The LED's you bought are over priced for what you are getting. Richard at http://www.mtnelectronics.com/ (US), or Hank at http://intl-outdoor.com/ (China) would be way better sources. For less money you could have gotten a true copper DTP MCPCB/star (Noctigon) - worth about $2 more than the Luxdrive stars, and at 3A, probably got a 10% boost in output along with longer, higher output runtimes.
There's tons of lies, lies, lies out there. It pervades the LED flashlight advertising/sales biz now - no big online retailers can be trusted - Amazon is infested with it.
You also could have done a little better buying a SANYO GA 3500 mAh or LG MJ1 3500 mAh cell - bout the same cost and same capacity as the 3400B but less resistance, so they are able to keep a high current longer.
For the cheaper off-brand budget lights yes there are not many single-Led lights that are 1000 lumens or more. But with premium lights using premium LEDs such as XM-L2’s or XP-L emitters there are many well over 1000 lumens output. Also note that many of the larger single-LED premium lights that use emitters such as a MT-G2, XHP-70, etc are reaching 1500 ~ 2000 lumens all in stock factory form.
Hi, I'm new here and this thread is disturbing but very useful.
I bought what is supposed to be a Sipik SK68 from Gearbest with what they claim is a Cree Q5 (XR-E Q5) emitter. Inside is definitely not an XR-E but rather what seems to be a fake XP-E look-alike, based on what I have read and comparing photos. (Square insertion pads right on edge, no third wire.) Since I'm kind of inexperienced with the topic, could someone more qualified confirm my appraisal of the LED I received? (Damage to corners of PCB was already there - the workmanship of the assembly of the flashlight is pretty awful, but that's a different topic.)
See response 736 above and earlier discussion and pictures for identification.
You probably bought one of these (thirteen search results)? http://www.gearbest.com/sk68-\_gear/
And probably paid anywhere from $2.99 to $9.18 for what you got?
(the pricey one has a probably-junk charger bundled with it)
And with luck you used PayPal?
Nobody has sold a real SK68 for probably years, but every store is selling the clones/copies/imitations.
Pretty consistently they’ve had LatticeBright emitters the last few years, which early on were blue-purple-craplights but have gotten rather better since then.
If it’s a good enough cold white light and works properly, you probably bought a cheap lesson there and got value for it.
If you’re entirely new to all this, you could complain and they will likely offer you a partial refund, after the usual send-us-a-video and etc.
I buy these lights for around $2 (patience at eBay or AliExpress, they show up off and on), and replace the emitter and the driver, and maybe replace the pill, and ….
I wasn’t expecting anything amazing with the flashlight, but at the time I was not aware of the rampant fake emitter situation, and I naively assumed I would get a real Cree LED, but maybe one from an “off” batch. I bought the light with the idea of having something cheap in my car, along with an Energizer Ultimate Lithium primary installed.
The tint is a bit blue/purple but not altogether unbearable for an emergency car flashlight. I think I paid $3.77 each, and got two of them. Since I’m just beginning to consider modding etc., I figured I could try swapping in a (real) emitter on the second light. I will, of course, research that but any appropriate choice come to mind for a relatively easy and nice emitter swap?
Definitely not a Cree XR-E Q5 emitter. ( and i agree its a roughly handled copy of a old first generation XP-E. The original Sipiks and its clones are getting difficult to find with the XR-E these days, as most of the cheap ones we seem from many sellers now come with a crappy purple tint Latticebrignt led.
Howiezowie, if you wanna make a straightforwardly nice & simple mod to that flashlight, take a look at these bargainly priced emitters mounted on 16mm boards:
Cree XP-E HEW 226-Lumen 2900K LED Emitter on 16mm Aluminum Base If that max 226 lumens figure is right, that means this emitter is a Q3 bin which, for that (2850K according to official docs) tint, it should be either an 80CRI typical or an 80CRI minimum emitter. :THUMBS-UP:
The pictures they have definitely shows a ” XR-E” , so if they sent you one with a crappy LB XP-E clone its false advertising. The originals Sipiks i have that i bought 3 + years ago definitely has Cree XR-E emitters in them, and are far better built, brighter, & have a better tint than any of the knock-off clones we see now.
if its a “real” XP-E would be fine, but its difficult to find real Cree leds in anything these days in lights under 10 bucks, what we usually end up with is a horrible tint, inefficient latticebright copy.
Hey guys, I just joined today and found this thread.
I finally received an Ultrafire T6 that I ordered on eBay from a vendor that I had been assured was legit. Normally I will only order an Ultrafire product if it is from a vendor that is well known for selling authentic products as most of them are copied so much now you have about a 1 in 100 chance of getting even a decent copy.
As soon as I opened it up Latticebright, and worse they did not even try hiding it. It was printed on the star. The eBay vendor assures you that he only sells authentic products. He will wish that were a true statement before I am through.
I have already sent him a message letting him know what I have found and pretty much left the ball in his court. I am curious to see his response.
I was able to get 3 Q-5's from a Amazon vendor that was recommended to me. Products are fulfilled by Amazon out of their facilities and that seems cut down on the clones. I did order another T6 from the vendor on Amazon, it is suppose to arrive tomorrow. I guess I will find out then if it is a clone.
Great thread, I read some of the other thread lines and saw tons of great information. I am still much the novice, however I work as a technician so I catch on to things pretty quick.
I will post sometime tomorrow the outcome of the T6 arriving tomorrow.
My 2 cents: is it quite possible that the vendor sold you that torch believing he got “genuine” UltraFire lights from his supplier and has no knowledge whatsoever to distinguish between a real Cree XM-L T6 and a similar looking LatticeBright T6 clone.
So he might have also been ripped off. Also note that if a china shop or Ebay only states “LED type: T6” and the word “cree” is not even mentionend you can be sure to get a LB clone, and it would probably not even be a false statement.
Well, to be honest, neither “T6” nor “Q5” are any type of leds anyway. If they were just a tad *cough* “smarter” they could deliberately slam a typo over the “Cree” name on the ads (“Cr33”, “Creee”, …), and so they could completely lawfully rip you off. “All sales final”, LOL! :D
