I have to find a place to post pics. My first idea goes like this. Isolate the cathode with a vertical cut to their left. If cutting from top to bottom, stop when you hit anode trace and turn right, cutting across the two through holes and stopping above led 3.
You can mount led 1 and 3 backwards and jumper the cathode to the area north of led pad 7.
That requires reflow. With just a bit more cutting (basically continue the horizontal cut out to both edges) and two jumpers you can do it without reflow. All this could easily be accomplished with a few cuts in the trace, zero ohm resitors and/or an extra solder pad prior that would allow reconfiguration. It's really unfortunate in a light intended to be moddable.
2S isn't just about max lumens. It's about keeping say 2A per led (or whatever it can sustain) from being affected fairly quickly by voltage sag. It gives you a setup where light performance has nothing to do with the battery voltage sag/depeleting, so long as it's capable of putting out the power required. But yes, you get max lumens too, so everyobody should love it. Anyway, I didn't understand about xph35's and I should have stopped to understand what you were saying there. I will try to post a pic later.
That's probably not even the most clever way (almost the least) just first things I saw. I think can get a solution with either no jumpers, only cutting, or certainly can get one with no reversing of led's and probably still only requiring one jumper. I'll try post pics later.
Bettter yet, you can use the extra led pads for the jumper(s). It might be possible to make this fully reversible/reconfigurable just by re-configuring 0-ohm leds on thee extra pads. Splitting the wire pads gives even more options. Now it's like a game. Is there a way to cut traces so that xml's can then be configured in 4p, 2s or 4s only by jumping large led pads, and changing wire connection points, without even resoldering leds? The thermal sensors might get in the way, not quite sure how they are wired.
Oh, you can mod the MCPCB to work in series, anything CAN be done. I said it was easier to install individual stars and I still say that is the case. With stars you simply install them, line them up and glue them down. All bolt in parts with no custom work needed. Even for me I prefer bolt in whenever possible. Why makes things harder then they have to be.
Personally I would have preferred the light be setup for 4s LED’s run by 4S cells from the start (maybe 2s2p LED’s). The overwhelming majority said they wanted 4s cells and LEDs though so that is what we have at this point.
To me this all seems MUCH easier than assembling a driver (which you still have to do but...) and it's quite a bit cheaper and faster than ordering new stars. If a few cuts in traces, and existing jumper points (the extra led pads, or just add proper jumper pads) can make this reconfigurable is it really too late to push it through?
(are they heat sink pads case grounded? do they need to be avoided electrically?)
Yes, the MCPCB is DTP. Like I said it could be converted but I personally hate cutting traces, I have always had massive issues getting a clean cut that doesn’t short out.
The $4 for new stars would be well worth the cost for me but to each their own.
4p as shown, positive is always to the left (or negative if you prefer).
Can do 4p, 2s, or 4s. No cutting, only jumpers (4s requires jumpering two of the wire pads, although there is room to route a trace for a zero-ohm resistor instead for that too, but jumping the wire pads seems ok). LED's do not need to be reversed. This should work as a stock board. (I deteted the thermistors because they were in my way at the time, but this is just a concept version obviously)
I had considered this, actually had a design half made up for something like this but decided against it as people would complain that the traces were not big enough.
If Miller says he is ok with trying to change it at this point I can finish my first design and see what the Q8 guys think of it.
Either way it doesn’t effect this driver much. The goal is to design it for overkill and then work backwards for smaller versions. I figure I would like to work down to at least a 26mm and maybe get a 20mm if possible since the mtnmax is not available in that size. Although that would be limited to the tiny13 which is not a great option but thats for a later design.
What's wrong with the one above? The places where traces are narrow, it's obvious how to improve it, just didn't for the concept drawing. Random addressing is fine, but that plus laying it out for short jumpers for the most used paths without ever needing LED reversal is a bit more of a trick. I did try to keep the central pad/hole design the way it was because I didn't know the constraints. If I could put pads anywhere I want, traces get a little better yet, but I'd still do it like this basically.
Anyway, if I inspired movement on it, that's great to me.
There is nothing wrong with it, but if going for a fully customizable board, might as well go all out IMHO. I tossed together another version and posted it in the Q8 thread that allows any setup you could want using jumpers.
The issue is practicality of thorfire actually using it or any of our designs.
Ok, I felt if the board had a chance it had to be now. Done all we can on that, so back to the buck.
So I'm mostly finding power diodes with about 500mV Vf. I'll get a summary of something soon. That produces 10% resistive power loss in the diode alone for all 1S configurations, regardless of current level. I don't like that.
