Yep XML T6 clone. Its a shame companies can get real Crees so cheap so why bother!
I have not seen this kind of emmiters (take a look at picture with reflector), may be XML2 clone.
Weird picture of that led, it may even be a render, not a real picture and be XM-L2 after all…
Well during re-assembly of the new sk98 that arrived today I snapped an O ring and nothing at all to fit. Headed out to Walmart, they are open all night and they gotta have assorted O rings... WRONG, after I explained what an O ring is and finally had to take out the light I had on me and actually show him what an O ring is, apparently that is the one thing they do not sell... Finally got back home and after looking though some other lights I found one that was probably a little better as it is just a tiny bit thicker.... So back to assembly and now the reflector will not thread. Part of that is my fault, the snap ring pliers I normally use are in my tool chest at work so I used a set that I am not as use to. It is set pretty decent now but I have to eventually get that replaced.
Best part was comparing it to the one I got from eBay that I know to be a Latticebright, seeing the difference is very simple even just zooming them both as far as they can and point them at the wall. Even my wife saw a huge difference. I will take a shot of that shortly and post it.
Here is the listings for where I purchased both.
This is the one I got today and so far to me looks the most like a real Cree UltraFire Cree XML T6 LED Zoomable Flashlight Torch Lamp 2 18650 KIT SK98 (Black)
And this is the one from eBay that I know is a Latticebright UltraFire 2200 Lumen CREE XM-L T6 LED Flashlight Torch Zoomable 18650 Charger
I will post the light difference in just a bit.
Okay I hope that this picture is a decent enough shot that you can see the difference. The light on the left is the one from eBay and for sure a Latticebright. The one on the right is the sk98 that arrived today.
It is obvious that one had a longer focus range, but I can handle that for the difference in just the light color alone. It is hard to see in the picture but the sk98 is a good deal brighter.
You judge... I would love to hear you thoughts.
Hi Terry White.
Check out this flashlight: UltraFire SK98 1*LED 3-Mode 600-Lumen Zooming LED Flashlight
Seems like the torch you got from Amazon, which you suspect has an onboard genuine XM-L.
That torch I ordered a couple years ago for a friend; heck, you can find my review of it on the page I linked (2014/04/15). It uses a genuine XM-L.
Well, glad to see you've woken up to the horrible reality of CrappiceBlight emitters: despicable colour rendering.
Cheers ^:)
Hmmm…
It looks fake to me with the grid of dots like that and no black dot in the corner…
Disheartening stuff altogether…
I have 2 XML'S 1 clone for sure but looking closer at the other now and I want a higher opinion. Either way both care coming out and new XM-L2's replacing them with much better boards. Provided I can keep the things centered. The butterfly gaskets I ordered have a smaller hole than the retaining ring. At least on this first one. Pictires below...
The run off you see on this one is my fault. It's Flux. both pics are same emitter.
This shot has bettet light and much more clear, and cleaned up some of the flux.
That one is not Cree, the die is too small.
I was pretty sure it was a clone but not 100 percent. Some I can pick out easily others I count the knowledge of you guys. Each one I learn a little more…
Thank you.
Side by side makes it much easier to see.
Im going to save that picture if it’s okay just for my own reference.
Im swaping out 2 clones right now. Utting in XM-L2’S and much better boards. Lol one of them the pill is much taller than most and the wire leads are too short to reach the noctigon. I have silicone coaed wire on the way but still probably at least 2 weeks. Think I’m going to harvest the wiring from the clones I removed. Just eally hate swapping wires on those boards they are the 8 7135’s from Mountain. That is a very tiny spot to hit.
hello, my first comment my English null (translator), well you say, Greetings
Hello, friends! I got from aliexpress two different flashlight. Seller page writes that it CREE XM-L T6. I gave him a photo of what I have received, and said it was fake diodes. The seller tried to convince me that this is the original T6. Seller has thousands of of positive feedback and honest. What should I do? How to prove to him that this is not XM-L, is not T6, and is not CREE? Or is it real T6? Write what is this diode. If you can give the link. Help me please!
Welcome to BLF!
Just take a pic from the OP here and place your led next to it.
With green arrow GENUINE CREE to th real, and with red FAKE NOT GENUINE CREE BUT SOMETHING ELSE
Make screnshot of the product page point red arrow to secs stating XML T6 and write in red ADVERTISEMENT SAYS CREE XML, Received produt does not have it
The word “CREE” is the only word you can argue for. “XM-L” and “T6” do not necessarily mean that the LED is CREE branded.
It’s clear, frend. But understand, I say to the seller, it is not Cree XM-L. But the seller said to me that it is a real T6 but with small crystals. (Although sales page he is clearly written: Cree XM-L T6 Yellow) What do i do? How can I prove to him?
Sad state of affairs indeed!
My last batch of 5 Ultrafires from DX are all fake with bad color and brightness.
Has anyone determined some safe sources of genuine Cree drop ins — that still qualify as “budget lights” ?
Thank you.
Upton Sinclair — ‘It is difficult to get a man to understand something, when his salary depends on his not understanding it.’
Face it, they either don’t know or don’t care what they’re selling — unless you make it their problem.
Posting here doesn’t affect this sort of seller at all.
You need to complain to PayPal or your credit card company, convince them, and get a refund
EDIT: or, if it was cheap enough and good enough to be a host, fix it up right, of course. We do that a lot.
If something looks too cheap to believe, it probably is.
Has anyone determined some safe sources of genuine Cree drop ins – that still qualify as “budget lights” ?
Thank you.
Steenbhg, if looking for SK98s, try this one out: UltraFire SK98 LED Flashlight (XM-L2) @FastTech
Related thread: UltraFire SK-98 XM-L2 U2 (FT's SKU4521200)
Cheers ^:)
