Blf lt1 full charge
6 posts / 0 new
leftfordead
Last seen: 1 week 2 days ago
Blf lt1 full charge
Hi I’m sorry if this is in the wrong section or if this has already been discussed . I was reading through the instructions on my lantern , and I noticed it says 4.2v is fully charged. When I fully charge the 18650s (sofirm) my the lt1 only blinks out 4.1v but when I put the same batteries in the q8 it blinks out 4.2 . Can anyone maybe enlighten me with there expertise? Cheers guys
Edited by: leftfordead on 10/18/2020 - 11:27
jeff51
jeff51's picture
Last seen: 16 hours 17 min ago
There seems to be some variance in the charge cut off. Mine never reaches 4.2.
Mine stopped at 4.16v and I manage to catch it at the exact moment it cut off.
And I quite happy for that. Easier on the batteries.
You might pull a freshly charge cell and see what what it reads.
Also there is probably some variance in the circuit reading the voltage.
Unless you measure something too low, I suspect you are just seeing normal behavior.
You will get more replies if you put this in the LED Lantern forum.
All the Best,
Jeff
SerenityNow
Last seen: 12 hours 30 min ago
From what I’ve gathered, the Anduril voltage indicator is not the most accurate way to judge. I always see variance but it’s not a huge deal.
leftfordead
i dont suppose u could help me . when i go in moon mode the lantern is already on a very dim setting . can that be adjusted as i thought the idea of moon mode is it slowly dims down and eventually turns off
SammysHP
SammysHP's picture
Last seen: 3 min 32 sec ago
That would be sunset mode. It starts at a higher level and slowly dims down until it reaches “moon mode” and then turns off.
Boaz
Boaz's picture
Last seen: 33 min 58 sec ago
Batteries fresh off of a charge fall almost immediately so the true reading would be after a reasonable period of time . Expect that a day later reading will be more accurate .
Moon mode is simply a low/low usually a sub 1 lumen  mode .Firefly is maybe even a tenth of that ..just barely on
