NEW! Balder SE-2 18650 XM-L 500 Lumen flashlight in stock @ EDCPlus
Hi guys,
Balder just released a new model the SE-2. This light has a lot of higher end features found on much more expensive lights. Best of all the price is only $34.99!
The light features HAIII, a forward clicky switch and pocket clip!
Here are the official specs:
1. Mil-Spec Type III Hard Anodized finish.
2. Made from Aluminum alloy, really strong.
3. Water proof to IPX-8 standard.
4. Precision Aluminum reflector (Orange Peel)
5. Simple operation. High-Medium-Low. No SOS and strobe modes
6. Single 18650 for stronger beam and longer runtime
7. Tactical switch for momentary on.
8. Prominent runtime
9. Advanced Cree XML-T6 LED
Specifications:
1. Dimension: Head diameter 33mm, Tail diameter 26mm, length 138mm
2. Cree XML-T6 LED
3. Lumen and runtime:
Single 18650:
Maximum output of 500 lumens for 1.5 hours
Medium output of 120 lumens for 10 hours
Minimum output of 20 lumens for 150 hours
4. Material: Aircraft Aluminum Alloy T6061
5. Weight: 110g (without battery)
6. Water proof to IPX-8 standard
7. Battery: Single 18650
8. Accessories: O-rings, user's manual[/LEFT]
We also now have the SE-1 back in stock, and now also available in Cool White T6, and Neutral White T6 3C! Also 2AA extension tubes for the SE-1 are now in stock! :)
Click the link below to go to EDCPlus for more pictures and to order!
Some Amazing lights for the price here guys! HAIII, Forward clicky, XM-L T6. These are features not typically found in a brand name light in this price range!
Would it be possible to see the pill in this light ?
I am interested in the construction because I want to know more about the heat dissipation .
Can you please post a picture of the light completely broken down ?
The lighting was not ideal (shadows), but this should give you an idea of how its constructed:
One item that is not pictured (didn't want to remove it) is a spring and retaining ring that makes contact with the driver board. This allows flat top cells to work.
Thanks for the pics! Does this light have memory?
No mode memory, always defaults to high mode.
I like the looks of this light .
I have and enjoy using a neutral XML SE-1 , so now I may just buy it's big brother .
Do you have a Beamshot ?
Jack - This looks like an economy version of the Balder BD-2 with a little less bling - very nice. The BD-2 is one of my favorite lights FWIW.
@EDC+: The head diameter between the two differs only by 2mm, but is it the same reflector in the SE-2 and BD-2? Does the SE-2 have hidden strobe mode like the BD-2? How about current regulation?
Quite a milestone, BetweenRides.
That is exactly how a forward-clicky should work. So if you use the “half-click” momentary on function, you always get High. If you don’t want High, you cycle to what you want before you do the “click”.
I guess I should have done a giveaway... :D
"That is exactly how a forward-clicky should work. So if you use the "half-click" momentary on function, you always get High. If you don't want High, you cycle to what you want before you do the "click"."
Correct.
FYI, these are now out of stock for about 2-3 weeks, but pre-orders are welcomed.
Where do these ship from? Nice lights BTW.
Keith
California. For International customers I may have them shipped from China directly by Registered Mail.
EDC+, you might have missed my questions ^^^
Yes I did. Sorry. I am told it is the same reflector. It appears to be the same. The SE-2 does NOT have any hidden modes like the BD-2 does. The driver is different. The output should be regulated until the battery gets low, but I've not done a full runtime test yet. Hoping for the reviewers to do this!
Thank you. Looks like a very nice light and the price is right.
Where are you finding this light for $34.99?
Click on the EDC+ logo in the first post then locate the SE-2.
As mentioned above its on backorder now for ~2-3 weeks. Pre-orders are welcomed.
Any discount for BLF members?
