My Liitokala with a solder blob on one of them have a good fit.
Keeppower 5200 protected (the new short ones) are also good.
The tailspring of my L6 has a lenght of almost 14 mm and is quite solid.
They work just fine in my L6.
Matter of fact, I have experienced zero problems using the LiitoKala 26650’s in any of my L6’s.
In fact I have one pair that works in series without any “fix”.
I use THIS with the others. Although a solder blob, magnet, or some other “fix” will also work just fine also. For my purpose though, the Jaxman Series Connector is about as simple as it gets and works just fine.
The LiitoKala cells fit fine in my L6. I used a small magnet to make better contact between the cells. Though I wouldn’t recommend the magnet without adhering it to the positive end of one of the cells.
Mine are 14mm also, substantial, as well as solid.
Personally, there would be no reason to replace any of the tail springs in my L6’s.
So would you guys recommend saving some money and just going with these Liitokala over the protected Keeppowers?
What spring do you recommend?
There is no big difference with original driver, but with FET driver the Keeppower deliver about 9 Amperes, the Liitokala almost 12 Amperes.
They fit my L6 very nice with a connecting magnet.
I personally am totally pleased with the LiitoKala’s. All 12 of mine test out above the stated 5000 mAh. Price is right. They work 100% reliably in the L6. What more could one ask for???
And as for the tail spring, if I were you I would not rush right out and change it till you try yours out. I have three L6’s and it would be absolutely useless to change the tail springs in any of the three.
Hope this helps……………
Will do. I think perhaps an earlier version may have had weaker springs Mitko is referring to. Perhaps Simon has already addressed the issue. Thanks.
The Jaxman store constantly delists and relists their items. I noticed their 219Bs vanishing and reappearing four or five times already in half a year.
On the other hand, there is nothing arcane in this thingy. Making a spacer is trivial anyway.
I went ahead and ordered 4 of these last night. Looking forward to trying them out with the L6 when it gets here.
I received two of them,charged with a Liito Kala 500,and put in a Cometa and a Manker U21. I measured the intensity of their light,and I found 164000cd from the Cometa,(159000cd with a Keeppower black 26650),and 121000cd from the Manker,(114000cd,with the same Keeppower battery).
Measured at 4.8m distance.
Edit.
I love Cometa.It shines…
My Manker U21 does 240 kcd, and a 2nd U21 I modded for a fellow BLFer does 253 kcd and over 1700 lumens, all on LK 5000 cells.
I feel the LK 5000 is the best cell on the planet right now, better than the best 18650's and better than all the other 26650's I have/tested. Even if it's close to an EFEST 4200 IMR, or the old Powerizer 26650, the higher capacity of the LK means it will maintain high amps for longer.
Imagine if the LK5000 was the full length of most other 26650, more capacity and current capability.
Those are impressive numbers for a U21, those are with the new W2 XP-L’s correct?
I just wish they were in something warmer then 1A, I find that on throwers in particular a warmer tint is “visible” further then a cooler tint, even if it is brighter. My S70 vs L6 being a perfect example.
+1, Yes & Amen!!! :+1: … I totally agree on all counts.
My LiitoKala’s stand tall above any of the several brands of 26650’s I have, and really extremely tall to a couple of the “brands”.
Can you please tell me what changes you have done to the U21,so as to bring it to 240Kcd?I have a friend here in Greece,who could possibly do something about.
Sorry, should do a full mod thread on it. I piggybacked in a 17 mm FET+1 driver, using the SIR800DP FET. 20 AWG LED wires, 20 AWG bypass on the driver spring, and I believe 22 AWG wire bypass on the tailcap spring - no need to remove the spring/PCB from the tailcap - easy enough to do in place.
Then on the LED side, the stock MCPCB is true DTP and nice big 28mm size. So I removed the stock XHP35 from it, replaced with a XPL V6 0D (XPL W2 1A on the other), then dedomed it. For both dedomes I used ZEP Aerosolve II. The V6 0D is a nasty dedome - doesn't come off cleanly, but the W2 1A dedomed easy. Could use gas or heat, whatever you prefer.
So, between the FET+1 driver and the dedomed XPL V6/W2, you got all the makings for some great throw'n for a Manker U21. It's all a shame of course because you are throwing away some expensive parts, but hey - do you want the most out of it or not?
More details:
Result:
Wired up to the harness for the switch, grnd, and RED LED control:
Used a 5.6K resistor for the RED LED - seemed to work out well.
Full photo albums for both U21's: photobucket MankerU21-LJ and mine: photobucket MankerU21 - TomE
Thank you very much Tom E.
You know I’m coming around Tom so you can explain all that to me in English.
