My new shiny came in the mail yesterday, and I got it out to play with today. Shiningbeam.com's house brand of light, more specifically the Spark.
Here's what came out of the shipping envelope:
And here's what you get out of the box and bag:
It comes with two spare o-rings, spare switch boot, belt holster, CR123 tube, lanyard, and an owner's manual. The battery was a freebie from Bryan at Shiningbeam, which just confirms his awesomeness.
Fit and finish are great. Definitely a HAIII anodizing, with no scratches, dings or uneven bits. Nice square cut threads with no burrs or chips. The threading was cut smooth, and well greased, so no grittiness or funny twists to it. The knurling is around 20 lpi, but is not very aggressive. It won't tear up a pocket, but it won't provide a positive grip in wet or muddy conditions. I prefer it not tearing my pocket, as I don't plan on crawling through any submerged trenches in the near future.
The LED is an XP-G R5 emitter, well centered on an OP reflector. The beam doesn't have any rings or artifacts, with a big hotspot and a good flood ring around it. Don't have any beam shots right now, as it's still light outside and I need to do pics out in the garage.
Some specs:
Dimensions in 2 x AA format : 15.3 CM x 2.3 CM x 2.2 CM
Weight: 2.6 oz
Dimensions in 1 x CR123A format : 8.6 CM x 2.3 CM x 2.2 CM
Weight: 1.5 oz
Working voltage range: 0.9 - 4.2V
Output: low 7 lm (23 mA), medium 95 lm (225mA), high 280 lm (740mA), strobe (550mA)
Powered by 2 AA Alkaline/NiMH batteries or 1 CR123
Runtimes: 40 min on high/ 6 hrs on medium/ 80 hrs on low
Reverse polarity protection
Forward click operating switch with momentary on
Mil-spec MIL-STD-810F
IPX-8 waterproofing
I don't have any 14500's on hand right now to do fit testing, so y'all are out of luck on that. Now for some more crappy pics:
A comparison to a JetBeam BA20
And with the short tube installed, compared to an iTP A4 (top), and a JetBeam BA10 (bottom):
This has the familiar tube feel of a 2 AA EDC flashlight. The clip is removable and reversible for bezel up or down carry, and hangs deep in the pocket. The clip is also anodized and very solid. I had a bit of trouble pulling it off the body to check the fit on the short tube, so no losing it because it decides to go SPROING at some random interval. When rigged up for the short tube, the light just about disappears into my meat hook. Very compact and very bright.
For those that care about such things, the light as shipped will not tail stand. The light does come with an alternate reverse click switch that, when installed, allows the light to tail stand. As I find that I'm not trusting enough to just leave my spiffy flashlights lying about for any mook to grab, this is a non-issue for me.
The UI is a combination type, with a rear switch for on/off activation, and a twist head for switching between modes. As mentioned before, it has a momentary click switch for on/off activation, with the option for a reverse click. Simply loosen then tighten the head to switch between modes. I found I had a bit of a problem with mode jumping when first fiddling the light. Modes would skip or I'd get two jumps with each twist of the light. I found that if I give the head a full quarter twist to loosen and tighten, this eliminated the mode jump, and presented no problems.
For $41 and change shipped, this is a great light for the money. The modes are well spaced, and once I got the hang of the change, very positive in the change. It's low is a good low, the medium provides a good working level, and the high is bright. Not eyeball melting, "Oh my god it's the Sun" bright, but bright. It's got a bit of heft to it, but not so much that it will drag your pants down. The body does lack any anti-roll flats, but installing the clip eliminates this problem.
Guessing by the construction, packaging and printing on the owner's manual, I'd say that this light was produced by Olight for Shiningbeam, but that's a guess on my part. For all I know, magical flashlight faeries leave these under a lumen tree for people to find.
I like this light a bunch. The option to switch back and forth between battery types is great, and Shiningbeam has an optional single AA tube for sale that means you could go to a common battery type for a bit of loss in brightness and run-time. This has now taken over as my EDC light, and I'll post up any problems or concerns after I carry it a bit.
