Checking Bats
15 posts / 0 new
cheaplite
Last seen: 6 years 7 months ago
Checking Bats
Got some new 18650 and wanted to check internal res. Got a dig. multi. now what?
Don
Don's picture
Last seen: 2 years 9 months ago
Checking internal resistance is hard.
Hopefully one of the folks who know this stuff will chime in.
sixty545 - hope you see this!
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
viffer750
Last seen: 2 years 11 months ago
not a hard thing, but this is a DC measurment, not AC as factories usually give it
first you have to measure the unloaded cell voltage
1
after that you have to load it with a resistor, and paralell it, you have to measure the loaded cell voltage,
usually,  I use a 3-5ohm resistor (a 5W because of the heating up)
2
and here is the formula
3
r -> internal resistance
R -> load resistance
Uo -> unloaded cell voltage
Uk -> loaded cell voltage
in this case: ((4.14V-4.05V)/4.05V) * 3.5ohm= 0.078ohm
+1 thing, the cell tempreture should be at room temperature ~ 20-25°C
unique engrish language... Smile
viktori
viktori's picture
Last seen: 3 years 5 months ago
I love this thread already. Smile
Viffer, do you have a source you can quote for that formula? I'd love to see an explanation for that calculation. Smile
Thanks!
Viktor
This is my flashlight collection.
viffer750
There are a lot of formulas. You have to use Kirchoff's and Ohm's laws simple.
here are two solutions below:
1
Uo: unloaded battery voltage
UL: loaded battery voltage
RL: load resistor
Ri: internal resistance
I: current
I use the first formula, because it is much easier to memorize.
kreisler
kreisler's picture
Last seen: 6 years 1 month ago
situation: the battery be under load, e.g. in a tailcap reading (flashlight measurements) for current (amperage).
Question: what type of voltage is it when i quickly interrupt the circuit, quickly take out the battery and quickly measure the battery's voltage?
this way, for example i was able to measure 0.8460V (i call it "remaining offline voltage") in an Eneloop AA cell which recovered to a steady 1.1680V after a few hours.
Apparently the cell's voltage under load at the point when i interrupted the circuit was *not* 1.1680V but i am measuring a sag of at least (1.1680V - 0.8460V =) 0.322V.
Assuming i would be infinitely quick with the measuring of the battery's voltage (see my Question above), would then the measured battery's voltage equal the cell's voltage under load (limes, in the limit)?
( Or is there any (other) way to measure the cell's voltage under load DIRECTLY? )
*FMI* i got 4 i/o sh
viffer750
This isn't a good example, because an eneloop at 1.1680V almost or fully discharged. And that's the reason why you measured 0.8460V when you took the battery out.
If you charge the cell up to 20-30% at least, the cell voltage will jump back very quickly to the unloaded cell voltage.
viktori
viktori's picture
1
RL: load resistor
I: current
Oh, lovely! I love it! Big Smile
Thanks!
Viktor
benckie
benckie's picture
Last seen: 6 years 10 months ago
I use the internal resistance feature in the menue of my icharger 106b+ and it gives me a read out good enough to compare to my other batteries.
viffer750
benckie
benckie's picture
Maybe putting that money to a decent charger that does IR or use the methods shown on this thread to work out th IR of the batteries
viffer750
Earlier I thought that it would be good to buy a 106b+, but I realized I don't need this, because I have a lot of nimh chargers including an ipc-1l, a lot of liion chargers etc, so  why?
And beside that, I should buy a good power supply for the 106b+, and finally I should pay $100 for these, then I could throw away my other chargers.
benckie
benckie's picture
If you buy the cheapest IR meter off ebay if you dont want to do the math for IR then you will have another item for your batteries, its great having 3 or 4 things to do one job, but the math is the cheapest option as a icharger 106B+ plus a power supply is around $130 usd with internation shipping not every ones cup of tea
cheaplite
Does this process only apply to li ion? if so why?
viffer750
It can be applied to all types of batteries.
