Micro-Textured Lens for Solarforce Flashlights
105 posts / 0 new
pflexpro
Last seen: 2 days 1 hour ago
I’m at the age where I don’t get excited too easily, but sometimes, something really small can do it for me.
I think beam tint and beam quality are just as important as blinding output. I developed the Smooth-Hybrid reflector just for that reason.
I really like a smooth beam but don’t want to resort to an orange peel reflector…it seem to ‘mush up’ the beam too much…especially in a small P60 sized reflector.
I now have a new lens that I’m calling Micro-Texture that has a really nice effect on the beam pattern.
A normal P60 orange peel reflector has about 200 or 300 good sized irregularities to coarsely diffuse the beam…the Micro-Textured lens has about 10,000.
When telling someone about this lens, two questions come up…how much does it reduce the output? and how much does it reduce the throw?.
Since it’s has a textured surface and not a frosted surface…it doesn’t reduce the output…because it’s AR, it increases the output over the stock lens -the output matches that of my clear AR lens.
It does reduce the throw, but only by about 2%… much less than an orange peel reflector would.
The Micro-Textured lens tends to make more visible difference if there are artifacts are in the beam…the worse beams will see the most improvement.
Even a orange peel reflector will have an improved beam pattern with the MT lens.
Here’s a photo of a Solarforce stock lens, AR lens and the MT AR lens (the lenses are 1” above the paper in the background).
! photo PFP Micro-Textured Lens Large_zpsyacnej3y.jpg!
No beam shots…I’ve never had much luck with ‘white-wall’ beam shots.
Since you’ve read all of this, I need a few tester/reviewers -Here are the requirements:
You want a smooth beam without resorting to an orange peel reflector.
You have a Solarforce P60 light…preferably with some ugliness in the beam.
Your mailing address in in the ConUS.
You will report back after trying it for a while with your opinion.
First 5 to comment something like ‘gimme one’ or something equally eloquent.
No destructive testing on this lens… it’s the same material as my clear AR lens that was abused in an earlier test.
Paired with a Smooth-Hybrid reflector, I really can’t see why anyone would want an orange peel reflector. I’m not sure why anyone would want a smooth reflector without the MT lens…but that’s just me.
We’ll have to wait for the comments from the testers.
(For the ‘first 5’, please PM your address)
New Info:
I’m adding my official testing of the MT lens. I’ve also added a diffusion lens to the mix. The diffusion lens is a ‘very fine diffusion’ but it is has the traditional frosted appearance. Even though, it’s very fine, it still diffuses more than I want and drops the output considerably.
For the output and throw test, I used a P60 with a 3.8A drop in. The drop in has a smooth-hybrid reflector installed. For both output and throw, I powered the light with a lab power supply set for 4.2v. The output test was performed with my integrating sphere. The throw was read at 2m and the throw was calculated.
First, the throw:
! photo lens throw comparison  Small_zpsf0pzauwi.jpg!
There’s two ways to look at the throw from the MT lens… it reduces the throw compared to ‘no lens’ by 1.23%. More realistically, it actually increases the throw when compared to a stock Solarforce lens and gives better beam quality.
The traditional type of diffusion lens gives a very soft beam, but cuts the throw in half.
Now, for the output test. The table within the graph makes a comparison of all lenses to ‘no lens’ and to the stock Solarforce lens.
! photo lens output comparison Medium_zpsdhzlkd4a.jpg!
You will notice that both the AR lens and the MT lens are running above 99% efficiency. At this power level (3.8A), the MT lens only reduces the output by 3 lumens vs the AR lens. At this output level and with such a small difference, I’m temped to say ‘there’s no difference in output’.
So, for all the testers, you should see:
1. a smoother beam
2. more throw (if you replaced a stock SF lens)
3. more output (if you replaced a stock SF lens)
Hopefully, over the weekend, everyone will have had a chance to try it out and give your feedback.
Edited by: pflexpro on 10/21/2016 - 17:52
mattlward
mattlward's picture
Last seen: 2 min 56 sec ago
Yes, please let me try one. My wife uses your first lens with a smo and 219c. I think this would be a benifit.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
freefly
freefly's picture
Last seen: 13 hours 23 min ago
Wow, looks cool! I’m in.
I have several different P60 set-ups that I can try them out on and report back.
PM sent! Beer
pilotdog68
pilotdog68's picture
Last seen: 7 months 1 week ago
I’m in!
I’m impressed it didn’t reduce output. So is this something you’ve found? Designed? Modified?
vinte77
Last seen: 1 week 3 days ago
I’m in!
