CUSTOMS ACT 1901 - SECT 203B
Seizure without warrant of special forfeited goods, or of evidential material relating to special forfeited goods, at a Customs place
(1) This section applies in 2 circumstances, namely:
(a) in a circumstance where an authorised person suspects on reasonable grounds that there are special forfeited goods:
(i) at, or in a container (other than a designated container in the immediate physical possession of a person to whom subparagraph (b)(i) applies) at, a Customs place; or
(ii) in, on, or in a container (other than a designated container in the immediate physical possession of a person to whom subparagraph (b)(i) applies) on, a conveyance at a Customs place; or
(b) in a circumstance where a person:
(i) is at a Customs place that is also a designated place; and
(ii) has a designated container, or has goods reasonably suspected by an authorised person to be special forfeited goods, in his or her immediate physical possession; but
(iii) is not carrying that container or those goods on his or her body.
Note 1: Container and designated container have special definitions for the purposes only of this Division.
Note 2: The baggage of a passenger entering or leaving Australia or of the captain or crew of a vessel or aircraft so entering or leaving is not a designated container.
Note 3: To determine the question whether a person is carrying a designated container, or goods reasonably suspected of being special forfeited goods, on his or her body, see subsection 4(19).
(2) In the circumstance referred to in paragraph (1)(a), the authorised person may, without warrant:
(a) search the Customs place, or the container at that place, for special forfeited goods; or
(b) stop and detain at the Customs place the conveyance and search it and any container on it for special forfeited goods;
as the case requires, and seize any goods that the authorised person reasonably suspects are special forfeited goods if the authorised person finds them there.
whatver that BS means. Its the axis lock that is the issue. It can be interpreted as an assisted opening knife. Not sure of the permit but if I fail to get one they will take me to court and may seek costs. Its designed so you don't bother.
The importation of these goods is prohibited by Reg 4(1) sched 2, item 19 of the Customs (prohibited Imports) regulations unless permission in writing to import goods has been granted.
I can't even find that lego on it when searching the database
