I like the C8 better, much better throw and thicker body parts, but the design can look outdated for some. I wish they could release a new version of the C8 with a redesigned bezel.
Fantastic work. I really want to build one of these.
A OSH Park link, and a link to a compatible 18350 tube would be much appreciated.
The driver I used works fine, but the OTC is in the way of getting the programming clip on the mcu. So I’ll edit that and post the new link maybe tonight or tomorrow.
The 18350 tube I ordered is this one, the “eagle eyes” option. It just came yesterday so I’ll try it tonight. Don’t forget to order the O-rings too though, they aren’t included. I forgot to do so but I think I have some that will work.
thx for your answer.
Yeah, it would probably be sufficient. But if not….
If i read your posts correctly, you built your driver yourself? Are there no compatible drivers floating around somewhere on the web like they are in simons store?
Has HJK opined on the charger used in the light?
Or anyone else done the equivalent look at it?
Wondering, as always, how muggle-friendly this might be.
HKJ can’t test everything, I don’t think this is on his radar at all.
I’ve tested it using a USB meter and mine terminates at 4.19v, current flow stops at that point or at least drops below 1ma. The light turns green a little early though, around 4.17v.
I’m also very curious whether 18350 tube works…please let us know once you test it!
I thought I had read that the Convoy S2+ short tube fits. Or is that only for the non-charging X2?
Ok, 18350 Tubes:
I have a blue tube sold by Banggood (US warehouse) for the S2+ and it fits and works perfectly on the X2R and the S2+.
I have a second blue tube, also sold by Banggood (CN warehouse) that also works on the S2+ but does not even thread into the X2R.
I have a black S2+ tube directly from Simon, it also does not thread into the X2R.
I now also have a black tube sold by Banggood (CN) as “Eagle eyes 18350” that I linked earlier in this thread. It threads in to the X2R perfectly but does not work correctly. I believe one end is not long enough to reach the contact shelf in the head. Also, the threads on this one are very very shallow, as in the ridges themselves are about half the height of those on the Convoy tubes.
pilotdog68, thank you very much for checking!
So actually it could be a roulette to buy proper tube…that’s a pity.
Yeah, it is a pity. Maybe we could convince EE themselves to make an 18350 tube. I’m sure it depends how much interest there is.
I won’t be playing roulette anymore myself though. I now have 4 18350 tubes and only 1 18350 battery. I wanted it mostly for the novelty, I don’t think I’d ever actually use it in short form.
I have more 18350 batteries than 18650. The 18350 format is much nicer to me because I don’t need long runtime.
With 18350 tube it would be one of the smallest tube flashlights with built-in charging, and probably the cheapest one. Perfect for a gift.
You’re right there. I personally just prefer the slimmer 14500 for a small size.
In any case I have messaged EE and told them there would be a lot of interest if they would make an 18350 tube themselves.
Is there a simple mod to get more amps with the stock driver?
Oh BTW here’s my mod if anyone wants to do a off-the-shelf driver swap.
I think chip stacking is possible, however these are not the common 350mA 7135 chips, they are much smaller.
Ok, I have the X2R board updated to be as close as possible to perfect (only a week late). If you order from Oshpark, be sure to get the thinner 0.8mm size. The large pad on the bottom is where the MicroUSB connector is on the charger board. You want to carefully solder them together for least resistance.
Here she is:
Parts list:
*all minor parts are 0805 sized
All values are pretty standard for BLF drivers
R1: 19.1k
R2: 4.7k
R3: 4.7ohm
C1: 10uf
OTC: 1uf
D1: Reverse-polarity Schottkey diode
FET: LFPAK33 sized, I used NXP PSMN2R4-30MLDX
Attiny13 or Attiny25 sized pads for the MCU.
Ordered. Thank you very much.
Hello pilotdog68,
Does the charger board still cut off power to the flashlight with the new driver while charging? or will it need to stay in ML mode during charging? Or did you add an off mode to the firmware?
Hey Guys,
Newbie here.
So i’ve seen this thread and instantly ordered an X2R, can’t what to do this mod myself.
So Oshspark seems to be some kind of platform where you can buy pcbs designed and shared by other people…cool didn’t knew that. Pilotgog ( ) was so kind to share the components….so far so good, but what about the controller? Don’t i need some kind of firmware to run that driver?
Please help me out
Awesome project, i just had crappy china-lights until now and even they were amazingly bright though of poor build quality.
Thanks guys
Yes, you’ll need to program the controller. Here i a guide for the Attiny13a. You will need just a minor change to flash the Attiny25 that you want for this build.
This is one of the better guides here on BLF, though it has been discussed many places: Guide: how to flash ATtiny13a based drivers (NANJG, QLITE, etc.) with custom firmware
Welcome!
