USB power meter/tester thread - YZXStudio, Power-Z, RDTech and more.
402 posts / 0 new
ymartin
Last seen: 5 years 1 month ago
Hi,
I've just bought the YZXstudio 1270 and I have a couple of questions.
I've bought the BT module separatly, but where can I find the small transistor and pins to be added it on the board?
I have 2 models, one is USB 2.0 and the other one USB 3.0. Is it possible to upgrade 2.0 to 3.0? If yes, how?
Thanks
Yves,
YMartin.com/meteo
dodge_911
dodge_911's picture
I’ve been messing around somewhat, thus far, I produced these :
I notice very strange things going on when playing around with QC charging…
:: YouTube ::
http://bit.ly/dodgereviewsyt
:: Discord ::
http://discord.gg/fqJEDyy
:: Join the Discord ::
we need more BLF'ers!
maukka
maukka's picture
Last seen: 3 months 1 day ago
Just got my YZXStudio 8th gen power bank. Seems quite good, when I tested it with a single Sanyo NCR18650GA.
Compared to a Miller ML102 (v9) it manages to squeeze out 11 % more energy (10.2 vs. 9.2 Wh) before shutting down. All while supplying a rock solid 5,13 volts from the usb output. I stopped measuring the ML102 after the output had dropped to 4.5 volts. Usually I consider 4,75 volts as the lower limit as per usb charging specs.
I just wired it temporarily to a 18650 holder before having 4 18650GAs spot welded to form a 4P pack.
sidecross
sidecross's picture
Last seen: 4 years 1 day ago
It has been a year since I bought I bought my then ‘new’ YZXstudio usb monitor from Frankie Tong, and since then I have not kept up with the newer products.
This new powerbank has caught my interest.
“You must have a plan, if you don’t have a plan, you will become part of someone else’s plan.” Terence McKenna
sidecross
sidecross's picture
I hope to read more about YZXStudio 8th gen power bank here or even have its own thread.
KAAYEE
Last seen: 3 years 8 months ago
The YZXStudio is now available on Amazon, just searching “YZXStudio” or visit directly:
ZY1270: http://amzla.com/qxfz1a7wnh46
ZY1266: http://amzla.com/rhm4qz1lkl6g
The user manual is in English version.
For more technical issues, just leave me the message.
d_t_a
Last seen: 8 hours 49 min ago
While searching online about YZXStudio devices, I notice there’s another model not yet referenced here: ZY1276, anyone who has this and have some first looks/reviews?
There’s also the ZL1100 load tester/protocol detector (it doesn’t have meter function? unlike the ZKE EBD-USB+ which is both a load tester and meter, but needs a PC and the software to view/control) from YZXStudio. There are a few reviews/images of the ZL1100 in the Chinese forum http://chongdiantou.com. But otherwise, similarly hard to find further info about it.
Found them in YZXStudio Taobao Store (in Chinese though, may need to use a translator…)
ZY1276: https://world.taobao.com/item/549902607690.htm (select the image to the right that shows ZY1276)
ZL1100: https://world.taobao.com/item/522642875491.htm
will34
will34's picture
Last seen: 2 days 7 hours ago
I have the new ZL1100 which is basically a more functional and accurate version of the ZL1000, I’m still trying to figure out some functions but so far it seems to be an excellent discharger. And because it draws external power it can also be used to discharge test batteries.
Took a while to program data logging via serial port but I finally managed to do it, however I wish there was an option to set reading intervals.
Let me know if you need to know anything else about the ZL1100
dodge_911
dodge_911's picture
Fancy meetin' you here, d_t_a Big Smile
I did a little video about the ZL1100 a while ago, use it quite a lot in cabletests on my channel.
Same offer as above, ask away Smile
I'm pondering the ZY1276, but it doesn't really do anything that I can't already do with my collection of YZXStudio stuff...
:: YouTube ::
:: Discord ::
KAAYEE
YZXStudio ZL1100, ZY1266, ZY1270, ZY1271, ZY1273 and ZY1276 are available on Amazon.(not all for prime shipping yet.) Search YZXStudio or KAAYEE on Amazon.com search box, then you’ll see them.
Have also done the user manual for ZL1100 here in PDF version: kaayee.com/download/
Cheers.
will34
will34's picture
dodge_911 wrote:
about the ZL1100 a while ago, use it quite a lot in cabletests on my channel. Same offer as above, ask away Smile
I’m pondering the ZY1276, but it doesn’t really do anything that I can’t already do with my collection of YZXStudio stuff…
Hi there dodge, Have you managed to set up the USB serial data logging? Do you know how to lower the data refresh rate like in the YZ1270 when logging via bluetooth serial?
