I am doing my (hopefully) last test run now and then I can start on the real test. The test will take a lot of time and I plan on publishing each battery when done.
The Flame TrustFire is not done yet, the cell I have been testing with is a year old, I have some new one lying around and they will be tested later on. They might even be the first cells tested, but that depends on when all the other cells arrives.
I have ordered RediLast 2600, 2900 and 3100.
Callies does only have 3100 and some 2250 high current cells, not 2900 cells.
What are you thinking on with "higher current TrustFire"?
And are the ebay cells from the intl-outdoor shop (They are in the mail).
A new batterie is in town - Spark built a protected 2600mAh (Sanyo inside) and presented now on their homepage. Maybe it is a good product for the test. Perhaps Spark offers you 1-2 free batteries for the test?
Which cells from intl-outdoor.com are you going to test? I just looked on their page and they have some very interesting cells there. I would love to see a test of all the Panasonic 18650 cells and both of the 26650 cells from MNKE and Kingkong.
The number of mosfet's does not have to be a significant factor, you can get mosfet's in many qualities and one good mosfet can be better than two cheaper mosfet's.
So true but what quality do you think your going to get for $1.99 usd installed with wrapper, label and one mosfet, including some ones time to weld it and put it all together ?
Like i said im pritty unlucky but it would be nice if more people could test these protected ones with discharges higher then 1 amp.
Mine took 16 days to get here to Australia, so yours should be there any day now to test and im sure they will be fine.
Must have thousands of the critters in various ESC 's and they get a good hammering in electric powered aircraft up to 12s li-po and if they are naff they zap real quick and melt plastic nicely.
As for me I would like to see something on these, might score some to checkout today after a BLF search.
I saw that link yesterday and has been thinking about including that cell.
Next "problem" is prioritize the tests, in one to two weeks I expect to have a large pile of LiIon cells. At the current time I only have a few (TrustFire and UltraFires) and Callies that is testing at the moment (The intl-outdoor will be tested when I receive it).
I expect to be running the test equipment continuous for the next few months, producing one to two test/reviews each week.
Thanks for the good and hard work! One thing to note is that in flashlights, unless you are in sub-zero conditions and at least a 5kph breeze, is that the cells would be somewhat warm. ie from both the discharge as well as heat generated by the light being switched on continuously. It is winter now, and if your house is at 10 deg C, it might not be a good indicator. Lots of people live near the equator too.
But i don't think Denmark is that cold, so if the house is heated i guess it's ok. Maybe place the cell on the charger (warm), probe it with a IR thermometer first?
It's 28.9 deg C in my house right now, and that is considered quite cooling. I switch on the air-conditioning usually after i bathe....and keep it at 26 deg C (24 deg C at first to cool my body). At nearly 30 cents per kWh it is not cheap!
The test will be at 25 to 28 deg. C, that is my usual indoor temperature.
Outdoor we are just about down to freezing temperatures during the night, later in the winter it might go down to -10 deg. C or lower, but probably only for a short time.
The Li-ions cells will no perform that good at 0 Celsius or 10 Celsius. They will improve in capacity if they are discharged at 40 Celsius or even higher. That is all manufactures say in their official graphs.
HKJ, have you though of test at -10C, 0C, 25C and 40-50C ambient temperature to see how the official ratings do ?
Not really, I do not have any equipment to easy do that. I could probably do a test in the fridge and the freezer or even the oven at low setting. This could be fun trying on a single cell, but it is not something I will be doing on all cells!
Anyway, I do not have time for it just now, most of my good equipment will be tied up on this big LiIon test for some time, but remind my again when the LiIon test is about finished.
You guys have all the fun with all that cold weather.
One guy from Finland said he wants to relocated to Singapore though....he loves warm weather. I told him it's fxxxing humid here, but he said that beats below -10 deg for a good part of the year.
My wife loves snow. Think we'll be visiting Seoul sometimes in Feb (only time when we'll be free). Second time we'll be there. Japan is quite "discounted" now in addition to Thailand, but general spending is still expensive in Japan, no make that !@#$!%$ expensive.
