The Blues Brothers +1 - Maglite Style
78 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
I decided to make a Trio of Maglites. The Blues Brothers. I already had a 2D Blue and found a 2 pack 2AA & 2AAA Mini Mags, in Home Depot, so I brought them home to meet their big (now small), brother.
bb1
I had already been working on the 2D, to make it into a 1x26650/3AA host, but now I will complete the trio and sell them together.
I intend on putting XM-L emitters in both the 2AA and 2AAA lights, with 2 Alkaline batteries. It should light them up direct, although not as brightly as with 3 batteries. I do have a board for the AA light (14mm board), but it's only like 700ma. 3v off 2 alkalines should put out about the same?, according to Cree specs. There is no board small enough for an AAA Maglite.
Anyhow, I will be dressing them up to match each other. It will be interesting to see if I can, on the small lights.
 The AAA Sub-thread is HERE...
The AA Sub-thread is HERE...
More to come, later..............................................................
I tried doing some filework (vine pattern) on the bezel. It did not work Jack! What a mess. Anyhow I thought about tossing it, but then I just tried to make it look like something. I don't like it, but I'm not going to try to find another Blue Maglite and start all over again. The heck with it, it is what it is.
1111
I also made a heatsink. I don't have much room for a heatsink due to the deep reflector and shortness of the light. The only thing I did different is to make a spot for the driver, where I can solder it right to the copper outer sleeve of the heatsink and hopefully my poor ground problems will be resolved.
2222
3333
Later..........................
 The cosmetics are almost done:
bbc1
bbc2
bbc3
Being as this is a "Set", I needed to have some continuity with all 3 lights. Due to the small size of the AA/AAA and other factors, I chose to do it this way. The AA light does not have any body rings cut yet. I still have to finish it, but I wanted to give y'all a taste.
Carry on...
Tailcap Switch,
I have done one of these before, but I figure I should show this one, so newer people can get the idea. This is a home made tail switch assembly.
1d1
Here's the components. The tailcap, A Judco switch (10amp pushbutton), A plastic bushing from lowes, a piece of 1" copper coupling and 24 gauge flat copper, a gold plated spring, a dd circuit board and some 1" plastic washers from Lowes (not shown till later).
Lowes has a bunch of specialty fastners in metal bins. I get most of my plastic bushings, washers, screws and nuts from there, as well as the copper pipe & fittings.
1d2
I start out with a small drill, like 1/8" and drill the center of the tailcap. Then I go up to 1/2" and from there I use the rotary bit. As you can see, it's not perfect. To get it perfect, one needs "the L word".
1d3
With this switch assembly, I decided to make a step, so that when the bushing goes into the tailcap, the step makes a stopper. This was done with a rotary tool. Again, it's rough and not a perfect fit. Thank goodness for Arctic Alumina to fill gaps and paint to cover it up.
1d4
Here's the bushing and switch set in place in the tailcap. I used a tapered stone in the rotary tool, to give the taper to the center hole, so it's easier to access the switch button. The button is less than flush, so tail standing can still be done.
1d5
Inside with the back part of the switch.
1d6
The 1" copper coupling is too big to fit down in the tailcap, so it has to be split and about 1/4" removed, so it can be squeezed into the tailcap. The cutout is to clear the contacts of the switch, when they are wired. The top piece of flat stock, is to keep the switch from backing out. This copper bushing is press fit and keeps the assembly from moving back, as well as being a ground for one of the wires of the switch.
1d7
A shot of the copper bushing going in. I will not drive it in for real until it's ready to go. I don't want to try to get it all out again, as driving it out will probably mess up the switch.
1d8
This shot gives you an idea of how the assembly sits in place. The slot lets the contacts and wires be clear of the copper. One of the wires will be soldered to the copper.
1d9
The last shots show how the spring assembly will go together. The 1" washers sit in the top lip of the tailcap. I use the blank board sandwiched in between the washers. The other switch wire is soldered on the bottom of this DD board and the gold spring is soldered to the top. AA will keep the washers in place.
That's about it. I showed it this way, because as you can see, it can't be seen once it's put together.
It looks like this set is already sold. A good offer can't be refused.
Finished.
Photos:
d1
The reflector was SMO, but it had several rings in it and adjusting didn't help one bit. I made it into my version of an OP reflector, with Krylon Clear.
d2
The 26650 adapter and the modified 3AA holder.
d3
Garage door
d4
Side of house
d5
Across the pond.
This 1C T6 led gives a nice white light and I am starting to favor it over the neutral. The newer version of the KD 8X7135 driver giver more amps and I think it's noticeable. There is a 2nd setting. I bridged for H/M/L, but of course, the paper they sent with it is wrong and I got H/L or H/M
It is what it is.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 04/27/2012 - 02:56
Chicago X
Chicago X's picture
Last seen: 6 years 9 months ago
So there's Jake, Elwood, and uh....John Goodman?
