WUBEN AMZ US Prime Deals- Grab the Perfect Time to Reward Yourself a High- end Torch
Its Prime Day: 28:30. Only 28 hours left of 2020 Prime Day. Grab the last chance to take your perfect WUBEN light home at the lowest cost.
  1. WUBEN A21 4200LM Torch, prime to save $24.96 plus clip coupon 10% clip coupon, Prime Day price 89.85, you save $35
    https://www.amazon.com/WUBEN-Rechargeable-Flashlight-Include-4800mAh/dp/B089YNHC45
  2. Amazon Prime Day Deal: $85.87 after 5% clip coupon (was $112.99)
    T70 4200 lumen flashlight
  3. Amazon Prime Day Deal: $37.09 after 30% clip coupon (was $52.99)
    Wuben TO46R NICHIA 219C High CRI LED for Photography - 1000 Lumens Neutral White Dual Side Switches Tactical Torch for Outdoor (18650 Included)
The TO46R with the Nichia’s in it is a great light. I have one and love it. Good price too. Think I paid $50 for mine a while back.
Its Prime Day: 28:10
4. WUBEN Brightest Rechargeable Flashlight 12000 High Lumens Super Powerful Torch with 3PCS CREE XHP70.2 LEDs and 10200 mAh Battery Pack for Flashaholics - A9 Light of Dual UI Ramping and Regular Mode
$50 off code: 2HFSLVZW, plus 5% off Prime Day special coupon, after discount price $189.99 (was $249.99)
https://www.amazon.com/WUBEN-Brightest-Rechargeable-Flashlight-Flashaholics/dp/B089WCDWZJ/
5. WUBEN L60 Zoomable LED Rechargeable Flashlight, Bright Compact Handhold Torch - IP68 Waterproof Cree Light for Daily and Outdoor Use (18650 Battery Include)
Prime deals: $27.19 (was $33.99)
https://www.amazon.com/WUBEN-L60-Zoomable-Rechargeable-Flashlight/dp/B087T5FSD8
6. WUBEN Handheld LED AA Flashlight E18, Solid IP68 Waterproof Cree Small EDC Light
Prime deal: $5.38 off plus $5 clip coupon, price $16.5 (was $26.88), only 20pcs left in stock
https://www.amazon.com/WUBEN-Handheld-Flashlight-E18-Waterproof/dp/B087TXCN51
7. Keychain flashligh in deals too:
https://www.amazon.com/WUBEN-Rechargeable-Flashlight-Battery-Keychain/dp/B089KJ8M72
Thanks to support WUBEN. Kindly share your experience of WUBEN TO46R on Amazon to let other flashaholic knows the pro and cons of this light.
If you like flashlight at: https://www.amazon.com/s?marketplaceID=ATVPDKIKX0DER&me=A2JFZQPTWASL74&ref=glow_cls&refresh=1, pls let me know.
I will create you a code to make up extra TO46R cost :)
Again, I'm really appreciate your guys support. WUBEN will keep moving to develop more dedicated torch
Oh, I missed this… :open_mouth:
Is the coupon better ordering from the marketplace? I just ordered a TO46R from the link at the first post up top.
I like Wubens. I have older TO46R (XP-G3s), probably 5-6 E-series keychain lights, i332 vulture, L50, a few E01s, etc.
Nichias would be nicer in the TO46R, so… :laughing:
Haha, no big deal. Codes will be available for the products in this link: https://amzn.to/2XvVTRb
While we are on the subject of TO46R- I have 3 of these and they all have different emitters. Mountain Electronics sells 20mm triple emitter boards in various LED flavors making an emitter swap incredibly easy.
I have these three:
MTN3XP-219C-D240
3XP-XPL-HI-U4-3K
MTN3XP-LH351D-4K
If you want to try different emitters but don’t feel confident, or have the tools, to do a complicated emitter swap, this light is a great choice. All you need is a basic soldering iron to detach and reattach the wires at the LED board.
1- Remove the tailcap and remove the battery.
2- Remove the bezel.
3- Gently blow into the open battery tube from the tail end and the air pressure will pop out the lens assembly.
4- Unsolder the wires at the LED board.
5- Remove the LED board and set the replacement in it’s place.
6- Solder the wires back onto the replacement.
7- Reassemble the lens, o-ring, & bezel.
That’s it. About as easy as it gets.
I installed a triple noctigon board with Nichias in my old TO46 as well. Great flashlight
