That 18K sounds like the light for me. I don’t need a compact 4x18650 light, so make it big with crazy output. Heat could be good for me though, especially this winter in a poorly insulated shop. I’d have the brightest handwarmer in town.
I have no idea man… I personally think it’s really cool that Haikelite use 80+ CRI. Seriously, what other (triple) XHP70 lights are out there with stock 80+ CRI? No Thrunite TN36-UT, no Olight X7…
that is wonderful! now, your UI is a step above, or at least better than all…err…most companies in my opinion. having turbo be memorized is a good move.
is the silver version available yet? if not, is there an eta?
what is the final lumen measurement on turbo?
Looks like a very good price point based on the listed prototype specs. If the final specs are close to those it would essentially be a meteor on steroids, with a much better UI at a much lower price.
I may have to sell a few lights to make room for this triple and the thrower….
You can press the switch again to use other modes until the light shut off at cut-off volt.
fast flash and Step-down to moonlight below 20% power is to remind people to use lower power mode and charge the battery in time. 20% can not last long on turbo or high, but can last long enough on low low, Low or middle.