Now I’m data logging at full speed at about 11 readings per second which is an insane amount if I were to do a 12-hour discharge test Big Smile
dodge_911
dodge_911's picture
will34 wrote:
Hi there dodge, Have you managed to set up the USB serial data logging? Do you know how to lower the data refresh rate like in the YZ1270 when logging via bluetooth serial? Now I'm data logging at full speed at about 11 readings per second which is an insane amount if I were to do a 12-hour discharge test :D
Nope, I'm afraid I don't use that particular feature of it.
I've got 4 EBD-USB' for that and I was getting tired of messing around with Excel for my graphs.
I need them timelapsed nowadays, for the videos, so that's why I use the EBD-USB's instead.
But I believe our buddy maukka knows a bit more about the USB serial data logging.
KAAYEE wrote:
YZXStudio ZL1100, ZY1266, ZY1270(Updated version 3.3), ZY1271, ZY1273 and ZY1276 are available on Amazon.(not all for prime shipping yet.) Search YZXStudio or KAAYEE on Amazon.com search box, then you'll see them. Have also done the user manual for ZL1100 here in PDF version: kaayee.com/download/ Cheers.
Hey! If you're gonna spam, at least spam some nice coupons along, dammit!
:: YouTube ::
:: Discord ::
KAAYEE
Hi Dodge, have no intention to spam on this. Just wanna give more buying options on Amazon. Moreover, we have customized the Bluetooth Backcover for ZY1270 and provide it on Amazon, which has mentioned by will34. And also made a serial upload instruction for the ZY1270. Here is the link ZY1270 Serial Upload Instruction
Regarding to the coupon, please use this 10% OFF code: YZXMETER on Amazon.com in KAAYEE store. Thanks.
dodge_911
dodge_911's picture
KAAYEE wrote:
Hi Dodge, have no intention to spam on this. Just wanna give more buying options on Amazon. Moreover, we have customized the Bluetooth Backcover for ZY1270 and provide it on Amazon, which has mentioned by will34. And also made a serial upload instruction for the ZY1270. Here is the link "ZY1270 Serial Upload Instruction":http://www.kaayee.com/wp-content/uploads/2017/03/Serial-Upload.pdf Regarding to the coupon, please use this 10% OFF code: YZXMETER on Amazon.com in KAAYEE store. Thanks.
Thanks for the coupon Smile If I hadn't said anything, we wouldn't have gotten that coupon Big Smile
:: YouTube ::
:: Discord ::
d_t_a
Dodge_911, nice to meet you here. Didn’t know you’re here. Am new here. =)
Anyway, just noticed your signature has links to data with cable resistances. I’d like to know the procedure you use to measure them (probably have to move to another message thread — I actually started a message / question about that in another thread here a few days ago).
I have some of the cables you mentioned — like the short flat micro-usb cable that came with the Mi 20000mAh powerbank and also the TronSmart 1.8m micro-usb cable; can probably make some comparisons by following your procedure (I only have a very few basic equipment though, so might not be able to actually replicate what you did).
Kaayee, I’m wondering if the other models, eg. the newer ZY1276, also support the Bluetooth module? If so, how is the module ‘installed’ to the ZY1276? (Unfortunately, I’m from a different part of the world than most people here, I guess… So Amazon isn’t exactly available to me, or if Amazon does ship to my location, the shipping cost will likely be more than the cost of the item itself. But the YZXStudio items has gotten my interest, but haven’t actually bought any yet..)
HKJ
HKJ's picture
Last seen: 2 hours 52 min ago
I will suggest you check my 1270 review:
1270 with Bluetooth: http://lygte-info.dk/review/usbMeter%20YZXStudio%20ZY1270%20UK.html
There you can see how the Bluetooth module is installed and I will be surprised it the 1276 is missing that interface.
angerdan
angerdan's picture
Last seen: 23 hours 42 min ago
Hello HKJ, it seems there’s a new USB Type-C voltmeter from YZXstudio:
www.ebay.de/itm/YZXstudio-ZY12PD-USB-PD-PD2-0-ecoy-type-c-poller-fast-charge-trigger-detector-/122604161897
HKJ
HKJ's picture
angerdan wrote:
Hello HKJ, it seems there’s a new USB Type-C voltmeter from YZXstudio: www.ebay.de/itm/YZXstudio-ZY12PD-USB-PD-PD2-0-ecoy-type-c-poller-fast-charge-trigger-detector-/122604161897
It do not look like voltmeter is the main function, but before I can play/test that I need a real USB-C power supply.
