ENEDED
I ordered the nichia 219c with the extension tube in stainless steel ,its my firys light i will ever have that is not and u2-1a tint or ,plv6 xplhi u21a so ….
+1. Extension tubes are also ready now.
What is the difference between the S41 with XP-G2,which I already have,and the XP-G3 of the new one?
The XP-G3 is more lightfull and has a warmer color tint. And it is a bit yellow.
Thank you.Not for me this tint.
Given that it has 4 leds, is that a reason other than heat tranfer limitations that makes it not being able to output around 2,000 lumens in turbo?
What 18350 battery is recommended for this light ?
Thanks,
Mike
Any high drain is fine. I’ve been using 700mAh Efest and Enercig with great success.
I ordered the AW 800MAH,supposedly has q 1z amp draw ,overready who. modifies surefires
Got mine today.
This is definitely a show light :slight_smile: and i love the aggressive knurling.
They do look expensive to non flashaholic and i have tested on my mates haha
Pics!!
My extension tube came into today too. Slightly over 10A reading taken from the tail with my full charged Samsung 25R!
Now I need to find a SS pocket to go with this light. Slot is about 4mm, regular SS clip from Astrolux SS or Convoy will not fit in them.
thanks for posting the pics Freeme :smiley:
Im starting to love this light more than the original version.
Look and feel expensive :smiley:
YES! That would really make this light. Looking forward to receiving mine (CREE XP-G3/G2 A6). I’ve got two of the ordinal ones and really like them. One for work (Nichia 219B) in 18350 mode & one for home/EDC (CREE XP-G2 A6) in 18650 mode. Good to hear you can notice a difference in the knurling.
Freeme, is this the XP-G3 version you’re getting this reading from?
Easy enough to disassemble this without destroying things?
Knurling is much more aggressive than previous Astrolux SS for sure.
Nichia 219. I could feel heat building up in my 2.5mm thick copper lead on turbo
It is rather easy for my samples. If you really have to disassemble one, I advise you to check with other S41S owners.
Is in post #01
Thx for the pic. How do you find it’s weight? In it’s 18350 form do you feel it should EDC well? thx for the 411!
Are there any pics of the assembled heat treated S41S using the heat treated 18650 tube?
anyone have a link for a holster?
