New Solarforce RCR123A Battery Test
27 posts / 0 new
old4570
Last seen: 4 days 13 hours ago
These are the new RCR123A batteries from Solarforce ...
DIA = 16.7mm
Length = 36.1mm
Protection Circuit [ cuts in @ 3v to protect against over discharge ]
I was lucky to get my hands on some of the new Solarforce batteries . And I would like to thank http://www.solarforce.hk
for the opertunity to test the new cells . The first thing I wanted to test for was discharge levels , in other words
how well the cells are matched for discharge , and to say I was suprised is an understatement . The cells are very well
matched , and I find no fault in this regard . I tested at different levels and if they were not to close to call they
were the same [ results ] , for example , with the SSC P7 pill in the L2m , I got 2A even for the cells tested . This is
better than expected , considering the little RCR123A's would have been pushed very hard .
Testing the older Solarforce RCR123A resulted in 1.79A in the SSC P7
The AW RCR123A did 1.81A
And the new Solarforce RCR123A as mentioned did 2A even .
Now this runtime graph is going to look a little different , simply because Im using a single mode low voltage Solarforce
pill in my L2M [ 1 x CR123A with single mode XR-E R2 ] , which would be Buck Boost ... which hopefully explains the curve ..
Now termination came about from the protection circuit activating at 3v under load , all batteries tested , were terminated by the Protection circuit  ...
And as can be seen , the new Solarforce RCR123A perform very well .
They performed well in discharge [ well matched ] , as well as capacity , and look to be a serious contender for your hard earned money .
Update
I put a cell through my [ new ] balance charger , Discharge rate was 0.5A and ended at 3v , resulting in some 721mA being discharged .
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Edited by: old4570 on 03/11/2011 - 23:31
antib
Last seen: 6 years 4 months ago
Wow , those looks very good!
Nice review, Thanks!
I hope the "consumer" also will be good. (The test version are sometimes better, as the final production)
I'm thinking, i will buy 4-6 from the 18650 V2, but i wait your review!
Can you tell us the physical dimensions?  ("Important" data, for some flashlight)
old4570
I usually include DIA + Length ...  Ive just started testing the 18650
DIA = 18.1mm
Length = 67.7mm , it will take a few days
qguy
Last seen: 8 years 2 months ago
ARGHHH... my older version just got delivered 4 days ago !!!.
 2.0 amps for the new models, 1.79a for the older version. What does an extra .21 amps (10 percent more) mean for my Solarforce XP-G bulb ?, will it give my 320 lumens bulb another 32 lumens ?
old4570
Just depends ...   Higher current usually means more output , but less run time ..
These new cells , offer both , better discharge , and improved capacity ..  But check out to make sure they fit , as they are on the long side ... [ New cells ]
qguy
they fit, will be using on solarforce L2p
scruffy dog
Last seen: 3 years 8 months ago
where are you guys buying these cell
 i have just spent 2 hours trolling all the usual HK dealers i cant find them on any of the sites
Barrie
SashiX
SashiX's picture
Last seen: 4 years 10 months ago
SolarForce Retail & Dealers here.
Check SFS/ITC web pages and also @ ebay Wink
scruffy dog
Thanks SashiX
i have looked at the dealer links but shipping costs kill the deal there was nothing on E-bay when i chacked i was hoping one of our dealers in HK with free shipping had them
thanks for your time
Barrie
EDIT - the E-bay link you gave dose have them
Cheers Barrie
Magsy
Last seen: 5 years 11 months ago
These look great! Thanks for the test.
How can I tell new from old? That ebay shop has ones that look different, with black text...
scruffy dog
DoH  stuped me
 read the small print  i did not
just bought 3 cells i thought were free shipping at $3.90 each
 only free shipping in the US  $6 per item to me  and i am commited to buy
 we live we learn
old4570
Old cells were white with black print .. New cells are blue and white as pictured ...
I looked yesterday . and could not see any of the new ones for sale ..
Saw them before new years , but not ATM ...
Piers
Last seen: 3 years 5 days ago
I'd send them an email asking them to combine the shipping cost as obviously $18 is madness. They should just charge you the $6 even that seem a little over the top.
scruffy dog
Hi pook
i have done that and complanad that his ad was misleading as it says free shipping but dosnot say to the US only in the main ad
 and said i would like to cancil the order got a reply today offering free shipping if i would buy so a good result and deal done somtimes it pays to question things
Piers
Ahh good, good. It was possibly just a mistake on the listing, I know things can get complicated if you're listing in multiple eBay domains.
old4570
You guys are not going to like this ...
I put the Solarforce V2 RCR123A through the Imax B6  @ 0.5A  and some 721mA was discharged to 3v Tongue out
scruffy dog
is that bad sorry for my ignorance
 even at 721mA it going to be a lot better than the crappy 3v batts i have
old4570
Thats good , especially considering everyone exaggerates capacity ..
Or maybe the parameters are different , like the cells are discharged to 2.5v or something ?  Anyhow , 721mAh is very good .
What I meant by people not liking it , was , ATM , these cells are a little bit hard to find ...
scruffy dog
that's good to hear i never believe what is claimed very few manufacturers tell the truth regardless of what thay make cars- motorcycles -lights- Batts
or anything else most of there power claims are exaggerated
fishinfool
fishinfool's picture
Last seen: 2 years 7 months ago
Thanks old!   It looks like my next RCR123A puchase will be from Solarforce.
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
sugiarto
Last seen: 7 years 11 months ago
Hi old4570,
Just want to make sure, is it true that the old Solarforce is not a good one (according to your thread in here http://budgetlightforum.cz.cc/node/1327) and the new Solarforce is prety good.
New Solarforce has more length compare to the old one, will this be a problem to some of flashlight?
Thanks.
old4570
Yes the new Battery is good , No , the older batteries are just that , old , they did not age well .. How the new ones will age ?
Yes , they are long , in fact a little longer than the protected Flame Trustfires , and yes in some lights , that might be a problem .
I use them in my A20 T5 , and I had to mod the light a little to make room for the batteries ...
Jayc
Jayc's picture
Last seen: 2 years 11 months ago
Atm, Solarforce is selling 2 types of RCR123’s
A white one with blue text, and a white one with black text
Is the blue text battery the newer version to the black text?
Or
the black text battery is version 3, and version 1 is no longer sold?
Secondly, is the diameter of both batteries the same?
I’ve heard the blue battery has a 18350 size.
On the Solarforce page, it says the white one is a CR123A, then says it’s a rechargeable, then on the battery it says 16340 which sounds like an IMR.
old4570
Blue text on white = New
DIA = 16.7mm
Length = 36.1mm
Black text on white = Older
Dont own any ATM
Jayc
Jayc's picture
Then I bought 2 of the wrong ones > <
The black and white version looks so respectable though.
Thanks for the info, old4570
Jayc
Jayc's picture
Do you think both the RCR123 versions can handle 1.5A safely?
how2
Last seen: 4 years 2 months ago
Yes they can but run times will be short.
