How To Build a Flashlight With Perfect Modes (picture heavy)
609 replies [Last post]
Tido
Last seen: 5 weeks 2 days ago
Title: ★★
So, you want a flashlight with modes that are just right but can't find the one, no matter how hard you look? You are especially craving for a light that can be programmed with light levels ranging from hardly visible to full blast can't-see-anything-but-dark-spots-for-a-few-minutes when accidentally shone into your eyes? Onna stick In a P60-style host? Well, today's your lucky day.
Building It
First, you will need to organize a few parts. From left to right, the NANJG 101-AK pimped with a fourth AMC7135 (other µC-controlled driver PCBs might also work), an XP-G R5 and a P60-style reflector with brass pill from KD.
Next, you sit down and write your own driver for the micro controller on the PCB. If you are lazy and have a PCB run by the ATtiny13, you might get the brand spanking new Budget Light Forum Versatile LED Driver and skip this step.
Now you flash the µC with your program...
...and assemble your flashlight.
Et voilà!
Testing It
Now let's take this baby for a test drive. First, highest output, picture taken with ISO 100, f/3.5, 1/25 sec.:
Nice!
Next up, lowest mode, same camera settings:
Is this thing even turned on? Let's take a look:
Well, maybe we need a longer exposure time. 30s should be plenty, right?
Hmmm well, let's just say it's really low.
Conclusion
Okay, I'll admit it, I'm just plugging the new open source driver for ATtiny13-controlled driver PCBs I just released. Since I got the idea for this project while reading BLF, I named it the Budget Light Forum Versatile LED Driver. I hope it can live up to its name. Some technical Notes: It can be built in two ways, either as programmable, like the Akoray K-106, giving you up to ten user programmable constant light modes (no strobes, SOS etc.). If built as fixed, up to ten modes can be defined at compile time, including all the fancy blinking stuff. And yes, it does a really low low mode. During testing it took my eyes almost a minute to adapt enough to the darkness just to find the spot on a white wall less than two meters away. If you think you might have a use for this, fetch your copy here and tell me what you think. All constructive criticism is welcome.
Edit: Updated links to the current version. Links to older versions: v0.1 v0.2 v0.3
SPAMBOT
SPAMBOT's picture
Last seen: 1 year 22 weeks ago
Title: ★★★
That is some seriously sexy
That is some seriously sexy stuff!
Now I just have to learn how to flash µC's ^_^
__________________
Now with all natural asbestos!
brted
brted's picture
Last seen: 8 hours 7 min ago
Title: ★★★★★
Nice work!
So you can re-program the ATMEL chip while it is still in place? How much for the board? I guess it's USB? Seems like you could make some money selling custom drivers. People love the K-106 just for the programmable modes, so if you can program that in there (with ramping and everything?) then you've really got something.
Have you got it where it can have mode memory?
. . . . Later on a Wiki was started to help get people started on this:
http://flashlight-wiki.com/AVR_Drivers
Aleister
Aleister's picture
Last seen: 19 hours 41 min ago
Title: ★★★
Very impressive! Where do you
Very impressive! Where do you find a "flasher" like the one you use? And which drivers can we use?
__________________
My flashlight has only 2 modes, day and night...
Sometimes a flashlight is just a flashlight...
Tido
Title: ★★
brted wrote:So you can
Yes, it's in system programmable (ISP). As long as the security fuses aren't set, it can be reprogrammed this way.
The programmer is an AVR Dragon with the Dragon Rider extension board on top of it. This combo can be bought for around $90, but it is a system designed for development and education. Simple ISP programmers cost less than $20.
Unless you're living in Germany, where it takes insane amounts of paperwork to sell anything in a commercial manner Wink
Yes, modes can be user-programmed like the K-106 (at least the way I think it is done there, I don't own one). Whether the driver provides mode memory or starts up in the first mode slot can be determined at compile time by setting or unsetting a #define in the source code.
