Shadow VG20: Shadowlicious
Is Shadow Foy's new Solarforce? The need for something different, something new, a different flashlight direction has finally been met. The Shadow VG20 is spectacular proof that bling can be tasteful and that a flashlight will not explode from your hand because it lacks knurling. This is flashlight nirvana, folks and the dopamine release will be irresistible for the true flashaholic addict. The Shadow VG20 is not just a torch with a lot of options, it is a finely machined, superbly assembled lighting instrument that has changed this writer's perception of what a flashlight can be. Pictures cannot begin to do the VG20 justice. What I saw with my eyes when ordering looked promising. What I hold in my hand today exceeds every expectation. The Shadow VG20 gets a resounding . . .
Foyapproved
Bottom line: The Shadow VG20 is a design tour de force. The metal work is near flawless, the anodization exceptional and the quality you see is the quality you feel. It has blazing XM-L performance, a clever user-defined UI and the versatility of single or dual battery configuration. And, maybe I just got lucky but this VG20 probably has the best tint of any light I own. It is loaded with extras, drop-dead gorgeous and for the flashlight addict; the VG20, without doubt will become the prize of any collection. It is worth every penny, its asking price.
Foyapproved
What I like:
- aesthetics
- finish/color
- tint
- UI
- no-knurl look
- machine work
- stainless bling
What I do not like:
- OP reflector (sorta)
- slight ano inconsistency between cooling fins
- could be driven a little better
- likes short batteries
Shadow VG20 XM-L 1/2 18650 Flashlight
$52.00 Int'l Outdoor http://www.intl-outdoor.com/shadow-vg20-xml-1218650-flashlight-p-330.html
ordered: 2-16-12
received: 3-8-12
Cree XM-L/T6 1A cool white emitter
OP reflector
designed for 1 or 2 18650 lithium-ion batteries (no working voltage listed)
<<update>>
programmable 3 or 4 mode user interface with mode memory . . .
To change between 3-mode and 4-mode with strobe; cycle to low mode and wait until light flashes once, then immediately turn light off.
3-mode: high (100%) medium (50%) low (10%)
4-mode: high, medium, low and strobe
6061-T6 aluminum
"HA III" pale green (?) color
tail-standing, reverse clicky tail cap switch with 16mm boot
flat, 304 stainless steel head and tail cap bezels
stainless steel tube trim rings
copper, screw-in pill
IPX-8 (immersion beyond 1 meter for at least 30 minutes)
selected manufacturer specifications:
"700 lumens"
208mm (length) 25.4mm (body) 37mm (head)
(143mm single battery length)
180 grams without battery
what you get for $52:
- VG20 flashlight/extension tube/2-sided sliding lanyard ring
- lanyard ring (single, for use without extension tube)
- spare tail cap switch (complete)
- 3 spare o-rings (received only 2)
- lanyard
- gift box
tail cap draw: with 2 x unprotected Panasonic 18650/2350
high: .85 amp (approx. 1.70 to emitter)
medium: .40 (.80 to emitter)
low: .05 (.10 to emitter)
1 x Panasonic 18650
high: 1.73 amps
medium: .77
low: .10
Run-time with 2 x Panasonic 18650s charged to 4.22 volts each.
Flashlight on high.
time | Foyometer |
11:26 | 148 |
11:34 | 144 |
12:06 | 142 |
12:28 | 140 |
1:06 | 144 |
1:26 | 144 |
1:55 | 143 |
2:00 | 118 |
Looks like 2.5 hours on high. Pretty dang good.
Foyometer (for comparison only)
60 - Foy's dimly lit office
107 - Solarforce L2X extended with 3-mode Solarforce 8.4 volt XM-L drop-in and 2 x Xtar 18700/2600
157 - Shadow VG20 with 2 x Panasonic 18650/2350
170 - Solarforce L2P with 3-mode UltraFire XM-L drop-in and 1 x Solarforce 18650/2400
As I've said before; gift boxes are useless and do unnecessarily impact the environment. I don't care. I still like it. My VG20 arrived undamaged, packed as you see here, 21 days after the order was placed. I think the "Shadow" name font/graphic is cool.
Who knew no knurl could be so pretty? Body design simplicity is hardly austere with stainless trim rings on each tube and a 2-sided, sliding lanyard ring on the extension tube. Vertical cuts are few and the two battery length gives ample room for a large hand between head and lanyard ring.
Machine work is stunning with laser straight cuts and nary a chip or flaw to be found.
From any angle, the VG20's design is an inspiration. This is form, following function that works; both aesthetically and in actual use. The smooth surfaces may not age well with hard use but as a collector light, the VG20 is without peer.
The pale green finish is a dull matte that seems to absorb light. It also easily picks up dirt or (as happened to me) ink from your hands. Shadow calls it "HA III" and it feels quite resilient. I love how the trim rings repeat the stainless silver of the head and tail cap bezel.
Probably one of the best looking flashlights I've ever seen and it's easily the hottest looker in my humble collection . . .
. . . but the VG20 is more than just easy on the eyes. The quality of this torch is nothing short of spectacular, with features found on very few flashlights - whatever the cost.
Eye popping design, old-school craftsmanship with exquisite execution and . . . one of the best cool white tints I have ever seen.
It's just as good looking short as it is long . . .
And, speaking of versatility; the VG20 has an ingenious UI solution. The light can be programmed for 3 or 4 modes. Turn light on low mode and after about 3 seconds it will blink once. If you do nothing, nothing changes but if you turn it off right after the blink, it changes modes. The flashy minority can have a blinky while the rest of us enjoy a simple descending, 3-mode UI.
I'm guessing a lot of guys will prefer the VG20 in single battery form and Shadow thoughtfully included an extra lanyard ring for the primary tube.
The VG20 makes a terrific single 18650 torch.
When's the last time you saw lathe work this awesome? There are lights that cost double the VG20 that can't begin to appraoch this level of fit and finish . . .
. . . it's almost like jewelry . . .
Shadow eschewed "tactical" scallops for this gorgeous, clean and flat stainless tail cap bezel.
Of course the threads are beautifully square and a silky smooth delight to feel.
Large, copper screw-in pill should provide a good thermal pathway.
Is that some Fusik or just glue?
Foy likes red o-rings.
The following beam shots were taken with a 1/4 second shutter speed @ f2.8.
First up is a Solarforce L2X/extended with my new Solarforce 8.4 volt XM-L drop-in and 2 x Xtar 18700/2600.
This the VG20 with 2 x Panasonic 18650/2350. I will later include some white-wall profile shots to better show the outstanding tint.
Solarforce L2P with the 3-mode UltraFire XM-L from Manafont. The L2P is brighter but the VG20 will have a bit more throw because of a slightly larger diameter reflector.
Left to right: Shadow JM05 (review on deck) Shadow VG20 and Solarforce L2P. Some might be put off by a long flashlight with a head barely bigger than a P60 but I predict the look will endure.
For a flashaholic, this is about as good as it gets and few flashlights combine top quality and great performance so beautifully, with so many extra features. I can't tell you how pleased I am with this Shadow. We'll see how I feel when (if) the new wears off but right now, nothing in my collection even comes close.
The Shadow VG20 is that good.
blownawayFoy
