Sure... amraspalantir http://www.aliexpress.com/wholesale?SearchText=100W+ballast&catId=0
If you don't wanna use ESCROW (actually it's safer than PP in a certain way, because the seller is not paid until you authorise ESCROW to release it, so you have the bargaining chip for any full or partial refunds. Now PP could in some rare cases be unable to suck funds from the sellers account, highly unlikely but i thought i nearly suffered that for my Lightpipe 250W purchase, which was usd 530 and he had multiple orders)
I purchased from Guangzhou COSON, as they have the 12V to 24V version. This version works with voltages from 9.5V-30V as specified on the back. The advantage is that you get slightly more power output with 24V, ballast efficiency is higher as well. The ballast would be straining, and you can hear it, if the voltage drops below 12V loaded. This is useful if you want to use an external pack next time with 2 x SLAs in series. You will never know what comes up.... i feel that paying like 20-30 bucks more is better for flexibility.
http://www.aliexpress.com/product-gs/476062132-warranty-for-14months-free-shipping-12V-24V-H3-100W-HID-XENON-KIT-wholesalers.html (I purchased it for usd 103 then, looks like it's now usd115. They are extremely fast, they posted the package via DHL the next day and i got it after 3 days after i paid.
You can see in the listing that it is taking 12.0V from a PSU and current is 8.3 amps. 99.6 watts of input power. I personally measured 98W from my SLA.
BTW if you want the most output, choose the 4300K bulb. 5000K bulb is ok if you want a pure white, definitely within 5% of the 4300K bulb.
You need to order a pair of 4300K H3 base bulb of 55W power. This would give you the smaller bulb with a shorter arc length of about 3-4mm. The 75 and 100W ones are 5-6mm, and this means less throw. However the 75/100W bulbs do give 9500-10000 bulb lumens, while the overdriven 55W can only get maybe 7000+ bulb lumens due to lowered efficiency. High powered HIDs & metal halides are very efficient relatively, more efficient than LEDs. The Philips bulbs are doing like 120 lumens per watt, and this is at the high end of the power curve, not like XM-L which reaches only about 60 lm per watt in real life in our flashlight app. (due to heat) You may notice that P60 XM-Ls often dig below 50lm/W.
The LED franternity thinks that HID is old-school and LED is overtook it esp with the XM-L. Sorry folks, in reality it's far from it. But on paper, XM-L looks good. :)
It's a big investment with all the bulbs/ballast and host. But i'd say bite the bullet if you are a throw junkie. It is WORTH IT. If you really want to get into the throw crowd and can accept the -ve of say big host and plastic construction, forget about LEDs.
Consolidated lux readings
http://www.candlepowerforums.com/vb/showthread.php?311939-Consolidated-Short-Arc-amp-HID-spotlight-Lux-readings
Short Arc (ma_sha1 short arc lux reading are from Extech EA30 lux meter)
Maxa Blaster: 100W Mercury short Arc, 9" Hi End reflector -52 Million CP
(Measured by RA @ >100 meter distance)
http://www.candlepowerforums.com/vb/...-Maxablaster!)
Moon Blaster: 120W Hi Pressure Mercury short Arc, 9" reflector -16.1 Million CP
(Measured by ma_sha1 @ 100 meter distance)
http://www.candlepowerforums.com/vb/...e-Moon-Blaster
16.7 Million CP when measured @ 10 meter distance
Mega Blaster: 120W High Pressure Mercury short Arc, 4.5" Aspheric lens-5.0 Million CP
http://www.candlepowerforums.com/vb/...t=mega+blaster
5.5 Million CP when measured @ 10 meter distance
Maxa Beam Gen II #1: 75W Xenon short Arc, 5" Hi End Reflector --2.3 Million CP
2.3 Million CP when measured @ 30 meter; 1.7 Million CP when measured @ 10 meter.
Maxa Beam Gen II, #2: 75W Xenon short Arc, 5" Hi End Reflector --3.2 Million cp
(Measured by ma_sha1 @ 200ft/61 meter distance); 2.1 Million CP when measured @ 10 meter.