Tido
Title: ★★
Aleister wrote: Very
You can find ISP-capable flashers for AVRs for a few bucks on ebay (search for AVR and ISP), but it takes a bit of knowledge to set up the necessary tool chain. Don't expect to just plug the thing into an USB port and press a button. Also, if you don't want to solder leads to the chip's pins, you'll need a debugging clip like the one I use. One of those will cost twice as much ($18 shipped from Hong Kong) as the cheapest programmer you can find Wink In theory this driver should work with any ATtiny13-based board that uses the µC solely for regulating the light output via PWM. I've developed and tested it on the NANJG 101-AK. Another likely candidate is the AK-47, but I don't have one here to test it.
agenthex
agenthex's picture
Last seen: 20 weeks 3 days ago
Title: ★★★★★
Hey Tido. I see that you used
Hey Tido. I see that you used a bunch of conditional #def's to get the right functionality (to the point of changing function headers). Is this done for any inherent reason or just a preferred embedded programming style? Seems like the way you split functionality to Programmable vs Standard, it's almost better to to have two programs/mains (if memory is an issue) that #include any standard functionality.
Also, have you tried or considered using the brownout detection for mode mem? I actually like the way you do memory better because it makes sense to me, but I think memory in many of the chinese lights set when you have the light off for a certain period, and I'm not really sure how they pull that off with just the brownout detection (ie discriminate between a short brownout and long one, do they use a cap to keep controller on but "browned out" or something?).
Thanks a bunch for doing this and releasing the code.
__________________
Reading this makes you smarter: http://lesswrong.com/
agenthex
agenthex's picture
Title: ★★★★★
Well, I answered one of my
Well, I answered one of my own questions. I looked at the hex files and you're pretty close to the 1k limit. Seems programmable + other modes is out unless you get clever, like define the blinking modes as a short set of parameters and incorporate them into the same pwm set function.
__________________
Tido
Title: ★★
Things aren't set in stone,
Things aren't set in stone, this is an alpha release, probably even more of a demonstration of what can be done. I'm not really happy about the programmable/fixed situation, but it was the only way to cram all the functionality into the tiny program flash without writing separate drivers.
Right now I'm not sure if I really want to keep the programmable light levels. After all, it's very hard to see a difference between, let's say, 75% and 80%. What is so attractive about the programmable light is probably not the fine grained control over light levels, but the ability to arrange the modes in a preferred order. Maybe it would be better to offer a number of fixed modes spaced at reasonable levels (e.g. 1%, 5%, 15%, 30%, 50%, 75%, 100%, strobe, beacon, whatever), from which three can be chosen in any order and stored into the mode slots (and the others could still be made available through a special click sequence). I'd be happy to hear some opinions on this.
Edit: Mode switching through brown-out detection is not planned so far. This would depend on the specs of external components (namely, the buffer cap) and right now I'm trying to keep this dependent only on the micro controller used.
sixty545
Last seen: 3 weeks 3 hours ago
Title: ★★★
Awesome! I downloaded from
Awesome!
I downloaded from here and managed to make an identical hexfile to yours in the folder Fixed Modes, so something must be right. Can this one be used to flash it into an AK47?
I would like to make a driver with a logarithmic scale of levels such as:
12,5% - 25% - 50% - 100%  or one with:
11% - 33% - 100%
Thanks, Tido
Tido
Title: ★★
The programmer looks usable
The programmer looks usable and at $11.50 delivered you're not taking much of a risk anyway. I don't know if the AK-47 is locked down, so you'll just have to try.
As for the modes, you might want to start lower. I used a PWM value of 16/255 for MODE_LOW, which is about 6% of maximum, and for me it is on the upper end of what I would want as a low mode. Of course the AK-47 uses only 3x 7135, so output would be about 25% lower than on the 101-AK. Just experiment and play around with the values a bit, that's what open source is for Smile
Vectrex
Vectrex's picture
Last seen: 3 days 21 hours ago
Title: ★★★★★
Erleuchtete Grüße Tido, I
I have already seen some of your posts on messerforum.net and geocaching.de, cool stuff you are doing with your µC-programmer.
