NANJG 105 8x7135 Driver
19 replies [Last post]
brted
brted's picture
Last seen: 24 min 44 sec ago
Title: ★★★★★
I got my NANJG 106 (could be 105; it's hard to read) on Friday with my XM-L drop-in. I had been having trouble with my MC-E drop-in so I thought I would put it in there. I ran into a few problems getting it soldered correctly and then found a short in my LED + lead, but finally got the light working. I put in a little piece of wire from the 2nd star (clockwise) to the outer ground ring to get 3 modes instead of the default 5. It works, I got a draw of 2.2A on a battery at 4.1V, so I am charging it up to see if I can get more than that (got more like 2.5A on a 4.2V battery which may be about all my DMM will read or all the battery will supply).
Anyway, Low and Medium on this one have absolutely the worst PWM I have ever seen. Hopefully I didn't mess up the LED, but it seems like it would either work fine or it wouldn't instead of somehow impacting the PWM rate. Also there doesn't seem to be any mode memory; at least on the 3 modes I have it set to now it always starts on Low, which is not how the SB version worked. Anyone else have any experience with this? If I can get my AVR equipment to work, this driver could be a good candidate for reprogramming.
Kai Domain: http://www.kaidomain.com/ProductDetails.aspx?ProductId=10995
Here is the current one that Shiningbeam is selling, but it looks different from the one I bought, which looks just like the KD one. Maybe the KD model really is 105 and this one is the 106.
Shiningbeam: http://www.shiningbeam.com/servlet/the-132/3-dsh-Mode-Regulated-Circuit-...
NANJG 106 8x7135 driver Top
NANJG 106 8x7135 driver Bottom
arenat
Last seen: 7 weeks 6 days ago
Title: ★★★
Got it yesterday also, I pulled
Got it yesterday also, I pulled four 7135 and  work perfectly , no pwm here, with the same bridge 1,4 A 420 mA 60 mA.
One was for a AK-101 to fix the crappy modes of a P10 R5 received yesterday also hoping to reach 1,4 A 3 modes.
Trying to measure with more resolution in the reading use an ampere meter with max scale 2A, big mistake, the max current was 1,1 A.
At first I tought that the heat using to unsolder the chip kill it.The second was 'unsoldered' with a cutter ,did not work also , always 1,1 A.
When the glass lens was broke the game was over...now i have a P31 R5 1,4A at least till the replacement lens arrive...Laughing
This morning I realize that with the 10A meter got 1,4A and with the 2A 1,1...
brted
brted's picture
Title: ★★★★★
I think you want to use the
I think you want to use the 10A setting because it has less resistance and will give you more accurate and consistent readings.
arenat
Title: ★★★
        Forget to say, mine
Forget to say, mine was from KD , could read 105, the memory work fine just as an AK-47, it seem the same with more 7135
"I think you want to use the 10A setting because it has less resistance and will give you more accurate and consistent readings."
I know that just did not realize how sensible at resistance are those circuits, actually an ampere meter is a volt meter which test the drop voltage trough a shunt resistor , in 2A setting is five more resistance than in 10A.
Also the regular test probes don't work, to a proper measure is need short tough wires.
My mistake was due the fact that more digits mean more resolution, in a 10A setting 438 mA is show as .43 A.
brted
brted's picture
Last seen: 24 min 45 sec ago
Title: ★★★★★
I wonder why yours is working
I wonder why yours is working differently than mine? I do think at one point that I had a short between the + and - out, so maybe I damaged the MCU.
sixty545
Last seen: 4 hours 50 min ago
Title: ★★★
Not so programmable now
Read about the new version here.
Kokopelli
Kokopelli's picture
Last seen: 5 hours 23 min ago
Title: ★★★★
Mine pulled 2.6A from 4.20V
Mine pulled 2.6A from 4.20V Black Trustfire, but my leads were too thin for such measurement. The real current may be even higher.
ezeqdb
Last seen: 20 hours 59 min ago
Title: ★★★
I found this pic in FL,
I found this pic in FL, stealed from CPF, it may be useful for someone
__________________
"no le temo a la oscuridad, la oscuridad me teme a mí"
sixty545
Title: ★★★
Yes, but there is a fault in
Yes, but there is a fault in it.
It has no purpose to cut star no.1 as it is only connected to ground (battery -). Leave it be.
Hayley
Last seen: 1 year 11 weeks ago
Title: ★★
ezeqdb,the picture you post
ezeqdb,the picture you post is more intuitive, thank you
pipopopo
Last seen: 16 weeks 5 days ago
Title: ★★
you can also leave the + on
you can also leave the + on the pcb just connect the+ straight  from the battery + (or the spring) to the led
pounder
pounder's picture
Last seen: 25 min 46 sec ago
Title: ★★★★★
how are the modules pulled to
how are the modules pulled to achieve 1.4a? can you just take whatever ones off you want? or is there specific ones? i'm guess you just desolder them?
also I have a copper slug I want to solder to the + battery connection..should I just put solder on the end of the copper then heat the other end?
still waiting on this driver to come in so appreciate any help in the install process..soldering to the led is not an issue nor is the other driver to pill soldering..just wondering about the contact spring area..
thanks
__________________
Friends don't let friends buy at DX or DiNO Diwrecked!!
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
ezeqdb
Title: ★★★
I've been all the day trying
I've been all the day trying to solder the black cable to the negative of the circuit.. any advice before I hammer it?
__________________
pounder
pounder's picture
Title: ★★★★★
ezeqdb wrote: I've been all
hmm were very easy with my solering iron..it's a 25w fine tip pencil style..what are u using? use thin style flux core solder and pre-tin the wire you are soldering..that and holding the wire with a tweezer or needle tip pliers might give you better control..
__________________
brted
brted's picture
Title: ★★★★★
Might help to put a little
Might help to put a little bend in the end of the wire. I can hardly even see what I'm doing because everything is so small. I  just keep trying until it sticks. As long as there is enough solder on the pad, you don't hardly need any additional. Maybe just a tiny bit on the iron.
ezeqdb
Title: ★★★
I'm using a cheap 40W
I'm using a cheap 40W soldering iron.
The problem was that I wasn't putting the tin on the circuit, but on the cable.. and it couldn't stick.
I finally did it, but I had some other problems, so I continue asking in this other thread :P http://budgetlightforum.cz.cc/node/990
__________________
Kokopelli
Kokopelli's picture
Title: ★★★★
I usually put some solder on
I usually put some solder on the pad, some older on the wire, and just hold the wire to the already tinned pad and with a touch of iron it binds there. There is no way I could use solder, wire and iron at the same time, apart from through hole components and PCBs.
ezeqdb
Title: ★★★
Actually I'm a noob in
Actually I'm a noob in electronics, and I'm discovering all this things now..  btw, what is exactly a pad?
__________________
Kokopelli
Kokopelli's picture
Title: ★★★★
Oh, I'm talking about the
Oh, I'm talking about the point on the PCB you need to solder your wire to.
brted
brted's picture
Title: ★★★★★
ezeqdb wrote: Actually I'm a
The little spot on the circuit board where you solder.
Comment viewing options
Select your preferred way to display the comments and click "Save settings" to activate your changes.
