Convoy S2+: the selected group is reset after battery disconnect
32 posts / 0 new
aeroden
Last seen: 3 hours 19 min ago
Good day,
I’m a fresh owner of Convoy S2+ – the one that comes with the 12-group firmware.
I’m able to change selected group to #2 (0.1, 1, 35, 100) and switched memory mode off.
It works fine… Until I replace the battery. Then it resets back to the default – group #1, memory on.
Can anyone confirm if this is a bug or by design? I.e. does its driver has a permanent flash memory to store the config? (The manual says leaving the driver in config mode will wear its memory, so I assume there is some kind of persistent memory, but I’d like to be sure).
Thank you.
aeroden
Bump.
Anyone please?
stephenk
stephenk's picture
Last seen: 11 min ago
Someone else reported a similar problem in another thread. Maybe contact Simon?
SammysHP
SammysHP's picture
Last seen: 7 hours 47 min ago
The switch already disconnects the battery from the driver. Removing the battery should make no difference. Is the light switched off when you change the battery?
aeroden
Just want to make sure first that I don’t bark the wrong tree.
Good observation, indeed shouldn’t make a difference.
Bingo – I usually unscrew the cap with the light being on. But now I tried several times with the light off, and it does remember settings!
So again – cap off with the light on and the settings are reset. Is that a bug?
SammysHP
SammysHP's picture
No, it’s not a bug. Turning the tailcap or head (depending on the anodization) causes many short interruptions which are interpreted as button presses. Same as when you tap the button all the time.
aeroden
Righto. All good then! Thanks for elaborating.
g_damian
g_damian's picture
Last seen: 6 hours 24 min ago
I did some testing.
When memory is ON:
- twisting tail switches mode
- button tap switches mode.
When memory is OFF:
- twisting tail resets flashlight (mode group 1, memory on)
Questions:
- how is it possible?
- can this feature be programmed in different way? E.g button tap switches mode, twisting tail goes to turbo.
Unloco
Last seen: 8 hours 22 min ago
Lighted switch?
g_damian
g_damian's picture
Unloco wrote:
Lighted switch?
Nope. Stock S21B with 12 groups 6A driver.
yasenf
Last seen: 2 days 8 hours ago
Did the same and mine S21B 6A 12 groups did the reset, but only after I unscrewed the cap fully. Only half turn remembers the settings. Interesting detail – when resetting it also defaults to memory on.
aeroden
Was the light on or off when you were unscrewing it?
yasenf
on
aeroden
Yeap, it’s the same for me – unscrew the cap with the light on and settings are reset. Unscrew with the light OFF – all good.
Blggg
Last seen: 1 day 2 hours ago
I have about 6 of these 5A drivers and one 6A driver and they all have this problem. I have talked to Simon about it and if I remember correctly he said he would fix it. I ordered the last 2-3 5A drivers about 3 weeks ago, which was after when I talked to him, and the drivers still have this defect.
I think the drivers are defective and have been discussed on Convoy dedicated thread but AFAIK it hasn’t been fixed. Hadn’t they been cheap and efficient, I wouldn’t have bought them.
aeroden
Sounds encouraging! Anyhow, the current workaround is robust and not too fiddly. I agree that it’s something I can personally live with. Thanks everyone for their input.
Blggg
My workaround (if the light resets itself too often, which happens from time to time) is just to stick to the 1st mode group and turn off the memory mode. When I have gone past the mode I wanted, I would just turn off the light, turn on and advance to the mode I wanted.
g_damian
g_damian's picture
I’m wondering how it is possible that somehow driver can differentiate between button tap and tail twist. Can it be used for different function like shortcut to turbo on tail twist?
SammysHP
SammysHP's picture
There is just power on and off. It is a mechanical switch, not an e-switch. Turning the tailcap just creates noise that is interpreted as multiple button presses.
nocturne
nocturne's picture
Last seen: 1 hour 45 min ago
I have been waiting for my first S2+ for some time. Last track shows it got to Greenwood IN. But now I learn this model is haunted so close to Halloween, I’m not sure I want it anymore. Imagine trying to escape from a haunt while carrying the thing that is haunted! Can’t be done. Just how is anyone supposed to avoid twisting off the head or tail cap while the light is on?! I don’t know how others use flashlights, but when I carry one, I am constantly and usually unconsciously disassembling all my flashlights while they’re running. How else are they to be used? It is hard to believe such an intolerable defect could have made it to production. This is terrible news.
SammysHP
SammysHP's picture
Sorry, but this is not a defect, it’s physics. Just cut the power cleanly without bouncing when you unscrew the cap and everything will be fine. Look at the signal with a scope, it will show horrible noise.
Do you turn off your computer by pulling the plug as well?
SIGShooter
SIGShooter's picture
Last seen: 1 hour 17 min ago
I’m curious as to why one would normally disassemble a flashlight when it’s on, or to turn it off that way rather than using the switch. I’m sure there’s a good reason for doing so but I’m not clear as to what it is.
Thanks
9mm/40cal/45cal bullets and large/small pistol primers available for sale in San Francisco Bay area
nocturne
nocturne's picture
Thanks
That was sort of my point, but I guess my satire didn’t come across as well as intended.
Funtastic
Funtastic's picture
Last seen: 1 hour 2 min ago
Well this explains why my 12 group torches reset to the first mode with a pressure switch. Damn it’s annoying.
Now I know to instruct customers to have mode memory on when using the pressure switch, very helpful
Just tested my new Convoy C8+ stock and it looks like it’s been fixed.
Observation:
Old revision with the bug = 10 taps to enter config
New revision = 20 taps
EDIT: Bug hasn’t been fixed Sad it only happens when screwing the tail on though. If you unscrew it, click the switch off and then screw it back on, it doesn’t reset.
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
Funtastic
Funtastic's picture
All that’s required is turning the switch off before untwisting the tail, it’s not normal to take it apart while its on.
Jack Kellar
Jack Kellar's picture
Last seen: 13 hours 52 min ago
The S2+ is an excellent torch to have when you need to escape a haunted mansion or spooky graveyard or maize maze or pumpkin patch. Just make sure to not unscrew any parts of it while it’s on! Big Smile
NeutralFan
NeutralFan's picture
Last seen: 4 days 2 hours ago
Observation:
20 taps seems like a much better design. Getting into configuration mode with just 10 taps is too easy and can cause accidental activation from my experience.
I’d rather use my flashlight around the house than turn on the lights.
Blggg
I didn’t untwist or twist the tail. I just used it as it is. It just reset itself randomly.
darosk
Last seen: 1 hour 56 min ago
That’s interesting, I thought that the self-reset thing was just a quirk of such an affordable light – turns out I got one of the defective ones as well. It annoyed me at first, but the light is such a good deal I just chose to overlook the niggle I guess.
Funtastic
Funtastic's picture
Did you make sure everything is tight, both head and tail, retaining rings, cleaned all non anodized parts? That’s the only way to know that it wasn’t a connection issue while memory mode was disabled
aeroden
Mine also has reset today while I was holding it in my pocket. 3 more are on order and then I’ll gather some stats and revert here.
