I was testing run time on a light using a Trustfire Flame protected 14500 battery. I would check on it every now and then, but in about three hours when I checked the light was out. I could turn it on and it would run for a few seconds.
When I checked the voltage it was zero. I have placed it into the charger, but wonder if it will charge again or if it is ruined having discharged to zero/
I have a flame 14500 that tripped a few months ago, never been able to revive it - I've only tried my chargers, though I understand there are other ways to do it as well.
I have a Trustfire 14500 protected that reads 0.0volts. I tried putting into the charger for a short time but it still reads 0.00 volts. Note that this may be a new battery. I read somewhere (but I forget which thread) that someone had an unlikely trick to solve these types of problems.
I ordered 6 batteries from Meritline. They are LONG - 26670 but that's not the worst of it. The third battery I crammed into the charger reads 1.7volts and will not take a charge. ANY IDEAS PLEASE?
You can reset it by briefly paralleling it with a good cell.
The easiest way to do this is to sit both cells on a steel rule with small magnets negative down and touch the positive nipples quickly with a small screw driver blade.
If you have a Pilla charger press the reset button for that channel.
(I thought I already posted this but it didn't seem to take.)
Meanwhile, my smallest magnets are 10mm and too large for the 14500 negative end so I connected the negative ends holding them against some pliers (tips) and then I shorted out the positive - and MAGIC - IT WORKED! Thanks again.
