UI. I want to thank everyone who participated in it.
Technically, you can still find 21700 headlamps with good brightness at a relatively affordable price. For example the sameFireflies PL47 Gen II. The question is, that Anduril UI is too complicated for any ordinary user. And, unlike Sofirn HD20, there is only one type of light and no built-in charging.
soone after it was released, Sofirn SP40 became bestseller headlamp as for 20$ user got good brightness with convenient color temperature and UI, built in charge and magnet in tailcap.
So, after almost a year of development, the model was released. If there will be any other improvements, I add them to this review. But now this headlamp has acquired a finished look and I am happy to offer you my review of Sofirn HD20, Wurkkos HD20 or whatever name it has. )
YOU CAN BUY Wurkkos HD20 from Sofirn official store at Aliexpress here with O0TT2MZB2O4X, 20% OFF
UPD Manufacturer wrote that kit includes 4800mah battery, not 4000mah as i got in review example.
AMAZON
➽ and 4800 mah Liitokala 21700 battery here
Emitter: 1x Samsung LH351D 5.000K 90CRI + 1x Cree XP-L HD 5.000K 70CRI Working voltage: 2.7V – 4.35V Battery options: 1× 21700 or 1× 18650 Li-ion battery Size: 122mm (length) x 30mm (head diameter) *Weight: *130g / 0.28lb (hd20+ head strap) \ 208g (0.45lb) Flashlight housing: Aerospace grade 6061 aluminum alloy, CNC hard anodizing to military grade III specification, anti-abrasive coating for a durable body, design provides drop protection and improves heat dissipation from LEDs. Waterproof. IP-68 (up to 2m / 6.56ft underwater)
Protection against improper battery installation.
Advanced Temperature Regulation (ATR) technology: ATR automatically dims the brightness level when the driver temperature reaches 60 ° C to prevent overheating Low voltage warning
If you are newbie to flashlights, it is good idea to read my text “how to choose flashlight”. This will give you some information, that makes reading and understaning headlamp review easier.
PACKAGE AND APEARANCE
Quite decent package for a budget brand. It is better than anything you get when you buy something in the Sofirn-Convoy price category. This is not sort of package you throw away right after getting flashlght out of it. You can use it for storing things within.
The kit contains everything you need – the headlamp itself, head strap, clip, O-ring, manual. Battery and charging cable are optional when purchasing the full version.
The head strap is is quite budgetary. No gel stripes inside, no reflective elements on the outside. However, the fabric itself is soft and pleasant. It would be great if the mount was quick-release, like what Olight headlamp have. But this is definitely a completely different price category.
The Wurkkos HD20 is definitely not short one. This is both a good (better heat dissipation) and a bad (after all, you wear HD20 on your head). 12cm in length and 208g of full weight (including headtstrap) will be too much for some users.Though, of course, OK for others. If you are not chasing brightness, and can get without separate LEDs and are ready to sacrifice overall runtime, then it makes sense to buy Sofirn SP40.
Actually, what could you expect from 21700, build in charge port and 2 LEDs? It would be possible to shorten it only by combining SP40 head with 21700 battery tube. Which also makes sense as a separate model, IMO. Something intermediate in price between Sofirn SP40 and Wurkkos HD20.
Even with the T-shaped layout, such 2xLEDs headlamp would be far from being compact and lightweight one, here’s an example of the brightest headlamp in the world – Acebeam H30 . By the way, it is damn good, but more than twice as expensive.
In terms of , appearance, this headlamp looks pretty good. Yes, big brands would make designs more attractive. But as it is, I think the Wurkkos HD20 looks pretty nice ( especially for it`s price, again)
A magnet installed in the tailcap is powerful enough to hold a fully equipped flashlight horizontally.
Thick enough spring inside tailcap.
one more at the head
Wurkkos can be splited into 3 parts
The thread is neat, but it is worth adding some lubricating.
The clip is double-sided. This is where you face great advantage of L-shaped headlamps – such a flashlight can be attached to the strap of a backpack and it will be great to illuminate the path ahead without wearing HD20 on head.
