Correct, given that emitter testing the way I do it (no automation whatsoever, which is labor intensive but also adds to the accuracy) takes several hours, and that I have a job and a family, I’m sure that I do not have the time to test all 13. But I will pick the emitters that will tell enough about the others that a complete picture can be derived.
I wish I live closer so I can bring the beers and coffee. Yes, I just need them all spectra tested by Maukka. Djozz only need to crash test any LED of his choice. As my/our gratitude to them, they can share the pre production Nichias (if Djozz haven’t kill them already …. )
How does a 0,04 °C•cm2/W thermal resistance with 17 Watt/m•K thermal conductivity appeal to you?
It’s far lower than the thermal resistance between LED die - solder point
Uhm…
Judging by the way you say it, it’s probably pretty good
I’m not familiar with those technical terms and units.
But i gather it’s better than the usual ‘seal pads’ used for power transistors etc.
I plan to buy one full reel (3500 pcs) of them for my near future project. That's why Nichia sent me several samples to test. Nichia is very strict about MOQ to me, It doesn't even let me buy 500pcs. It will be available in Q1 2017. Still waiting for my Fujipoly..... ;)
The plan is to use only the 3000K and 5700K. Yes, the 9050 is my target. If I needed lower CRI, I would go with XHP50 instead, easier on thermal design. No, it’s not for an e-shop, I have residential & shop display lighting projects here. But why not? if I could get some extras from bare emitter sale online, then I’ll do it.
Still working to get less than 500 pcs though.
If you could get some in ~4500k I would grab some for sure (assuming they work good after testing). 3000k is a bit too warm for a flashlight and 5700k a bit too cool. I have come to the conclusion that 4000-5000k is my personal sweet spot.
Obviously this is only if you could get a few extras tossed into your order (I am sure others would buy as well), I do not even remotely expect you to change your planned tints.
If you could mix the tints a bit I am positive there would be some level of demand for some neutral tint versions with high CRI. How much only depends on the results from testing.
If Djozz could manage to keep a 12V 5700K one alive, i’d be very interested.
…actually also very interested in a 3000K one…
(but i’m probably not the only one…)
Good news guys!
I just spoke to Nichia sales person, and I can mix the CCT and voltage for my next order. Hooray
Please vote your preferred CCT and voltage in my recent poll
Sounds good! Have you asked about the 219c 90+ CRI versions that are supposed to be released now? Seems they are available up to 4500-5000k? according to the data sheet, if you can mix and match I know there are a lot of people that would like some 90+ CRI 219C’s.
No, it’s confirmed that the 219C Ra9050 only available in 3000K. If you look at the website the rest of the CCT only available in Ra8000. (corrected by Maukka). I asked my local Nichia representative
