Maratac CR123 Triple Nichia & Tail Clicky
I have always really liked this little hefty chunk of copper, except that it is a twisty.
The tail end has a solid 7mm of copper to play with so…
Triple Nichia 219c emitters on Noctigon MCPCB
Copper heatsink
ARC Glass/ 10507 TIR
Nanjg 105c 3A driver
Green tritium vial
Lockout-able
Reverse clicky switch
Max – 900lm OTF
I have no idea how you did it CRX but you have and it works. Well done. :+1:
You must be approaching around 5000 mods this year come out of your mod factory. Whats up next? :slight_smile:
Cheers mate, just tryin’ to build up to my 1000 post, I don’t talk much but I do like moddin’ :laughing:
Thinking about doing the same sort of mod to a triple trustfire mini 01 next… :wink:
You will do a step by step build thread on it ok. :laughing:
Where’s the fun in that?
No no, it’s much better if you use your imaginations to f ll in the m s i ng st ps. :stuck_out_tongue:
:slight_smile: :person_facepalming:
Really nice CRX!
Thanks mate :+1:
With those gloomy pictures I have no idea how you did the switch, s I c n’t fi l n t e ga s. Which is a pity because I’m curious!
It is another great CRX mod for sure!! Keep them coming.
Slaggin’ mi pics huh? :slight_smile:
It’s one of these with one leg bent underneath and the other bent up the side of the switch, pressed into the 10mm hole i drilled. About 3mm of the switch sits inside the battery tube which i epoxied around with the copper taped contact just sitting proud. These are small forward clickies that seem to be well made.
Tanks 4 thee updat. The picture is very clear now. This is a big thumbs up shrunken down to normal size. :+1:
This is tr*l*y an ama*ing mods!