Keep on going, maybe we can find a flashlight manufacturer to implement one of those programmable drivers of yours into a custom BLF light.
MrLite comes to mind, since they offer a reprogramming service for almost all their lights.
agenthex
agenthex's picture
Title: ★★★★★
Do you know at least how they do it? According to a brief glance through this http://www.atmel.com/dyn/resources/prod_documents/doc1051.pdf, it seems the brownout reset would be triggered regardless. So I presume the program counter (part of general registers?) is retained through the brownout so they can discriminate by the entry point after power is resumed?
Also, where did you get the right clip? I think I have a wider/larger one somewhere but it might not fit on that circuit/pitch. I haven't done any real electronics stuff in a while.
As for picking modes, a big list of fine pwm ratios (you can stack them more densely in the eeprom, or just calcuate them) in programming mode that you can pick up to 3 from (using a n-click UI you already have) would be really nice. For example, I can envision doing the 6click to get to programming mode, clicking through the many modes, and 3clicking to pick out up to 3 modes consequtively. Since you write to a mode slot in eeprom and increment every time, it's safe to stop halfway through to re-pick just the first mode so it's not tedious. You can even stack on SOS modes in the programming phrase but that would still spill over 1k unless it was optimized a bit more.
__________________
agenthex
agenthex's picture
Title: ★★★★★
My bad. I just found the doc
My bad. I just found the doc folder with the readme, which kind of helps. :)  You've already implemented the multiple slots. It wasn't clear just looking at the code.
I think the UI to do the programming is a bit tedious. Even what I described above is unnecessary. The programming can be done based on what mode/slot the user was already in.
For example, I'm in a mode/slot, and I'd like it to do something else. I 6click or whatever to go into programming, move through the modes to one that I like, 6click to leave programming, and that last level/mode I was in should be what I choose. Might need to be a tad clever (need x-click to be multiple of # of modes or something) to discern what mode I was in originally, but this UI would be simple and easy to remember.
__________________
Vectrex
Vectrex's picture
Title: ★★★★★
I have a spare AK-47 here...
I have a spare AK-47 here... it looks like this... received 2 or 3 weeks ago from DX... do you think it would be programmable Tido?
ATMEL 1022
TINY13A
Δ SSU
Tido
Title: ★★
I think the programming UI
I think the programming UI needs to be a bit complex to prevent accidental re-programming. If you can re-program by just clicking away, you will end up with garbled modes more often than you'd like. Especially with the time-switched-on kind of mode switching, where it doesn't matter for how long the light has been switched off. It's easy to end up in programming mode by repeatedly using the light for less than two seconds, let's say for finding the key hole every day. I think the light should behave completely different the moment it enters programming mode and changing anything must require some sort of timed action by the user. If he just keeps clicking or does nothing, programming has to be aborted. This may make programming a bit tedious, but how often are you going to re-program the modes?
As for the brown-out switching, from the programming point of view, the only difference between a normal and a brown-out reset is the set BORF-flag in the MCUSR register. You can check at start-up whether the flag is set and act accordingly.
I got the programming clip from ebay, but the vendor I got it from isn't offering them any more. Search for "SOIC8 clip", there are a few available from other vendors.
Tido
Title: ★★
Vectrex, there's an ATtiny13
Vectrex,
there's an ATtiny13 on the board and it's connected to the 7135s via PB1, so it should work with my program. The only question is whether the chip is still programmable. The only way to find out is to try it.
agenthex
agenthex's picture
Title: ★★★★★
Sorry I don't have the code
Sorry I don't have the code in front of me, but can you use a mechanism to time the consequetive clicks? Like 6 clicks within 3 sec or something, which doesn't seem like typical user behavior. I personally think it's bad idea to require a manual for programming a flashlight. My experience is that people tend to avoid complex UIs.