The head is really massive, in fact it is about 1\2 of overall size of headlamp.
There is a deep Type-C charge port on the back. Rubber plug is thick – everything is fine here
The bundled cable is very good.
Wurkkos HD20 also works great as a power bank.
The charging current is 1.9A, then discharge current in power bank* mode is 1.6A*. This is more than enough to quickly charge the phone in case of urgent need.
The kit comes with a 4000mah 21700 battery, the same one that is included in set of Sofirn C8G, that is consider to be best budget long-range flashlight. But I recommend to buy a more capacious 21700 battery from Aliexpress, the same 4800mah (this is the real capacity, little bit less declared 5000mah ) Liitokala costs close to nothing.
The power button is located on the top, it has simple charge indication backlignt : green> 30%, red> 3%, flashing red – time to replace battery.
Two TIR lenses. One for the flood light, another for spot light.
Glass is AR coated. On the bottom, under TIR lenses are Samsung LH351D (flood) and Cree XP-L HD (spot). Quite a reasonable choice. And Samsung LH351D in what you definetely cannot expect from a budget model. Great!
Glass is AR coated
LEDS in all combinations: spot, flood and both.
That’s all, actually. The headlamp looks nice, has no visible jambs. Feels good as hand flashlight from the position of a hand torch. The only question is in size, not everyone will be satisfied with a forehead of this length.
*UI *
Sort of classic Olight-Thrunite interface as a basis along with Lumintop-style access to the moonlight in lock. I believe that to be decent and comfortable UI. So, initially, it was somewhat different, but in the end, with assistance of forum members, it came to what is see below.
It is good, though, of course, with Ramping and mode memory for each LED in Spot+Flood mode (like MID+LOW) it would be better.
How Wurkkos HD20 \ Sofirn HD20 illuminates
The light of Sofirn HD20 will suit anyone – if you need some throw, you get it. If you need it some flood light – here it is.
Light distribution for every taste, color temperature of 5000K (which I like more than 4000K), you can combine spot and flood at different brightness levels like Spot LOW + Flood MID. Everything is really good here. Far from budget model definetely.
ehhh…what about stabilization, everything is exactly the same as Sofirn SP40 has. Quite ugly. Sometimes it acted really strange, like brightness started to grow up in turbo. And, damn, it shows full stabilization spot+flood hight. I cannot explain it. But that is what my luxmeter measured.
Most of BLFers are used to full stabilization. But, guys, lets be honest, what would you expect for such price?
In fact, this is the only thing that i dont like about Wurkkos HD20. It would be cool to see full stabilization here. But, as in the case of Sofirn SP40, it can be forgiven for such a price and other functional advantages. And the eye will not see a drop in brightness of 1% in 3-5 minutes. The eye adapts and visually the brightness seems the same until a certain, quite low level.
Taking into account the fact that you can buy a spare high-capacity 21700 battery from aliexpress for a penny – I think you can close your eyes to this.
If you want full stabilization for this price – take Skilhunt H04. With a shorter rutime and either TIR or reflector version (the version with a TIR curtain caused a lot of criticism).
Nevertheless, i understand that such situation will distract some potential buyers. And, as well as lots of potential buyer will don care as long as the get all the other advantages of this model
To make my review of Sofirn HD20 \ Wurkkos HD20 as informative as possible, I made a damned bunch of pics and gif! that clearly make it clear how all modes in different combinations relate to each other: Spot, Flood and both them. And, of course, comparison with Sofirn SP40.
If we compare which headlamp is better: sofirn SP40 18650 or Sofirn HD20 \ Wurkkos HD20 21700, then the latter is much more interesting in terms of light.
It is much more convenient for close range works, and Wurkkos HD20 have way better throw than one would expect from a headlamp.
I should underline that you can combine Spot and Flood in different modes. There is only one headlamp with such functionalit – YLP Panda 3.0. that is great model, but it is T-shaped and 18650 powered.