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
Don
Don's picture
Last seen: 2 years 11 months ago
Surely it's Jake, Elwood and the lighter that Jake threw out the window after he got out of jail.
I've seen that movie quite a lot of times - often enough to count the stunt drivers in the credits. 86 if memory serves.
Not seen it for ages, time to watch it again.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
BetweenRides
BetweenRides's picture
John Goodman, aka Mighty Mack McTeer. Blues Brothers 2000 was an awful movie, never could compare the brilliance of the original.
My vote is for Jake, Elwood and Twiggy.
Shadowww
Last seen: 3 hours 26 min ago
For the 2*AA / 2*AAA lights, you'd be way better off using three 2/3AA's and three 2/3AAA's respectively. They are only around 700mAh for 2/3AA's and 400mAh for 2/3AAA's, but 2x alkalines / 2x NiMH's would barely light the LED up at all, while those 2/3 types would shine in direct-drive.
You can get both types at batteriesinaflash.com, for something like $2 - $2.5/piece.
(or two 14500's (Li-Ion or LiFePO4) and a buck driver, but I doubt that'd fit + I heard you like direct-drive)
mizjif
mizjif's picture
Last seen: 2 hours 42 min ago
I am loving that 2D host! What an awesome set of lights!
Old-Lumens
I looked at that stuff, but I didn't want to mess with custom spacers, since the stack ups would be 20+mm shorter for the 2/3AA and 10+ for the 2/3AAA, but it's an idea. No way to charge them either. It's not that I like direct drive, I just cannot solder tiny wires on tiny drivers. I always ruin them or short them out.
I just figured Alkalines would give them 3V for a little while at least, but maybe it's a waste. Guess I will have to test one with 2 Alkalines.
charlestt
Last seen: 2 years 9 months ago
 http://i776.photobucket.com/albums/yy41/charlestt225/Sig/A1200023-1.jpg" width="159" he
Old-Lumens
Of course, another way is to just leave them as Incans. After all, these are all just shelf queens anyhow. That way I wouldn't have to screw with all this crap. Just dress 'em up and leave it at that. I hesitated to mess with the AA/AAA, because basically, they are a real pain, but I just thought the trio would look good on a shelf. Make the 2D into a 3AA XM-L and leave the others as is, except for dressing them up. Not a bad idea really...
Rezolution
Rezolution's picture
Last seen: 1 year 4 months ago
You can direct drive the XML in the 2AA with a single 14500 and a single AA dummy cell.
The AAA light, same thing. One 10440 and a single AAA dummy celL  Each setup will give 4.2 V
Old-Lumens
Ya, that would work. I don't have any Li batts or chargers. I could always make the dummies and then sell them and let whoever got them worry about getting the Li batts. It's an idea.
Old-Lumens
Wink
Old-Lumens
For the AA and AAA lights.  FD-A Boost Current Regulated 0.7V~4.2V 1.0A Flashlight PCB
fdab
I happen to have One of them. Does anyone in the US happen to have one of these? I hate to order from KD and let this all sit for three weeks, but if no one has one, I will have to...
Thanks
NightCrawl
Last seen: 4 years 5 days ago
Is that driver new? I've been searching 2AA drivers a long time now and the only one that seemed good to me was the DX one. This one seems pretty nice, tho its only 13mm..
PCC
Last seen: 5 years 8 months ago
fdab
Thanks
Lots still too large for the AAA.  Also, keep in mind that even NiMH AAA cells would struggle to put out the amount of current needed to keep this thing pushing out that much output.  I'd use the 700mA driver on the AA and the AAA driver from Illumination Supply in the AAA cut down to 1XAAA.  If you don't want to cut it down then I can make a spacer and drop it off with Craig to send to you along with that driver.
Shadowww
1A at LED needs ~1.8A with two AAA's, Eneloops can handle that just fine (in fact, they handle up to 3A just fine) Silly
Chicago X
Chicago X's picture
Thanks
PM me if you still want one.  Smile
Old-Lumens
PCC wrote:
fdab
Thanks
Not too large with the AAA. It will be done just like the AA that Match modded (I have too). 13mm will go right in the head, after boring it out.
I have used AAA Eneloops in P7 lights for 3-4 years. In fact I still have one. They work well and they last for about 10-15 minutes DD on a P7 C bin. I don't think it will be an issue with a 1000ma driver. They take much more than they are rated at, just like the Eneloop AA batts. It won't be a long lasting light, but it should still do 1/2 hour with a 1000ma driver (depending on how efficient the driver is and the resistance in the setup).