Where did you get your nanjg? dx or kd? I just bought from dx.
Also, can you check if maybe a SOIC 16 clip would fit, clearing the other components?
__________________
Oxy Moron
Oxy Moron's picture
Last seen: 1 year 1 day ago
Title: ★★★★
Very, very cool.   Tido
Very, very cool.
I can only speak for myself here but that is exactly what I want. I really don't need a gazillion different modes (which hasn't stopped me from buying lights that have about a million and one modes, but I digress) and even though I appreciate the ability to have absolute control, I don't really need that either. I know people who won't dare play with their (programmable) K-106s for fear of losing their moonlight/really darn low mode after they managed to get it just the way they wanted it. Having a bunch of reasonably spaced defaults would probably go a long way to improve usability.
Tido
Title: ★★
agenthex wrote: Sorry I don't
3 seconds in "absolute" time (on and off)? No, I can only record the time the light has been switched on.
DX. Although they seem to sell board of different specs over time. One I bought over a year ago and used for several tests and projects is flashable. From the two I bought a few months ago, only one can be flashed and even that took a lot of tries initially. The other one won't even be recognized by the programmer. The two from the latest batch I received a few days ago gave me no problems at all.
I don't think a SOIC-16 clip will work. I tried moving the SOIC-8 clip two pins to the left and right and it won't clear the chips on either side.
agenthex
agenthex's picture
Title: ★★★★★
Currently, you have the watchdog timer set to 2 sec and clearing clicks after this. As a practical matter, maybe using 1 sec for this and mode mem is a workable trade off?
If more than one timer is possible, or something to similar effect, you can also set a shorter timer to count the number of consecutive short ON periods (decrement clicks if longer) as a reasonable approximation of fast clicking. I can't think of non-pathological use cases that would violate this, especially with reverse clickies.  I suppose in the worst case this also works if we're willing to give up mode memory.
I don't mind buying a cheapo USBasp like the one above, but buying another $20 clip seems a bit excessive for just this one project (especially too many what-if's with drivers from dx). How many of the pins are active for programming? Would it be possible to just use a few generic probe/hook type clips?
__________________
Tido
Title: ★★
agenthex wrote: Currently,
Sure, it would be possible to record, for example, that the light was turned on 1, 2 or 5 seconds the last time. But if we started making distinctions, we'd end up with something like "turn light off within a short period of time to do A, and to do B, turn it off within another, but different, period of time". That would be very confusing.
The problem is that the same action is used for different things. Turning on for a short time (let's call this a 'tap' for now) means either changing modes or, if done repeatedly, going into programming mode. Maybe a single tap shouldn't immediately start changing modes, but instead be used for shifting functions? Let's say, a single tap does nothing. Two taps get you into mode shift, where you can cycle through the programmed modes, four taps let you cycle through all available modes and six taps get you into mode programming. The main problem with this approach is that people unfamiliar with this UI will be very confused.
ISP programming uses four control/data leads plus power and ground. If you're willing to temporarily dedicate a driver PCB to development (and have a steady hand), you could just solder leads to the pins and terminate them in ATMEL's standard 2x5 ISP plug. This way you could simply plug it into the USBasp. Or if you just want to play around with the program logic, you could use something like this:Breadboard
(ignore the upper half of the board, that's a loftover from a different project). I'm using a normal DIP ATtiny13 for developing the program logic and only use the driver PCB for testing with real light levels. Keeps the risk of being blinded by accidental mode changes to a minimum Wink
agenthex
agenthex's picture
Title: ★★★★★
What I meant was short-click detection just makes the entry point to the programming state less ambiguous (which you described as a problem). A "short-click" is just a practical timed cut-off for each click before the code resets the count var, not anything to be measured time-wise. I don't mean to change the general paradigms discussed.
