If you could mix the tints a bit I am positive there would be some level of demand for some neutral tint versions with high CRI. How much only depends on the results from testing.
Nichia 144A and 229A series: bigger dies, more output, 90CRI included,.......but no thermal slug :-(
If Djozz could manage to keep a 12V 5700K one alive, i’d be very interested.
…actually also very interested in a 3000K one…
(but i’m probably not the only one…)
[edit]
6V is fine too.
[/edit]
Good news guys!
I just spoke to Nichia sales person, and I can mix the CCT and voltage for my next order. Hooray
Please vote your preferred CCT and voltage in my recent poll
Sounds good! Have you asked about the 219c 90+ CRI versions that are supposed to be released now? Seems they are available up to 4500-5000k? according to the data sheet, if you can mix and match I know there are a lot of people that would like some 90+ CRI 219C’s.
Link to poll?
Sounds good! Have you asked about the 219c 90+ CRI versions that are supposed to be released now? Seems they are available up to 4500-5000k? according to the data sheet, if you can mix and match I know there are a lot of people that would like some 90+ CRI 219C’s. Link to poll?
No, it’s confirmed that the 219C Ra9050 only available in 3000K. If you look at the website the rest of the CCT only available in Ra8000. (corrected by Maukka). I asked my local Nichia representative
Texas_Ace:Sounds good! Have you asked about the 219c 90+ CRI versions that are supposed to be released now? Seems they are available up to 4500-5000k? according to the data sheet, if you can mix and match I know there are a lot of people that would like some 90+ CRI 219C’s.
Link to poll?
https://www.nichia.co.jp/specification/products/led/NVSL219C-E.pdf
This pdf states 2700, 3000, 3500, and 4000K available as 9050.
clemence: Texas_Ace:Sounds good! Have you asked about the 219c 90+ CRI versions that are supposed to be released now? Seems they are available up to 4500-5000k? according to the data sheet, if you can mix and match I know there are a lot of people that would like some 90+ CRI 219C’s.
Link to poll?
I know, asked for it many times. And the answers always negative. I just called him yesterday.
Still not ready yet. They said “maybe” next year
Oh well, it was worth a shot. Depending on price I would still be down for some 219’s as well though, I am really liking tint mixing lately and 80+ CRI tint mixed lights look quite good as well.
A little more 144A info:
- Emitting area: 4x4mm (16mm2) - same configuration as a XHP35 (with lower forward voltage)?
- Aluminium Nitride substrate (285 W/(m·K))
- Gold contacts
Distributor of the brand Nichia in Italy, *Welt Electronic* presents the new multichip series 144A. Nichia, a company of the first
magnitude in the products Mid Power and High Power, deals with the application market outdoor, street and tunnel lighting,
with a multichip Super Hight Power consists of four chips of 2 mm2, close to each other and arranged in a square: a plus optically unequaled.These are the characteristics of the series 144A: Aluminium Nitride substrate, a component that increases the efficiency and
lowers the thermal resistance; Nichia Flip - Chip technology, which eliminates the process of wire bonding as a connection between the anode and cathode, presents a critical element in less than the technologies adopted by
other manufacturers; gold electrodes, which allow not to decay in application, because it is completely free from corrosion in an
environment saturatedAlumininium nitrite looks like the way to go creating a board for mounting these.. it should be reasonably cheap to have someone make a bunch of 16 and 20mm disks... then glue two pieces of copper sheet to the top to act as electrodes. Done.
Welt Electronics sounds like one possible source.
Who's gonna request a quote for a big box of standard 16 and 20mm boards with multiple wire contact points and thick copper traces to these guys? O:)
Cheers
Original posted on: Tue, 10/11/2016 - 20:09; typo fixup.
Link to poll?
You’re right. I edited my post. Well maybe other Nichia distributors have it. I asked the Sout East Asia distributor in Singapore via Indonesian representative.
Manual Man:A little more 144A info:
- Gold contacts
Who's gonna request a quote for a big box of standard 16 and 20mm boards with multiple wire contact point and thick copper traces to these guys? O:)
Cheers
Interesting material....You go (buy) first, I'll follow
maukka:https://www.nichia.co.jp/specification/products/led/NVSL219C-E.pdf
Also the Reylight Pineapple is supposed to be 219C 4000K R9050.
GOOD NEWS!!!
I can get the 219C 4000K Ra9050. It’s available now
GOOD NEWS!!!
You mean like these?
Nichia 219CT 4000K R9050 high CRI LED It is used in the ReyLight Pineapple, and Ti LAN. I was requested by a few members to sell bare emitters. 4$/pc, free shipping with tracking number, paypal is 395090663@qq.com Order 10 pcs or more, 3$/pc. If possible, pls send it as gift and pm me your shipping address. Some trits: [image] 1.5*6mm trit, 6$/pc white-18pcs pink-20pcs green-20pcs ice blue-25pcs A few old drivers available. 3$/pc (2K HZ PWM) 0.9~4.2V input Reverse protection 14.6…
I couldn’t find the CRI of them for certain, i think it’s 92 (?)
GOOD NEWS!!!
Very nice, if you can get these for a good price I would get a few, I do prefer 4500k myself so it would keep me from stocking up.
I can’t wait to see the test results.
When I’m back home I can do a test on the 219C 3000K R9050 that clemence has sent. I may also wait for the 4000K R9050 that will come from Rey shortly. But not both, that seems not meaningful because the output, current and voltage behaviour will be similar.
And for that matter the test will not differ much from the 5000K 83 CRI version that I tested last year I guess, same voltage curve and same output curve but shifted a bit vertically because the output bins of the high CRI versions are lower.
clemence:GOOD NEWS!!!
No 4500K available based on the data sheet. The 9050 only available from 2700K-4000K, the rest is Ra8000 max.
The sell price is approximately the same as the other sellers here, also quantity sensitive.
I can’t beat China based seller since the courier services are extremely cheap there. For small order quantity they’re your best bet.
- Clemence -