Maxa Beam Gen II, #2 with Gen III lamp: 75W Xenon short Arc, UXL-75PB lamp -6.1 Million cp
(Measured by ma_sha1 @ 200ft/61 meter distance); 4.6 Million CP when measured @ 10 meter
Maxa Beam Gen II, #3 with UXL-75XE lamp: 75W Xenon short Arc,-7.1 Million cp
(Measured by echo63 @ 160 meter distance)
150W Military Xenon short Arc: 6" Hi End Reflector --0.8 Million CP
(Measured by ma_sha1 @ 100 meter distance), 1.1 Million CP when measured @ 10 meter distance.
http://www.candlepowerforums.com/vb/...duction-lights
Franken Mag short Arc: 50W UHP short Arc, 4" Nighthunter II Reflector --0.5 Million CP
(Measured by ma_sha1 @ 10 meter distance)
http://www.candlepowerforums.com/vb/...00-lux-1-meter
HID & Hi Power Halogen Spotlight True CPs for reference.
Extreme Throw Incans:
MagDaddy PAR 46 HIR: >400,000 cp, 130W, 5.75" Reflector sealed beam H7680 HIR (Measured by ma_sha1)
Platinum Thor 15 Million CP Halogen: 380,000 cp (Maxablaster host): 130W, 9" reflector (Measured by RA)
Several other 15 Million cp halogen spotlights: Non went above 400,000 CP, unknown but large reflector sizes (Measured by RA)
Thor 10 Million CP Halogen: 183,000 CP 100w, 7" reflector (measured by mtbkndad & calculated by RA)
High Power HIDs
Mozo Mega HID, 75W Mod, 6" Reflector, Philips 4300K lamp 1.7 million cps, (Measured by Ma_sha1)
Sanmak SM5200, 100W Mod, 6" reflector, 6000K bulb, ~1.25 million cps. (by 2100/12.5M/Dx meter)
Sanmak SM5200, 100W Mod, 6" reflector, 3400K bulb, ~1.35 million cps. (by 2100/12.5M/Dx meter)
Barn Burner 75W HID with stock DL50 lamp, 4.25" reflector: 750,000 cp (Measured by That Guy)
Barn Burner 75W HID with stock DL50 lamp, 4.25" reflector: 4-500,000 cp* (estimated by Flashanator based on Dec 2007 shootout)http://www.candlepowerforums.com/vb/...=199989&page=2
Mozo Mini Barn Burner mod, 75W HID , 4" reflector: 552,000 cp (Measured by ma_sha1)
Polarion Night Reaper CWSL, 50W HID 3" Reflector: 506,000 cp (Measured by 2100 @ 45 meters)
Polarion X1, 40W HID, 3" reflector: 400,000 cp (measured by mtbkndad & calculated by RA)
Regular Power HIDs (30/35W)
>5" Reflector group
...POB HID, 6" Reflector >400,000 cp , ebay 4300K lamp (measured by Petrev)
...Mozo Mega HID, 6" Reflector 430,000 cp, stock 6000K lamp (Measured by Ma_sha1)
...Mozo L35 clone in 5.75" Par 46 HIR Reflector 275,000 cp (Measured by ma_sha1)
4" Reflector Group
...Titanium Innovations L35 35W HID, 4" Reflector: 225,000 CP (Measured by selfbuilt)
...N30 HID 4" reflector, 250,000 cp (measured by mtbkndad & calculated by RA)
...Mozo L35 Clone, 35W HID, 4" reflector: 180,000 cp (Measured by ma_sha1)
3" or smaller Reflector Group
...G&P 35W HID, 3" reflector: 143,000 cp (measured by jirik_cz)
--Xeccon SSK-33 2-mode HID, 3" reflector 35W mode: 135,000 cp (Measured by ma_sha1)
--Xeccon SSK-33 2-mode HID, 3" reflector 28W mode: 96,000 cp (Measured by ma_sha1)
--MicroFire Warrior III 3" OP reflector 53,000 cp (measured by MorePower)
--MicroFire Warrior III OP-polished reflector 92,000 cp(measured by MorePower)
--MicroFire Warrior III 3" SMO reflector, 108,000 cp (measured by shinetop, 3 meters)
--6600mAH ebay HID 35W, 3" SMO reflector, 103,500 cp (measured by shinetop, 3 meters)
--Fire-Foxes 1(火狐2009), 2.6" SMO, Peeled naked bulb, 148,500 cp (measured by shinetop, 3 meters)
Low Power HIDs: 25W or less
...24W Tactical HID- 40,000 cp (measured by jirik_cz)
...24W Oracle HID, OP reflector- 45,000 cp (measured by ma_sha1)
...ledpwr's 14W DC HID maglite, peeled bulb, Anode Focus, SMO 330,000 cp.
...Ra's 10W Mini DC HID, peeled bulb, Anode Focus, SMO 250,000 cp.