RobertB
RobertB's picture
Last seen: 1 day 14 hours ago
What diameter are these lenses? Can they be used in a light like a 20mm Convoy ? If so, I’d like to try one. Can compare one with and without the lens.
edit… I see now, solarforce lens are 28mm
pflexpro
pilotdog68 wrote:
I’m in!
Modified is probably the best description.
I buy my base material from a company that specializes in high performance HD plastics, so the base material is sourced from them.
I have another company do a vapor deposition coating. The company doing the VD coating makes touch screens. Their coating process focuses on durability and cleanability.
The base material is true ‘optical quality’ and very scratch resistant…the coatings, along with very high AR properties also are smudge resistant (on one side) since the coatings are meant to be touched.
The base material for the new MT lens has only a very fine texture…the texture is a micro-ripple.
A lens can eaisly over diffuse light because of it’s position (distance) in respect to the emitter, so the texture must be incredibly fine.
If you think about rippled glass vs frosted glass…the rippled glass only changes the direction of light but is still complete clear. Frosted glass will diffuse light and block a great deal depending on the amount of frosting.
If this lens is placed directly against a printed page, it will look completely clear. As it is moved away from the surface, the diffusion will become noticeable.
In the photo, all of the lenses are about 1.25” from the printed page.
sac02
sac02's picture
I’ve got several P60s solarforce lights and I’d love to review the lens. My daily driver is a solarforce P1 so I can give it a good workout in that and other lights. I also have rudimentary lumen/lux measuring capabilities, and more advanced photography capabilities if you want pics.
viperbart
viperbart's picture
Last seen: 11 months 1 week ago
Now patent it for flashlight use.
lumenzilla
lumenzilla's picture
Last seen: 6 days 2 hours ago
I have several 6p (both surefire & solarforce) but I’m not in US.
So I will wait until this lens availabe on your store Smile
ace0001a
Last seen: 1 year 5 days ago
I’d like to try one please! Glasses Thumbs Up
I’ve always been a huge Solarforce and Surefire C format flashlights and have many!
Ronin42
Ronin42's picture
Last seen: 2 years 1 month ago
excellent, looks like a lighter (more professional ) version of the DC fix (which it s what i have on my solarforce).
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
vinte77
I got the lens yesterday and I was able to try it on one of my solarforce lights with an xhp70 led. It definitely reduces artifacts in the beam and helps reduce the black doughnut in the center of the led. I noticed that it’s more noticeable when I have the light on high rather than on the low setting. I tried the lens on both OP and smooth reflectors and it helps with a better beam on both reflectors. I was only able to try it on a white wall and didn’t have time to try the light outside to see if there was any noticeable differences in throw to the naked eye. I’ll report back once I have more time to play with the lens. But so far it seems like pflexpro has found another trick to improve upon p60 lights.
Gurthang
Last seen: 3 years 3 months ago
PFP,
Very curious about your MT lens. I have several ‘mule’ P60 drop-ins using XR, XP, and N219 emitters. I’ve tried diffusion plastic, tuf-film spray and textured plastic insert to smooth the light, all w/ varying degrees of success. I’ll watch for test updates and pricing. Good luck w/ your product.
mattlward
mattlward's picture
Got mine in the other day and it works wonders. I tested it in my Solarforce with a hard driven 219C and SMO reflector. The rings in this light have always driven me nuts, this all but removes them and I do not see an impact on the amount of light out the front. I will try and capture good pics this weekend of the results.
EDC rotation:
FW3A, LH351D 3500k
ace0001a
Just got mine today, haven’t had a chance to test it yet… Will get to it in the next few days for sure!
pilotdog68
It’d be great if these could also be made in the 21mm(?) Tube light size.
pflexpro
My guess is you’re looking for something for a triple.
I could have a sheet cut at 20.25mm for the S2/S2+ lights but it would be in a lot of lenses. If there is enough interest, it would be no problem.
Have you held it in front of a triple to see what it looks like?
pilotdog68
Not necessarily a triple. I think it would have more impact on a single emitter light, like my EagleEye X2R. I already use frosted (narrow) optics on my triples and quads, so I don’t think there would be much benefit seen there for me.
RobertB
RobertB's picture
Simon is selling the SMO reflectors now for the S2+. You were saying they probably wouldn’t be effective with the OP reflectors.
mattlward
mattlward's picture
It would be very effective with the S2+ SMO optics. I have a couple of them now and they would improve with this. And, they would still have more throw and a more concentrated hotspot than the OP reflector! The Olight S10R would also like this glass in front of it.
EDC rotation:
FW3A, LH351D 3500k
pflexpro
That’s good news…but where’s the smooth reflector for the M1?