So, IOW what I proposed is still:
1. select mode you want to re-program
2. signal 6 shortclicks to enter programming
3. click through mode options just like any other mode light and stop on the one you want
4. signal 6 shortclicks to set and exit
Same as before, but you won't enter 2 as easily by accident which I agree is possible with the existing way count is done. The problem with the above might be that 4 needs to be disambiguated from possibly clicking through the modes quickly in 3. Should this be a problem, perhaps replace "6 shortclicks" with some other sequence (short-long-short?), but make it the same sequence so the user has to remember just one special signal to program the light.
To summarize, I think this minimizes the principles the user has to remember. It's basically down to:
2 states, general use state, and programming state
1 signal to enter or exit programming state
click to move to next light mode.
That's all they have to know, more or less.
The main challenge is a signal that is unambiguous, not impossible to tap out,  and allows us to know which mode they were in before they started signaling.
If anything above doesn't make sense, please feel free to PM me and we chat over IM or something.
So I suppose step-through debugging works well with your tools? I can't imagine trying to write that program without it, especially with printf's in morse. Smile
__________________
agenthex
agenthex's picture
Title: ★★★★★
I've contacted the supplier
I've contacted one supplier in china, and he's now offering SOIC 8 clips in 1pc quanties for $10 shipped. This comes with the 10pin cable which is perfect for the USBasp's, and it's about half the price of anything else on ebay.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=400171159037
__________________
agenthex
agenthex's picture
Title: ★★★★★
On avr programmers, it looks
On avr programmers, it looks like the dragon board is probably the cheapest for anything with debugwire. In your opinion, is it worth getting debug capability for playing around with this or other simple projects?
__________________
Tido
Title: ★★
So far I didn't need the
So far I didn't need the Dragon's debugging functionality for this project, or, since this is my first µC project, for anything else. The code execution path is simple enough (always ends in an infinite loop somewhere) that it's easy to spot when it goes wrong somewhere. I'm sure I'll soon be using it for some other, more complex project coming along, but for this it would be overkill. One feature I did need was high voltage programming to unbrick the chip after setting the wrong fuses.
So, if you plan to do other things with it than just this project, get the Dragon, it's terrific value for money. Otherwise you'll probably be fine with the USBasp (as long as you always make double-sure the fuse bits are set correctly Wink).
On another note, I tried out the mode programming sequence you suggested. The first part (start from the mode you want to program, click x times, then select new mode from the extended list) works and is intuitive, but I'm not sure about the part where you store the selected mode by clicking again x times. I still think acknowledging should be done with some sort of timed sequence.
brted
brted's picture
Title: ★★★★★
Nice find on the clip,
Nice find on the clip, agenthex! I might have to give this a try. What do I need to run Tido's software?
sb56637
sb56637's picture
Last seen: 7 hours 2 min ago
Title: ==Administrator==
Fascinating post, Tido! Very
Fascinating post, Tido! Very well done. Frontpage'd and Sticky'd.
__________________
agenthex
agenthex's picture
Title: ★★★★★
Easiest way is you need that clip to go from the chip in the light to something to propgram it. The cheapest programmer is the USBasp linked above for ~$10. Or the USBTinyISP for about the same, or the Pololu for ~$20. I think I might get the latter (or the AVR Dragon) because it claims to be directly compatible with AVR studio, the official Atmel tool.
The software for this is free. For the toolchain, you get WinAVR (tool/compiller collection) + AVRStudio (gui/ide) for the dev environment. Studio can program the dragon or pololu (supposedly clones an AVRISP), or you use AVRDude that comes with WinAVR to program the two cheaper programmers.
I think the above is correct from my web browsing, but I'm a little behind Tido with zero ucontroller projects under the belt Smile.