As for the throw Wurkkos HD20 successfully covers half a hundred meters, may be even 75m with good detailed light. Since a long throw headlamp is generally nonsense (why – I tell in my FAQ “How to choose flashlight), then such a throw for a headlamp is a wonderful result.
In this regard, wurkkos HD20 \ Sofirn HD20 is clearly superior to sofirn SP40, which has to blur the focus on the side light.
HD20 has separate LED and specific TIR lense for good throw.
There is a LOT of alive videos in all the modes in my utube review of Wurrkkos HD20
OVERALL IMPRESSIONS
In my opinion, this is quite successful attempt to make a good affordable and bright headlamp with split light and 21700 battery. But…it is definetely not perfect one, there are 2 CONs that you should take into account.
a) This headlamp is not compact at all. At all! And I don’t see any way that would allow to combine bright split light, built-in charging and 21700 powered L-shaped bodynand compactness. If you want something shorter – remove some of the variables and get a completely different lantern.
Since I started writing this review of Wurkkos HD20, I periodically used this headlamp. And I dont feel that the difference in size and weight is too serious. Yes, if you carry Sofirn Hd20 on your head all night long, sooner or later you`ll feel excess weight. But if you plan to use it for some hours, then I do not see a problem. And, guys, 70kg man and 100kg man will also feel it differently.
Generally, this is not a problem, but a derivative of the general construction and the advantages of this are obvious, but the disadvantage is subjective. Though, of course, for some people, even this pair will be enough reason to say NO.
b) fairly budgetary and mediocre stabilization. I don’t like this. I would, of course, want this headlamp to shine not so long, but without a drop in brightness. However, this is not so serious for two reasons:
1) Stepdown in most used modes (MID for far and near) will be very smooth and the eye will simply adapt to it, visually the brightness will be the same and the flashlight in these modes will work for an exceptionally long time, especially with a 4800mah battery.
2) A spare battery costs a penny and takes almost no space. If you have one with you, I would generally forget about this.
The Sofirn SP40 performs the same, and that didn’t stop this headlamp from becoming the best budget model. A lot of people use the SP40 and don’t complain at all.
*Again, i dont like it. But that is what we have. Headlamp is budget and here it peforms exactly like budget one. *
Sooo…that`s All!
And then a long list of advantages begins.
The Wurkkos HD20 has really long runtime , thanks to 21700 battery.
Battery included in set has actually 1\3 more capacity than the one from set of Sofirn SP40. And if you buy a cheap Liitokala 21700 4800mah, then the rutime will be a way longer than what you get from any 18650 headlamp (except for models with portable separate 2×18650 battery pack). And these are really expensive headlamps, if we are talking about noarmal brands, and not about sh*t fires zoomies.
Here, by the way, disadvantage of such stabilization turns into an advantage – the brightness slowly steps down , but the headlamp shines longer.
The L-shape allows this bright headlamp to be used as a hand-held flashlight with a great deal of versatility and comfort. And thanks to the clip, you can use it as a walk around or camping light by attaching a flashlight to your chest pocket or backpack strap, thereby relieving your head.
Wurkkos HD20 has split light. This is far from a unique solution for headlamps in general, but I dont remember seing that in the L-shaped format. All such solutions were in the classic T-shaped case. And the diffused dipped beam there was just a pleasant addition, limited both in maximum brightness and in the number of available modes. Not to mention the ability to fully combine both types of light. The only exception I know of is Panda from Bright Beam.
Right there you get both types of light with the possibility of combining them for any situations.
This is actually a* bright headlamp*. There are brighter models we know. The question is that these models (from Klarus and Olight, for example) are almost twice as expensive, while the usual compact dimensions reduce the turbo to a rather short , in comparison with the Wurkkos HD20.
Good color temperature. 5000K, and even in *HiCRI *for low beam. Any of the major brands except Acebeam in such a situation gave you a standard cold light to raise the brightness in the specification.
This is a headlamp with a magnet. An extremely convenient solution for the same garage. Yeah, dont carry cards in pocket with HD20.