When I have more lenses cut, I will order some for the S2/S2+
will34
will34's picture
Last seen: 34 min 8 sec ago
If the price is reasonable, I would love to have this lens for all of my reflectored S2+ and C8 lights.
Yesterday I put together a S2+ with SMO reflector + XP-L HI and there are some unwanted artifacts in the center spot, same with the new clear C8 which doesn’t produce a beam as clean as the older v3 batches, it has an ugly corona and the spot is not as smooth, it also produces about 5% less kcd which is a bit disappointing. The best C8 reflector I’ve used was from a thorfire C8S.
Gunga
Gunga's picture
Last seen: 12 min 50 sec ago
I have interest in the s2 size.
pflexpro
I’m afraid the price for C8 lenses would be too high…the material is very expensive. Even though, I think it would be great in a C8, – the lens would be almost 2.5 times larger, and it would have a lower cut yield because of the larger size, so it would end up being an $18 lens
The P60 and S2/S2+ lenses are small enough so the price isn’t crazy.
pilotdog68
I decided to try my sample with the ultimate challenge: The XP-G3 4500k 90cri in a smooth reflector.
I give this product a thumbs up.
No, it doesn’t fix this emitter. The tint shift is still ugly as sin with green blue and yellow all in one. But I did see a noticeable improvement over how it was without the micro texture. One thing I notice about this vs a frosted lens, the coating/texture/whatever doesn’t “glow”. With other effects it looks like the lens itself has become the light source, with this you can still see through it to the emitter and reflector when the light is on, it’s just a little blurry. That tells me it isn’t blocking the amount of light frosting does. Hopefully that makes sense.
I do think you should price out a run to fit the S2+ and other tube lights, I’d buy one or two.
ReManG
Been playing with the one I got as well, just busy with work for the next few weeks so no pics. This is amazing and like PD68 said above, the lens itself does not look like the actual emission surface. Good way to put it PD68, I could not place what was so different about this lens and its treatment prior to what you posted.
Putting this in front of a smooth optic (20mm) makes an even smoother look to the beam. Not a “holey moley” difference, but a good one for someone that wants a different look on a clear optic.
In front of my SMO reflector lights, this is EXACTLY what is needed to make a beam that can be used far or near, indoors or out and just looks right. Incredible stuff you have here Randy, I would guess you got your idea from a Kindle or other dedicated glare free device, that is the only thing I can think of. On a sheet of paper in the sun, the lens is glare free, but for flashlights, a little bit off the emitter makes for a beautiful beam from the micro textured lens.
Great stuff! This will be on any light I order from you!
I would also order this as a lens separately as well….
pflexpro
I’ve added some output and throw test to the original post.
I should have the MT lenses available for the S2/S2+ lights in about 2 weeks.
ace0001a
Alright so after a busy work week, I finally got around to putting the lens in my Solarforce L2N lego…
Here’s what it looks like before the swap with an AR lens I got from KD:
Ceiling shot with AR lens (don’t think my old Samsung S3 camera does a good job of showing much here):
Getting ready to do the lens swap here:
Micro-Textured lens installed:
All put back together:
Ceiling shot… from which yeah, my Samsung S3 camera sucks for this type of shot Sad Facepalm :
As you guys can see, my ceiling shots don’t show any difference because a combination of me not being a photographer and the old camera on an old phone just wasn’t able to capture. From what I can see is yes I saw no visible difference as far as light output between a regular AR lens and this MT lens, which is great. To my eyes, the Micro-Texture lens does definitely have a subtle smoothing effect on the beam without muddying it up like a heavy orange peel reflector does. It’s too bad a large size lens would be cost prohibitive as I too think this would be a great lens for a pocket thrower like a C8…
That being said, this PFlexPro Micro-Texured Lens gets 2 big thumbs up from me! Thumbs Up Thumbs Up
freefly
freefly's picture
Just got mine as well, and should have some more detailed feedback shortly.
One thing I noticed (that I didn’t catch initially) was that there is protective film on BOTH sides of the lens. At first I only noticed/removed the film on the more obvious side, as the other side didn’t appear to have any film in place. Also, the attached instructions states to install with the textured side out, and that the clear film side is textured. So, at first I thought there was only one “clear film” side. At least on my sample, the film on the non-obvious side was on there very good and perfectly round. It actually took a bit of effort to get the film off that side once I finally realized it was there.
So, to all that received these as samples, be sure to take the film off both sides! Beer
Edit: Mini-review up:
PFP MT AR P60 Lens Review
Bob Loblaw
The Rayovac beast uses a lens like this. It uses an mkr or another 4 die led but the beam is flawless