__________________
agenthex
agenthex's picture
Title: ★★★★★
I thought a bit today about this today, and I still think it's possible to make this work as long as there are no technical hurdles. The essential part is down to tuning the timing. For example, when a user is just clicking through real modes, they're likely to at least pay attention to what the level/mode is. That means they're unlikely to stay in every mode for less than 1 sec that many times in a row (human reaction time is like ~1sec). On the other side of that range, you also don't want to require users to click furiously just to get into the programming state. I think a  <1/3-1/2 second limit may be too demanding. So setting the ON timer to somewhere in between 0.5 and 1.0 seconds seems best.
Another angle to the above is to find reasonable cases where the user might accidently drop out of programming (the other case of entering into is taken care by the fact they have to click/cycle through the equivalent of all modes twice to get into programming). For example, if there are loads of the same type of levels (like >10 continuous levels), the user might habitually click through all of them quickly to get the highest or whatever. I think this might be mitigated by squeezing from both sides. One is to limit the number of continuous modes; the other is to increase the number of continuous clicks required. A reasonable solution might be to limit the number of selectable continuous modes to 7-8, and increase the number of clicks to 8 (conveniently giving the user 4 normally selectable modes).
Of course it's possible that all the above combined might not work for whatever reason. I thought about what would be an intuitive signal. Requiring the two "changes" in timing like 2short clicks, 2 long, then 2 short seems like difficult acrobatics. 1 change seems reasonable, for example 4short 2long. This kind of requires measuring on time, at least to 2 levels, so I'm not sure how you do that. Maybe set the timer again after first callback? One issue is that the counting can be confusing to users, especially given the way it's implement; it's doubly so if they use fwd clicky vs. reverse clicky. Regardless, I still strongly believe there should be one signal that they learn, and it should be the easiest one that can work. Conceptually I think the right way to picture this is that there's ideally a recessed programming state button on the flashlight, but we're doing this because we only have 1 button to work with and have to find some replacement/alternative for that second button.
Welcome to the world of UI design, where everyone has their opinion and the way to get it right is to keep iterating Smile.
BTW, do these guys keep the chip at the default 1 mhz, so you're getting like 4khz on the pwm? Surely it's lower?
__________________
Tido
Title: ★★
Having taps of different length is no problem. The watchdog triggers repeatedly, so we could set it for 250ms and count the ticks in the ISR. To get the kind of tap, we just have to store a marker for "short tap" in eeprom on start up. When the ISR reaches 4 ticks, it overwrites the marker with "long tap" and at 8 ticks it clears it altogether.
The current development version uses 2n (where n is the number of programmable slots) taps to mark a mode slot for programming and go into extended mode selection. There you can cycle through all available modes. Staying in one of those modes for more than two seconds will select it as the new chosen mode. Next time the light is turned on, there is a timed sequence where the new programming can be acknowledged or discarded before the light returns to its normal mode of operation.
This sequence could be quite inconvenient for people who, for example, use a strobe mode from time to time, but don't want to waste a mode slot on it. They could just go to the extended selection, use that mode and abort the programming afterwards. The problem here is that the next time the light is turned on, they have to wait a few seconds before it can be used in the usual manner. By using a tapping sequence like short-short-long-short, this wait could be eliminated. When returning from extended mode, mode switching would immediately work as usual and only if the sequence is used, the slot is reprogrammed. The chances of accidentally hitting this sequence would be quite small, as people tend to switch through the modes at a constant rate. I think I will give this a try.
Yes, I know. That's why I kept to things like hardware architecture, low level drivers, automation and networking protocols at uni and stayed well clear of anything needing direct user interaction. It's such a drag to spend hours on something that doesn't really do anything of the interesting stuff Wink
It depends on the batch from which your driver comes. The first I got ran at 1MHz. The second I don't know, as I never managed to read the fuses and the latest batch ran at 9.6MHz. I set mine to 4.8MHz, as this makes ISP programming easy, delivers very high PWM frequency and guarantees reliable MCU operation down to ~2V.