The Wurkkos HD20 has perhaps* the fastest built-in charger* ever seen on a headlamp. 2A this is really very good. And it also* works in power bank mode*, in a situation of emergency you can charge your phone.
Flexible and convenient UI. Anduril will be more flexible, but for an ordinary user, such an variety of settings will be rather a disadvantage. Wrong extra click can lead into the jungle of settings and cause only swearing.
Price. All these wonderful features would not be so pleasant if the cost of the flashlight was at the level of Fenix ??\ Olight. But it is way less.
that is all.
With full stabilization Wurkkos HD20 could be reall? close to perfect (if size and weight are good for you). With the one it has now it is just good budget headlamp with combination of features that no other model has.
Really good for regular user, perhap OK for experienced one, if you can live with absence of full stabilization .
That is what i feel about this model now.
Let`s discuss, guys.
Edited by: Lumeniac on 10/21/2020 - 12:14
mbp
Last seen: 4 hours 59 min ago
I REALLY like the idea of this headlamp, but XP-L HD is not a good choice for a throw LED. XP-L HI should be used, or SST-20. Also, perhaps the flood LED is a bit underdriven?
My DREAM headlamp would be dual LED, LH351D 4000k 90CRI for flood, and SST-20 4000k 95CRI behind a very tight TIR for throw. So this headlamp is not far off from that, and Sofirn has both of these LEDs on hand…
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 1 hour 11 min ago
The English and German manual can be downloaded here from my sharepoint.
I will soon create a separate promo sales thread for this flashlight. Stock will be en route to Amazon warehouses as of tomorrow.
Caleb
Caleb's picture
Last seen: 3 hours 19 min ago
20 bucks?? Using your link the price is OVER $40.
AEDe
AEDe's picture
Last seen: 13 hours 28 min ago
Everything is strange in this “headlamp” exept UI )Don’t think it would be popular. 45$ is prise for conwoy+H03/H04.
Wurkkos
Wurkkos's picture
Last seen: 4 days 23 hours ago
thanks for the review, nice photos Thumbs Up
Lumeniac
Lumeniac's picture
i was talking about Sofirn SP40 there,  20 bucks definetely relates to it.
Lumeniac
Lumeniac's picture
AEDe wrote:
Everything
suppose, you mean size?  yeah, that is far from being compact model.  and i underlined it several time.
i met some "ah, Acebeam H30 is damn big". but people who relly own it  wrote that it feels ok.  (as far as i remember, you also had one)
so is the size here. it is big, but some people will ok with it.  some people will say "nonono!"  i personally know man, who refuse to use even 18650, that is too big for him, though he is big guy. Big guy, who fell in love with Nitecore NU25.
for me personally, poor stabilization is worse that size.
H04 is alternative, of course, but it lacks some features that HD20 has.
everything is damn subjective here.
MoreLumens
MoreLumens's picture
Last seen: 5 hours 38 min ago
Thanks for good review.
I order one for sure, but I just might do a led swap for throw, but flood might be ok. I got two different LH351D 5000k’s and other is beautiful, but other not really. Could use a throwish headlamp with good flood too. And price is really nice, under 35€ for a 21700 headlamp is a bargain.
mbp
I do not mind the unregulated driver. Regulated would be better, but you cannot have everything in this world… will not be hard to keep the battery topped up. As for size/weight, it is a 21700 right angle light w/USB-C charging and dual LEDs. There is no way to make it as light as a Skilhunt H03 or whatever, once again you cannot have everything in this world!
The bigger problem for me is the LED choice… XP-L HI would make this a definite buy. If/when they are available on Amazon, I will probably still get one, and consider an LED swap.
jp9mm
Last seen: 10 min 38 sec ago
‘you can combine spot and flood at different brightness levels like Spot LOW + Flood MID
Seems a little awkward with no mode memory but do you need to cycle through individual LED set level and then cycle back to both leds on for that to work and it remembers what you set?
Lux-Perpetua
MoreLumens wrote:
[...] And price is really nice, under 35€ for a 21700 headlamp is a bargain.
