quick question... will two unprotected 32650 cells fit in a 2D mag with cut down OEM spring?
thanks!!
thanks!!
Yes I believe so
... do I need to bore out the MAG-D tube ID a little? I ask because I had to get my 2C bored out a little to fit IMR26500 cells
No u need a spacer u can use a PVC pipe for that I'll post back with the size u need or u can pay me for the shipping and I'll send u one ?
Hi thanks for the generous offer, but I already have a 2x26650 adapter for my D mag. What I want to to is upgrade capacity to 2x32650, and leave the adapter tube out.
What I am unsure of is do I need to bore out the 2D inside diameter a little to fit an unprotected 32650 cell?
thanks!
Let me go check and see
A 2D barrel ID is 34.6mm (Incan). I don't know the Dia of the 32650 is ?? It should fit, but I think a LED Maglite is a different ID. I never measured when I had one.
The KD 32600s need a shorter spring than the stock Mag issue. KD used to sell them and may do so nowadays. If they don't, cut about an inch off the stock spring.
The 32600s that KD sell are flat tops and need magnets to work in a 2D Mag.
