Mini Mag DIY mod guide
9 posts / 0 new
old4570
Last seen: 8 hours 52 min ago
http://www.candlepowerforums.com/vb/showthread.php?t=242361
Pictures are back !   anyhow did this a long time ago , and then gave the light away , simple cheap MM upgrade ...
Sorry , on the other forum [ the one we cant talk about ]
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Huny74
Huny74's picture
Last seen: 3 years 4 months ago
Thanks for the link! Great mod instructions!
I did not know that you can direct drive an LED with two AAs (as I don't know many other things).
I modded a Mag 3D and am very satisfied with the result but my old and battered MiniMag which I refused to recycle because of nostalgic reasons has been just lying around for years. Could just not imagine how to fit a driver in there, and now you tell me I don't need it!
Will try your mod asap, thank you again!
charlescleec70
I second the thanks.
xP.1337
Last seen: 2 years 6 months ago
this is a nice mod, but a minimag doubles as a laser pointer much better.
AA's may be cheap, but they just dont perform for their size.
im partial to 18650 and Cr123a
old4570
The trick here is to get more light , for very little $ invested in a upgrade .. So for the price of a LED ... You can build a nice custom DIY
Huny74
Huny74's picture
Thanks again, old4570!
I am now the proud owner of a XP-G R5 (or so it's labeled at DX) MiniMag!
SecaRob
Old4570,  could this be done with the 3AA miniMag as well?  I have a XPG-R5 lying around as well
old4570
Voltage voltage voltage , its a safe mod with 2xAA , but 4.5v , if you could squeeze in a resistor to drop the voltage ..
+ Heat , overdriving the emitter will make it hot . real hot .   And plastic does not offer the best heatsinking , so quite a few issues would come to mind ..
1/ Killing the emitter
2/ Melting the plastic parts
This is a great 2AA mod as the emitter is so under driven that it does not get very hot , but still puts out about the same light as the LED Mini mag , if not more with a XP-G ..
My LED mini mag has been moded to XP-E Q5 , and puts out about double what the original  did .
Its up to you , but I would seriously put in a resistor , if I was going to try it with a 3xAA minimag .
Hayley
Last seen: 8 years 7 months ago
Thank you for sharing, the process is very detailed