I agree. With the upcoming BLF promo discount the light will be available for a decent price.
I don't mean to overstate the specs here but apart from the light you also get:
  • a decent 21700 4.000mAh battery
  • a useful headstrap
  • a magnetic tailcap
  • USB-C (type C-C) charging
  • reverse charging ("powerbank" feature)
  • USB-C cable
Therefore, HD20 will be great for people who like to start right away with everything included in the box. This light will also work nicely for those who do not want to deal with battery chargers. Certainly, there will always be things to make even better but let's be fair about prices and included features. In my humble opinion you get a lot for the price. Comparing HD20's driver with something like Acebeam H30 is somehow like comparing apples and pears.
Provided that HD20 will be a successful light in terms of sales, I am sure we can continue on improving it. Yes, XP-L HI is an option that deserves a closer look, maybe even Osram's Boost HX 2mm². Weight and size may be an issue to some people, that's alright. But still this light could be useful as a toollamp on one's belt, in one's pocket or attached to a jacket. Personally, I prefer to wear my headlamps in front of my throat to walk "handsfree" in darkness. I will probably not notice any additional weight wearing this headlamp there.
Anyway, I really appreciate all your input here, regardless if it's positive or negative feedback. If you have any suggestions how to improve the UI, I will be more than happy to collect them for further improvement.
Большое спасибо Lumeniac!
AEDe
AEDe's picture
I mean size, weight, battery & construction, leds, driver.
Of course it is subjective and someone likes huge headlamps with cool leds without stabilisation.
BLF-L
BLF-L's picture
Last seen: 12 hours 46 min ago
Thanks so much Lumeniac , for your very detailed review.
I wanted to purchase SP40 but this HD20 seems more interesting and versatile with dual LED and 21700 batt.
MoreLumens
Is it possible to charge and use the light at the same time? What about could I strap this into my backpack for floody walking light AND at the same time charge my phone from it?
TeeJayEDC
Last seen: 1 week 3 days ago
This looks really good with the tan color. Highly anticipated and competitive price if really available at $20. Very nice to see Wurkkos/Sofirn update to support USB-C to C charging and include a braided cable. Just pick up another FC11 4000k hope it will also support it.
rdhood
Last seen: 1 hour 1 min ago
At $50, I’m not all that interested. At $30, I’m buying without hesitation.
Wurkkos
Wurkkos's picture
there will have a groupbuy price here as soon as stock ready on Amazon warehouse
sochi111
sochi111's picture
Last seen: 1 week 2 days ago
Awesom review Lumeniac,
This took you probably a whole week of work.
MoreLumens
Is that going to be only from Amazon? No AE which has good – 20% from HD20 right now, so that might be my cheapest option?
Also any pics of AliExpress army green HD20 from Sofirn store? When there is more coming they sold out fast.
Sillen
Sillen's picture
Last seen: 1 hour 6 min ago
Any thoughts on Amazon AU?
rdhood
The discount code in the OP’s post (20%) is not working. If it did, I’d purchase
Lux-Perpetua
rdhood wrote:
The discount code in the OP's post (20%) is not working. If it did, I'd purchase
Try this one: BOQ3QL64B74X
Lumeniac
Lumeniac's picture
yeah, BOQ3QL64B74X works
Lumeniac
Lumeniac's picture
bitteschön
rdhood
When I try to use either code, it says “you used the code” but no discount is applied. At $50, this is not for me. If 20%+ off code comes that actually works, I’ll use it
Lumeniac
Lumeniac's picture
may be you simply register new account? this should definetely work
Lumeniac
Lumeniac's picture
got new code, works both for with\without battery kit
Grayman007
Last seen: 11 hours 37 min ago
Anyone know if the green version and battery bundle will be back at Aliexpress?
Lumeniac
Lumeniac's picture
thanx
overall...something like this. i did about 2 dozens of runtime tests alone.
one of most time taking review ever.
but, i hope i explained any detail that reader would be interested in
Grayman007
I will buy this flashlight based on your honest review.
Thank you.