Tido
Title: ★★
Okay, I've got this new
Okay, I've got this new programming scheme working and it looks like a winner to me. The extended mode list is hidden in normal use, but can be accessed without too much hassle. At the same time it's nearly impossible to reprogram a mode slot accidentally. It was even very hard to do it on purpose without counting the seconds on a watch, until I added some visual timing aid when leaving the extended mode selection.
I think I'll clean up the code a bit and release it as v0.2. I hope you guys will get your programming hardware soon, so we can discuss the further development based on real experience instead of all the theoretical musings.
brted
brted's picture
Title: ★★★★★
I went ahead and bought the
I went ahead and bought the clip and programmer today. Should arrive in a couple of weeks and then we'll see what happens. I already have an extra AK47 driver to test. Once we get this running it will be good to put together a complete tutorial on how to do it, software and hardware needed, etc.
sixty545
Title: ★★★
I'm a week ahead of you, ha
I'm a week ahead of you, ha ha Wink
and ordered 4x101-AK too.
exciting...
brted
brted's picture
Title: ★★★★★
Good! I'm going to need some
Good! I'm going to need some help.
Tido
Title: ★★
Version 0.2 of the BLF-VLD is
Version 0.2 of the BLF-VLD is ready for download here. There have been some substantial changes, especially for the programmable version of the driver. Light levels are not freely programmable anymore, but can be selected from a predefined set of nine logarithmically spaced levels and a few strobe modes. The programming procedure has been simplified a lot, thanks to agenthex's suggestions.
The driver can also be built in two non-programmable versions. The first gives access only to a subset of modes defined at compile time. The second version also has a fixed subset of modes in the standard mode group, but can access all modes defined in the extended group by switching modes x times in a row (configurable at compile time). This way a flashlight may have just three or four default light levels, but special modes like moonlight mode or strobes are still accessible without getting in the way on everyday use.
sixty545
Title: ★★★
Thank's for the new SW,
Thank's for the new SW, Tido.
I expect my programming equipment at my door in about one week.
I have calculated a little (or more) around the actual output from the emitters taking into account the degrading of output with temperature. There is quite a loss at full power.
I presume using a NANJG 101-AK with 1050mA for XR-E, 1400 mA for XP-G and 2800 mA for XM-L and that the LEDS reach about 125 degree C at full power. If DC was used instead of PWM one woud have to degrade also from the fall in efficacy with current.
That gives the following result if you want a doubling of light for each step:
XP-E Q5 at max 1046 mA:
Flux(LM) mA  output code
191     1046   255
 96       446    109
 48       210     51
 24       103     25
 12        51     12,4
  6        25.2    6.1
  3        12.6    3.1
 1.5       6.3     1.5
XP-G R5 at max 1395 mA:
341       1395    255
171        606     111
85         288      53
43         141      26
21.3        70      12.7
10.7        34.6    6.3
5.3         17.2    3.2
2.7          8.6     1.6
XM-L T6 at max 2790 mA:
629       2790    255
315       1127    103
157        527     48
 79        256      23.4
 39        126      11.5
19.7       63       5,7
 9.8        31       2.9
 4.9        16       1.4
Ofcourse you have to round the output code.
(corrected to PWM).
agenthex
agenthex's picture
Title: ★★★★★
In "pwm" the current is
In "pwm" the current is pulsed at max with the given % duty cycle so it's close to a completely linear relationship. The cree graphs are for a steady current, not any waveform with given average current density.
__________________
sixty545
Title: ★★★
I agree. In PWM the output
I agree. In PWM the output versus current curve can not be used, only the point for the drive current,  which leaves the degradation due to temperature. I will have to re-calculate for PWM. But linear it is certainly not.Laughing
I have now corrected the numbers in the former mail.
agenthex
agenthex's picture
Title: ★★★★★
How are you assuming the
How are you assuming the junction temperature?
