Electrical Leakage On The Magnetic Charging Port - Is It Dangerous
10 posts / 0 new
vietnamreviews
Last seen: 21 hours 9 min ago
A friend asked me about the leakage on the SKILHUNT H04F RC magnet charging port. I sent a letter to SKILHUNT and they said: H04 RC charging port have short circuit protected function. So you have SKILHUNT H04F RC please rest assured to use. There is one thing you should pay attention not to share SKILHUNT H04F RC and the key to minimize risk as I analyze in the clip.
SKILHUNT H04F RC is my great headlamp. It is very light in weight and customizable for a wide variety of usage scenarios such as high or low beam.
What’s your opinion ?
SammysHP
SammysHP's picture
Last seen: 29 min 28 sec ago
Olight has also the full cell voltage on the contacts. Early models had no protection, on newer models the current is limited to a few mA.
Sunnysunsun
Sunnysunsun's picture
Last seen: 33 min 54 sec ago
If you’re really curious, try putting some steel or a wire to bridge it (temporarily). Be very care to push it away after a short time so you don’t cause damage? Note: idk if this might damage something
kennybobby
kennybobby's picture
Last seen: 8 sec ago
Good review video. i’m still a little alarmed to see exposed voltage on the port, maybe it needs a magnetic cover made of plastic to prevent a key or other metal from accidentally touching across the electrodes.
i wouldn’t want you to damage your light, but a test of short circuit protection should be made to verify that it works. i’m afraid it may not actually work and would cause damage. The design is not good in that it puts voltage on the exposed port and is a risk of damage or spark.
What is the schematic of the circuit that provides the short circuit protection? How much current can flow before the protection kicks in? These would be important to understand before it can be declared “safe”.
Favorite Song = "Flashlight" (BLF of course, with a righteous bass)
https://youtu.be/gCTGMIXaD64
Exercise and Training:
My typical training routine: https://youtu.be/_aVASp9raMk
Morning Workout: https://youtu.be/ZEA_3yXG570
Remember Don't Do Drugs...
without me: https://youtu.be/oVKtxHTcnho
vietnamreviews
I agree with you. I am counting on Skilhunt’s statement. But maybe we should still have an independent test
thefreeman
Last seen: 38 min 20 sec ago
I tested with a bunch of 0.5Ω resistances, down to 1Ω current rises up to 2.8A (bat=3.9V) and then at 0.5Ω no current anymore, so there is a protection.
Edit : with a real short it does spark, but still no current afterwards.
kennybobby
Merci, Thank you for doing the test. What is the power rating of your resistors?
Approx 8W for the 1Ω test, could the last 0.5Ω resistor have let go under 30W load?
thefreeman
50W, but like I said in the edit, I shorted the contacts with a wire in the end, no current (measured with current clamp)
kennybobby
Très bien!
rdhood
Last seen: 1 hour 9 min ago
A deliberate short circuit bench test is better than an accidental short circuit test in your pocket
