I was thinking it was a problem; more a subjective thing than objective with the equipment available.
I should note that all along the planning stage I was thinking 4 x 7135’s mightbe unneeded. DBSAR is quite happy with only 2 or 3 - 7135’s on his SRK lantern project.
What’s necessary really depends on what you’re doing. I’d want more light in the OR than in my bedroom and more light for fine solder work than for cooking. For a lantern to while away the hours of a storm reading it may or may not need more. Chances are you’d be fine just sitting close enough to it.
This the the “while away the time” and not trip over stuff when the lights go out or when camping type of light. We have other assorted lights for detail work, etc. etc. Not having a super bright setting gives more of a guarantee the light will stay lit longer.
I’ve done a couple of ceiling bounce comparissons. I find they waste more light illuminating the ceiling and upper spaces. Also that doesn’t work outside. :person_facepalming:
For the heck of it I removed the heat sink and ran the light on high, maximum 1050 mA. After a half hour the metal lid where the heat sink used to be registered 22 degrees F higher than the room ambient temperature. Considering that a prior test on level 5 (525 mA) with the heat sink in place registered 20 F above ambient, I may leave the heat sink off for a cleaner look. Using the light around home and at the cabin in the mtns. I find myself usually operating on levels 1, 2 or sometimes 3. so heat is really not much of an issue.
Nice. Haven’t been in here for some time. That’s one sweet mug-o-light you built there. Lot’s of different materials that had to be machined and brought together. Congrats
Is this the first successful remote phosphor build here on BLF?
Just a memo to state that if anyone has thoughts of playing around with a remote phosphor Arrow Electronics has some of the Chromalit products in their stock.
For the month of September they have free shipping with no minimum special going on. That’s limited to the USA for the no minimum part. International has a US$50 minimum to qualify for free shipping.
I had glued up an extra block way back there at the beginning. This one has the same walnut and padauk but has red oak in place of the maple. This afternoon I couldn’t resist drilling some holes I had marked out a few days ago. I may not have sufficient time to complete Mk. II by October 31. If I do I’ll nominate only one of these to be my official entry. I hope that is okay with the letter and the spirit of the official rules that permit only one entry per person. Anyhow here is the start….
The larger hole is space to be used for two TP4056 charger boards along with a heat sink that will cool to the outside of the mug. That is the biggest plan addition / change. I have some NCR18650, 3400 mAh cells I plan on using. That will give 85% of the capacity of the 4 Samsung 30Q’s I used in the original. That will still be plenty of run time and I don’t need the high drain of the 30Q’s in either of these. I’m also planning on cutting out another 7135 and using two. From what I have seen with Mk. I this should be quite adequate for the designated purpose.
I have a mini voltmeter thanks to Lazy-R-us, which I am going to try to add the Mk.I version as a modification to the original. It would be nice to know the SOC of the cells.
Well, the MK2 version will not make it in time to be placed in the contest. So, we go with the original with a slight mod. Today I drilled one small hole, soldered two connections and placed a mini voltmeter inside.
The meter is on whenever the light is on. I did not measure the mA draw for just the meter. I meant to but forgot. So this is just a gap filler measure. The MK 2 version with the charger will also incorporate a mom-on push button to take the voltage reading. But it will have to be “just another” project to be (hopefully) completed in the next month or so.