__________________
sixty545
Title: ★★★
The assumption is that at
The assumption is that at full power the junction reach 125 degr.C. That of course depends heavily on the construction of the light. Perhaps 125 is a little too high looking at Don's measurements from turn-on until 2 min. (this looks more like 90-80% as for 100-120 deg.C)
The Cree curves output vs. current give the output at full current before degradation from temperature.
Using the Cree curves for nominal output vs. temperature I find the derate values at 1/4 - 1/2 - 3/4 - full power (AVG. current) corresponding to 50 deg, 75 deg, 100 deg and 125 deg C.
Then I use curve fitting to find the formula for nominal output vs. avg. current.
To find Lumens from this you just have to multiply with the actual bin's nominal Lumen output.
Now I just have to get my programmer board and clip and 101-AK to try it out.
Ebay and DX, come on!
Can't wait...
agenthex
agenthex's picture
Title: ★★★★★
My drivers are stuck in
My drivers are stuck in pending at DX. Dammit.
But...Kinect computer drivers are out (no obfuscation over usb, it seems), so that's something very very cool to play with. $150 for probably the most advanced piece of equipment you can have in your house.
__________________
Tido
Title: ★★
I just received three 101-AKs
I just received three 101-AKs and a NANJG-106 from KD (took only 13 days from ordering to get to my doorstep!) and all of them are flashable.
brted
brted's picture
Title: ★★★★★
Let us know if the NANJG 106
Let us know if the NANJG 106 is really 2.8A as it should be. Also I know you will be flashing them, but it would be good to know how the modes are spaced by default and whether they can be changed by soldering to the stars. That could be a really great driver for P7's, MC'E's, and XM-L LED's.
Tido
Title: ★★
I can't test if it really
I can't test if it really delivers 2.8A because I don't have any LED capable of handling such a current. It does have 8x AMC7135 in parallel, so it should be a able to regulate at 2.8A. I'll test the modes once I removed the 4 "spare" 7135.
I'm not convinced this will make a good MCE/P7/XM-L driver, as it can only be used with a single Li-Ion cell. There are also no buffer caps for the 7135, which are needed according to the datasheet.
phlowcus
Last seen: 4 days 4 hours ago
Title: ★★★
Tido wrote:I'm not convinced
Yes, it will run out of regulation rather fast and act as direct drive, only less effective due to the AMC's own voltage drop.
Hm, I think they may be only needed when used with a switching power supply?
Tido
Title: ★★
brted wrote: Also I know you
I just did a quick test and the stars work just like they do on the AK-47. You get exactly the same mode groups.
Tido
Title: ★★
phlowcus wrote: Hm, I think
One version of the datasheet states that a 0.1µF ~ 1µF buffer cap should be added to the output pin if the LED is not mounted on the same PCB. It's probably true that this will only have an effect if the supply current is not steady, but with PWM we're having a switching frequency of up to 20kHz.
I'm just a software guy, so when the datasheet strongly recommends adding this caps, I try sticking to it. Do we have an EE around here who could comment on this?
brted
brted's picture
Title: ★★★★★
Tido wrote: I just did a
That is so awesome! Thanks for checking, Tido!
sixty545
Title: ★★★
Tido wrote: phlowcus
The capacitor is used to limit oscillations that can occour when switching large currents through inductive paths like a long wire. The oscillations produces voltages that could be destructive for the components and/or violates EMC regulations. EMC = Electro-Magnetic Compatibility. This concerns noise disturbance of other electronic equipment. A driver without the capacitor could make a "dirty" light.
brted
brted's picture
Title: ★★★★★
The clip showed up today.
The clip showed up today. Hopefully I'll get the USB stick soon and be ready to try this thing out. If I do a programmable UI, I'm thinking I'll set up 4 modes and set them L-H-L-H to start with. Then if I need a medium or a different Low, I can set that. But L-H-L-H will be like having a 2-mode light with an option for 4 modes.
Comment viewing options
Select your preferred way to display the comments and click "Save settings" to activate your changes.