angerdan
angerdan's picture
Who knows the best shop to buy from europe?
amazon.com does not ship KAAYEE items to Germany.
dodge_911
dodge_911's picture
d_t_a wrote:
Dodge_911, nice to meet you here. Didn't know you're here. Am new here. =) Anyway, just noticed your signature has links to data with cable resistances. I'd like to know the procedure you use to measure them (probably have to move to another message thread -- I actually started a message / question about that in another thread here a few days ago). I have some of the cables you mentioned -- like the short flat micro-usb cable that came with the Mi 20000mAh powerbank and also the TronSmart 1.8m micro-usb cable; can probably make some comparisons by following your procedure (I only have a very few basic equipment though, so might not be able to actually replicate what you did).
I'm also still kind of new here Smile But, check out the first lightning cable test videos on my YouTube channel, that shows you one way you can measure voltage drop and calculate the resistance without YZXStudio meters.
Check the thread you started for more info.
There's probably more and better ways, but I don't know those Smile
:: YouTube ::
:: Discord ::
KAAYEE
The ZY1276 also supports the bluetooth, but need some DIY job. Will make a short video for this later.
KAAYEE
The latest firmware(Aug. 2017 update) for ZY127x and ZL1100 are all available on kaayee.com/download for downloading. Cheers.
maukka
maukka's picture
Many thanks KAAYEE!
After google translating the readme.txt I suppose the ZL1100-V100N00-170828.hex is for the old and the ZL1100-V100P00-170828.hex for the new version.
Can the version of the ZL1100 be determined by looking at the PCB or just trying to hold down OK when powering up the meter? Mine says ZL1100 V10 and doesn’t do anything when pressing OK while powering it up. And it doesn’t have the PD trigger as far as I know.
Could you please point out where exactly the short circuit should be made and clarify the updating process?
“Old version of ZL1100: short-circuit power supply next to the two circular pad, then the power Micro port connected to the computer.”
KAAYEE
Hi Maukka,
You’re right that the ZL1100V100N00 is for old version and ZL1100-V100P00 is for New version.
I’ve updated the Readme doc to English version for easier way of understanding. You could re-download the ZIP file.
For quick way, I paste it below:
The way to confirm the version of ZL1100 USB Load.
1. Put the USB Load on the table with fan attached towards the table and display screen upward.
2. If the Type C port is to the left of the USB plug, it’s the old version.
3. If the Type C port is to the right of the USB plug, it’s new version.
For the Old Version ZL1100, please use the firmware of: ZL1100-V100N00-170828.hex
The way to flash the firmware:
1. Please short circuit the two round shape soldering pads that close to the power in Micro USB port of the ZL1100.
2. Find a charging cable with Micro USB plug. Connect the USB end to PC/Laptop, and the Micro USB end to the power in Micro USB port on the ZL1100.
3. The ZL1100 will boot to flashing mode with the display screen black out.
4. Run the flashing software to flash the firmware.
For the New Version ZL1100, please use ZL1100-V100P00-170828.hex firmware.
1. Press and hold the OK button.
Hope this helps.
Dennis Z.
KAAYEE Tech
maukka
maukka's picture
Seems I have the old model as I suspected. Starting the ZL1100 in firmware upgrade mode works (screen is blank), but the updater (STM32…exe) is in Chinese. It does recognize the COM8 port, but what baud rate and other settings should I use? Just pressing FLASH does nothing.
KAAYEE
The last button in the right is “Start Flahsing”
The one you chose in the pic is “Read the Flash File”.
Will double check with the engineer to get the English software.
maukka
maukka's picture
Thanks, that worked!
The new interface is uglier than the beta versions though Smile
will34
will34's picture
Maukka, does the new FW add any new function other than re-arranged menu?
maukka
maukka's picture
Here’s a google translate of the changelog Wink
Quote:
1.00-00-170828 Significant software upgrade optimization, interface modification, increase the PD hardware communication IC support, increase the picture curve function, cancel the VOOC-DASH trigger, increase the SCP trigger, the official version of the first edition.
Other than a new voltage/current graphing mode, which seems useless, I don’t see any added features. Also, you need to recalibrate your meter after flashing. At least if you loaded factory defaults before flashing.
angerdan
angerdan's picture
Can someone psot pictures to compare the new with the old interface?
