XM-L Available in November. 13 dollars. 3Amp drive current!
9 posts / 0 new
fran82
Last seen: 1 week 5 days ago
http://www.forolinternas.com/viewtopic.php?f=22&t=384&p=9363#p9363
Looks like in November this monster is available.
Up to 3A drive current.
Price starts at 13 dollars (cheaper than I espected)
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
Don
Don's picture
Last seen: 2 years 7 months ago
I want!
I want a lot!!!!
But at 25mm2 die? That's enormous - probably far too big for flashlight use with reflectors of less than half a metre in diameter.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
fran82
No no, is a bit smaller than P7. So is a flooder, not a thrower
More info here http://www.candlepowerforums.com/vb/showthread.php?t=270517&highlight=cree
SPAMBOT
SPAMBOT's picture
Last seen: 1 year 11 months ago
There has been a lot of confusion surrounding the XML but I think that the consensus is: 4mm2 die, 5*5mm package foot print. XML1000-ish lumen @ 3A VS SST-50 1150-ish lumen @ 5A.
Now with 100% all natural asbestos!
Don
Don's picture
This means it ought to give very good results from existing P7 drivers and reflectors - hopefully without the heat. the efficiency at 3A won't be anywhere near the efficiency at 350mA though.
It sounds like it might make an excellent close up light (You want a very floody beam for that) that would run on an AAA for ages. An emitter swap in a Fenix E01 would be interesting with one of these. Many hours runtime and about 8x the output of an E01. Hopefully Fenix will do something like the E05 with incredible runtime unlike the present model.
old4570
Last seen: 3 days 12 hours ago
125Deg View angle [ XM-L ]
125Deg View angle [ XP-G ]
100Deg View angle [ XR-E ]
I was hoping for a tighter XR-E angle on the emitter lens , so this will be interesting , never the less ..  But the base is way to large ...  To fit smaller CR123A EDC lights like the Akoray , we need this emitter on a 14mm base .
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
XRAYBoY
XRAYBoY's picture
Some FL users maintain contact with cutter on the subject. The response of cutter was:
"Still waiting for 14mm Round PCB design to be finished, approx 1-2 weeks"
You can also view some exclusive field pics of XM-L led here.
ForoLinternas.com
brted
brted's picture
Last seen: 5 days 1 hour ago
Gracias for the update and pics, X. I've been waiting since April, I guess I can wait another few weeks.
xP.1337
Last seen: 2 years 8 months ago
SWEET! 14mm already! noice!
that makes me excited.  XM-L Aurora V6 here i come!
