Long before electrically neutral thermal pad introduced, all LED designed that way. Miniaturization and higher LED wattage has change the norms. But when space is not the limitation, non thermal pad LED and non DTP board usually cheaper to produce.
Well, I donāt know what his design looks like, but I was thinking that electrically connecting the LED- to the board makes the whole thing useless for 99.99% of flashlights, because the driver regulates current on the negative side. Then āgroundingā the negative side of the LED makes the light single mode Turbo only!
ā¦so we should electrically insulate / isolate the MCPCB from the pill with a thin layer of something plus some thermal goo.
Should i make a crude drawing?
The current sense feedback is on the negative side of buck/boost drivers, to my knowledge. This is baaaad news. For the love of g0d, why have those @#$%ns chosen the cathode slug as the main heat sewage? They just weren't thinking in flashlights at all, which I can understand, but it could also have implications for āintegratedā drivers.
Of course, just an opinion. Time for BeO/diamond dielectric MCPCB's fellows.
My MCPCB is designed for prototyping purpose. It will accommodate various optics and mounts - thatās why itās big and thick without pre drilled holes. The design makes it easy for various testing, I can mill it down to circular 20mm or any shapes without risk to short any electrical traces because itās shorted anyway.
To make it electrically neutral is EASY. You just put any commercially available dielectric tape/epoxy/glue between the MCPCB and the host. The heat concentration already spread to area 95 times the cathode size, less delta T. Even if we use dielectric material with only 3W/m.K (thin layer of course) thermal conductivity would still theoritically superior than those LED with thermal pad. The cathode makes metal - metal contact through copper and solder connection, less thermal resistance than through dielectric - solder connection from the LED thermal pad base. Unless the base of those LED with thermal pad is made from material with thermal conductivity superior than copper this design would be better for high power LED. But I canāt be really sure until mr Djozz done with his back to back test.
The best test is to compare it to XHP50 with equal sized DTP board.
The package is on the way to Maukka, should be there in a week. I added extra bare NV4 emitters from each type for you. There are total 13 emitters including 3 pcs NVSL219CT R9050.
PACKING LIST
āāāāāā
NV4W144AME (6V) - sm653E1200KR70 - 1 pc
2. NV4W144ARE (12V) - sm575E1000Lv9R9050 - 1 pc
3. NV4W144AME (6V) - sm575E1000KR9050 - 1 pc
4. NV4L144ARE (12V) - sm305E900Lv9R9050 - 1 pc
5. NV4L144AME (6V) - sm305E1100KR8000 - 1 pc
6. NV4W144AME (6V) - sm653E1200KR70
soldered on VirEnce DTP MCPCB - 1 pc
7. NV4W144ARE (12V) - sm575E1000Lv9R9050
8. NV4W144AME (6V) - sm575E1000KR9050
9. NV4L144ARE (12V) - sm305E900Lv9R9050
10. NV4L144AME (6V) - sm305E1100KR8000table(table#posts).
Correct, given that emitter testing the way I do it (no automation whatsoever, which is labor intensive but also adds to the accuracy) takes several hours, and that I have a job and a family, Iām sure that I do not have the time to test all 13. But I will pick the emitters that will tell enough about the others that a complete picture can be derived.
I wish I live closer so I can bring the beers and coffee. Yes, I just need them all spectra tested by Maukka. Djozz only need to crash test any LED of his choice. As my/our gratitude to them, they can share the pre production Nichias (if Djozz havenāt kill them already ā¦. )
How does a 0,04 Ā°Cā¢cm2/W thermal resistance with 17 Watt/mā¢K thermal conductivity appeal to you?
Itās far lower than the thermal resistance between LED die - solder point
Uhmā¦
Judging by the way you say it, itās probably pretty good
Iām not familiar with those technical terms and units.
But i gather itās better than the usual āseal padsā used for power transistors etc.
I plan to buy one full reel (3500 pcs) of them for my near future project. That's why Nichia sent me several samples to test. Nichia is very strict about MOQ to me, It doesn't even let me buy 500pcs. It will be available in Q1 2017. Still waiting for my Fujipoly..... ;)
The plan is to use only the 3000K and 5700K. Yes, the 9050 is my target. If I needed lower CRI, I would go with XHP50 instead, easier on thermal design. No, itās not for an e-shop, I have residential & shop display lighting projects here. But why not? if I could get some extras from bare emitter sale online, then Iāll do it.
Still working to get less than 500 pcs though.
If you could get some in ~4500k I would grab some for sure (assuming they work good after testing). 3000k is a bit too warm for a flashlight and 5700k a bit too cool. I have come to the conclusion that 4000-5000k is my personal sweet spot.
Obviously this is only if you could get a few extras tossed into your order (I am sure others would buy as well), I do not even remotely expect you to change your planned tints.