I certainly appreciate your offer and I am constantly amazed at the knowledge here. It really is very nice to recieve these ideas and it makes me think. If there's any problem with the driver setup, I will let you know and will try the one you suggested.
Thank you
Old-Lumens
I don't think it's new, I've seen it for a long time on the KD site. I got it for an AAA Copper light I was going to make and never did, since it's the smallest I have seen that gives at least 1000ma, which is probably really 800ma at best.
Old-Lumens
I've been thinking about a little file work, like is done on knives. What about a pattern like this?
I only did one and I can change it to fluting, but I wanted some opinions before I commit the whole light to it.
file1
Shadowww
A cannabis plant? Silly
nitro
nitro's picture
Last seen: 2 years 2 months ago
my first though when i looked at it Smile
mizjif
mizjif's picture
I can't fully envision the light with more of those file designs but I actually like it so far.
Chicago X
Chicago X's picture
I prefer your fluted lights, but a green version could be the "Cypress Hill" edition.... S)
NightCrawl
@OL: Must have hidden from my eyes then.. I cant even find it on the aqualab driver list.
I like the cannabis leaf btw, gotta take you a while to make so precise little strokes..
Have you ever tried making your body-mods with an engraving tool for the dremel?
Old-Lumens
Ok, I took some time to find out if the Driver would really fit the AAA light. Here's some photos:
aaa1
Here's all the pieces.
aaa2
I bored the head with a 1/2" drill and then used my rotary tool to just take a few more thousandths out.
aaa3
This is the depth from the top edge of the head, that I bored out. 11.97mm, call it 12mm.
aaa5
The driver is 4.64mm thich.
aaa6
The modified Reflector measures 5.03mm and that only leaves me with 2.3mm for the Emitter and Star! Not a lot of room and it's going to get hot fast! I cut the fins off the reflector and used a coarse sandpaper till I cut off all of the base of the reflector. When you sand it down, you open it up to the major diameter in the bottom. Plenty big enough hole for an XM-L.
aaa7
The AAA body had a non-threaded taper on the top edge. By eliminating that taper I gained over 1mm and that lets the body screw in further. I am at 1-1/2 turns in, so it should work well. The top edge now works as the ground contact to the board. The outer ground ring on the board fits perfectly against it.
aaa8
Here's the board in place. I did have to sand with fine paper, all around the edge of it, to clean it up and remove just a few thousandths.
aaa9
Here's the reflector in place and you can see there is not a lot of room here. I think an XM-L AAA Maglite is stretching things a bit. I will be using a thin copper pad behind the star and a copper sleeve between the star and driver, so it should conduct some heat to the head itself.
 Ok, so the driver is history (toast is more appropriate), and this is now a DD light. Here's a couple photos.
zz1
zz2
I used the shell of the driver for the contact plate.
zz3
It's just a normal copper pill, like I have shown in the videos before. The reflector is OP.
xx1
100W (rated 450lumen, when did they start rating light bulbs in lumens?), for a comparison.
xx2
AAA light with 2Alkaline batteries direct drive.
xx3
White door, the only thing white in the garage. The LED is a T5 3C 5000k, from Illumination Supply.
 I'm done with this one. Next is the AA light.
Old-Lumens
No, actually it represents the rising sun. Appropriate for an XM-L AAA Maglite.
Mary-J-Wanna.......  No I don't, yes I did once (or twiceWink), I was young then, can hardly remember....Tongue Out
Old-Lumens
I tried once, trash man took it.  I don't have the touch for that. Any pressure at all and whoopee!Surprised
You make a nice unplanned design across the surface......Tongue Out Of course, I have done that with a file too. I think the trash guy knows now and he looks for lights when he comes by... For Xmas, I'm just gonna leave them out for him.Smile
NightCrawl
Until there I wasnt sure whether you were talking about weed or engraving.. Big Smile
You actually dispose lights? I thought you'd just file away whatever it takes to hide such a slip. I never did engraving, videos make it look easy..
Btw, have you thought about resoldering the emitter directly to a thicker piece of something for better heatconducting?
Old-Lumens
Considering there's only 2.3mm of room, there's not much in the way of thicker that's going to fit. The emitter base and star will be close to that.
If I can I hide the error, I do, but with a rotary tool the error is usually deep and ugly. Yes, I have heaved a light or two, but I usually hold on to all the good parts, so there's a mix of stuff just sitting around till I get tired of it and make it disappear. When I'm angry, it feels good to hit the garbage can from about 10' away. It has a nice ring to it Innocent
jacktheclipper
jacktheclipper's picture
Last seen: 5 hours 44 min ago
I have long been waiting for someone to do some filework on a bezel ring something like this
I know you have the skill .