But I did find a couple of gems like this:
Which is really slow (and can't find just how slow) and just not meant for this. It's half tempting to put one in parallel with a faster diode though, so it can kick in when it catches up, if it ever even does though.
I think without finding a current regulated synchrounous IC though, that's just reality. We could try to parallel two diodes (or more), but it's not guaraunteed to help much since whichever takes more power, gets hotter.. lowers Vf, and takes even more power. So I'll try to round up the best of the bunch, mostly already done probably.
Keep in mind that the primary usage of this driver will be for 4S setups or 2s setups. For example if you were running 1s 3V LED’s then you would run the driver as 2s voltage. If using 2s LED’s then at 4s voltage and obviously 4s voltage for 4s LED’s.
I don’t see a reason to use 4S input to 1S output in any case. Although having the option is great naturally.
I tend to agree. There's not much reason for 4:1. 2:1 is showing about 3.4% loss for the diode, and 1:1 (close to it anyway) well I haven't run the numbers yet but it will be next to nothing, so it's not so bad.
It can turn an asynchrounous buck into a syncronous one as a drop in replacement for the diode, without support from the buck IC.
It uses a MOSFET (of our choosing) to do switching in place of the diode, but instead of being controlled by the main IC, it has a voltage sense. When there's voltage on the cathode, it closes the switch. The body diode of the MOSFET is used to cover the slight delay from sensing. This won't work for a 17mm version I guess. No room for the extra IC.
Anyway. I said before, and it's written many places, that max ripple current is at 50% duty cycle. As with many things technical that statement has to be taken in (a fairly unfair in this case) context. It turns out that's true for equal current. For equal power, the ripple as a percentage of average current is a bit worse or anyway pretty similar at high duty cycle/high output voltage compared to 2:1 operation. Most things though are easiest at high voltage output and get harder/worse at lower voltages.
I've been thinking about total voltage drop issues a little for 1:1 (now included in my tables), and adding some tweaks to the math. It seems to me on first scratch like it won't be an issue.
The input capacitor however is showing up as a very the large majority of the remaining 5% innefficiency in for near 1:1 operation. I'll double check there, but this can be useful info.
Edited commentary. I first increased the capacitance and it got better, but then I realized that's because I calculate ESR from the capacitance, frequency and dissipation factor, so maybe that's not right. Then I realized many of the bigger 0805 caps are just stacks of 2 or three smaller ones. And it seems to me two parallel caps have the same phase angle as one, so the original conclusion is right. More capacitance, less ESR. Also checking some spec sheets dissipation factor doesn't seem to vary so much across capacitance values.
Anyway, I'll see if I can find some cap or combined stack that works a little better. 5% isn't a big deal, but it's probably easy to make it 1.5% instead, which would just be a nice boast.
If we kept to a 17mm inductor then we should be able to fit that without much trouble, including the mosfet. With a 22mm it would be real tight but just might fit, although not sure if it would compromise the overall EMF interference due to cramming things closer together.
Although looking at existing buck driver designs, they cram components right next to each other with no apparent side effects, although they also put out a fraction of the current we plan to.
We could try to use the LTC4412 if nothing better presents itself in the Q8 driver setup. For the smaller setups I doubt we will need more then 10 amps of current ability so it should not be as big of a deal anyways.
I kinda figured that things would get harder as we decreased the output voltage. Circuits pretty much always handle voltage better then amps, Ideally it would be something like a 4S input to a 3S output, just enough to keep it in regulation till the batteries are depleted. but thats just not practical in the real world. That is unless you swapped the Q8 out for 4x triples and built a DIY M43 (or M34?).
Caps are 10 uF 7.5% dissipation factor.
Inductor is the 15uf one previously (lower resistance than the 22)
Diode is 0.5V Vf Mosfet numbers are a bit vague, but I think at least Rdson is about right, wouldn’t trust the switching losses much at this point though. Input voltage is 16.8, output is in multiples of 3.5 for now (I may add a correction for current, especially since it matters in 1:1). The output power at 4:1 is less because I limited it to 15A for now.
I just noticed, the 5% mode on this light is going to brighter than most pocket lights (not BLF ones). I’m pretty sure we’re going to need that PWM for moonlight and even just an indoor low.
So for a true synchronous buck the freewheel mosfet is opened late and closed early to prevent reverse current, using the body diode during the transition. But I realized for this thing that works during opening, but not closing. It's already open and it closes too late.. and I guess there should be reverse current briefly then. I don't know how ideally that thing really works. A very smart IC could predict closing based on the last cycle and only have issues then during load changes.
