I’ll definitely be buying some. Next project QX7Q Photon Cannon.
It is like building your own XHPxx
And one can mix different tints.
can someone please explain to me what is Thermoelectric separation and Direct thermal path?
ImA4Wheelr, as far as I can see on the different board pics, I see a proper top copper layer layout for the 6 & 12V versions; that is not the case for the 3V one, which looks the same as a 6V. In a 3V baseplate the central strip interconnecting all of the leds' inner leads should be one (maybe the negative) pole, whereas the other pole (maybe the positive) should have tracks embracing both sides.
Definitively fishy yet, as I said, lots of eBay vendors know @#$% about the real product, maybe the real vendor hires a handful of employees with multiple eBay accounts (in order to flood/monopolize the search engine) and gives them generic pre-designed item ads; they do nothing more than telling daddy “send this or that to Joe/Jane Blowsgoats” and answer clients' questions the best they are able…
Bruno28, led baseplates usually are Metal Core Printed Circuit Boards, which means they need a dielectric layer to isolate the core from the track layout, and this dielectric's thermal conductivity (thermal goo class ±) is a bottleneck with regards to maximizing heat transfer from the led die. In Direct Thermal Path boards the dielectric is nonexistant where the led's thermal pad goes, so solder goes in there for at least a twentyfold heat transfer ability improvement on that layer surface.
Cheers ^:)
Original post date: Mon, 09/05/2016 - 12:45. Information added; grammar fix.
Thanks for explaining
Looked it up and found this image, hopefully helps someone that didn’t know like i didn’t.
This seller has some very low prices on Cree LEDs. Makes you wonder though…
Been browsing the store and Yes I am wondering. They carry some crazy SHtuff and stupid low prices. They need reflectors to match the odd stuff.
Even if the pics are Genuine Cree, what are you going to get?
Want XP-G2 neutral on 12mm but I am hesitating on the click.
Think I am going to stick with Simon on these.
I see what you mean. Weird how the 3V and 6V have the same scratches (underneath the solder resist). I ordered some of each last night. I’ll report back when they arrive.
I´ve bought 20 x 3V bases and 2 x 6V boards with CW XP-G2`s on it. I will report when they are good ones.
Robert
CRX already has that image in his LEDs & other stuff thread. It’s stickied and chock full of similar good info. Not a bad place to spend time learning.
Received my order of 3v, 6v, & 12v 4-up XP and a XHP70 bases. They look great and are DTP. So the OP’s suspicion is correct. Thermal pad is nice and close to the top surface. Wondering if the traces are thin. They appear to be so, but the solder resist is thick and may be creating the illusion of thinness.
Oh, the 3v is indeed 3v and the 12v is 12v. Appears to be a pretty good deal.
Sounds good. Have any plans for them?
Reeaally cool! :CROWN:
Trace thickness matters, but also its width.
Is the 3V board layout as I presumed? Pics?
Regards,
Salvador ^:)
It’s sold so I’m not sure! But The beam was similar to XHP70
Not yet. One of the vendors has a bunch of 4 up glass optics that are cheap that might potentially work. Need to ask them about the spacing on the emitter end. Forgot which one it is. I mentioned them earlier above somewhere. Otherwise, the single big reflector like shown above by 3Tronics looks promising.
EDIT: Guess I didn’t mention the vendor in this thread. It was Kaidomain, but looking again at their optics, none appear to be a match for these boards. Maybe I will try to splice 4 individual optics together.
Reeaally cool!
Regards,
Salvador :partying_face:
Yes, it is. Negative on the 4 inside pads and Positive on the outside pads.
I’ll try to snap a few photos tonight in a light that will hopefully reveal the traces.
I expect these 4-ups in a reflector would have not so good throw. Half the area of the reflector will just be reflecting the spaces between the dies. It is an easy way to get a lot of power in a small space though.
^ Bet you're right. Will be interesting to see if these 4-ups can be used for more than just big emitter reflectors.
I took a couple quick pictures last night before hitting the sack. Looking at them now, I need to run a straight edge across the top of them with a light behind them to see how much lower the thermal pads is lower than the electrical pads. My impressing looking at them directly was that they are close enough. But the first picture has me wanting to make sure. Threw in a Noctigon and SinkPAD for comparative purposes.
If you cut a reflector into quadrants and positioned each quadrant so its focus was at its respective LED, all the reflector area would be correctly utilized and you would have good throw. It would sort of be like making your own quad reflector, sort of like the TM16GT reflector. Of course, this would not be an easy project, but it would be an effective way to make a high output thrower like the TM16GT. On the other hand, there are probably large quad reflectors already available that could have similar performance.
