The problem I had is not the flashlight, it was the copper ring with a groove on top in witch I put the o-ring that come with the flashlight. There was an asperity all around on the outside of that ring and that ring didn’t go inside the flashlight deep enough. I only tried if the parts fit and everything fit as it should. I took photos but I don’t know how to post it here !
Robert
Sorry Robert,
I had several problems with a newer M2 host and was directing the issues I had in comparison to the host you used. My issues are in the What Did You Mod Today thread.
Yes the brass ring is tight because there are raised edges on the inside and outside of the ring from machining the tops and bottom after the OD/ID.
That ring does not fit the later M2 even after deburring the edges.
Sorry Robert,
I had several problems with a newer M2 host and was directing the issues I had in comparison to the host you used. My issues are in the “what did you Mod today” thread.Yes the brass ring is tight because there are raised edges on the inside and outside of the ring from machining the tops and bottom after the OD/ID.
raised edges the words I searched.
Thanks
Robert
Batch1, thanks for your fast reply.
I file it and everything fit nicely.
- Please DO NOT start to mill, sand, cut part if you see that it don`t fit. Just look why it don`t and measure dimentions of problem zone.
Robert
I have met this problems with SS rings in X5 set, 50% of manufactured were defects so I decided to use brass for such parts.
I`m checking all IDs to make sure there is more than 24.0mm to fit carclo quad inside, while external diameter is not so important because (as I thought) all hosts are same and 0.1-0.2mm gap will be enough. I hope all stock glass lens are same size (28.9mm), so I will make 28.6-28.8mm external ring diameter next time.
I ordered a few X6 AL heatsinks on 5 Oct. I was surprised to receive them today 15 Oct. I’d say that was pretty quick shipping. The heatsinks look great. Thanks kiriba-ru
Another package with more goodies from Russia arrived safe and sound.
Hmmmm…. What should I order next???
Parts that will be available in a week:
U11 quad conv. kit (?)
Hi,
any updates on the Manker U11 kit? I have a host waiting … i want just 1 piece.
Regards
Kenjii
Lathe machining is made, now I have some problems with milling operator. Rings from brass are ready.
I will defenetly finish them but I cant promise deadline.
And Eagle Eye X7 spacers?
X7 Cu spacers, couple of P60 solid neck Al, couple of P60 solid neck Cu, second batch of M2 quad kits, few of F13 Cu spacers, few of P60 surefire-compatible RR quad drop-ins and S2+ Cu spacers are next to produce, I think this parts will be ready in the mid. of November.
Can you say more for the “solid neck p60 AL” ?
Is this for triple or quad ?
It is universal. Even single.
I wont show drawings because they do not show real proportions. Let it be made first.
Is the solid neck p60 aluminum,the same as the ones that dsche used to make?
No, it is different, but yes, idea is the same.
I have tried to make it most short. Copper insert have Convoy S threads (please take pills from this giveaway: ReyLight Titanium Triple Ti 1 host & ti Clip )
I want to get the Convoy M2 carclo quad copper spacer + brass liner. Just want to make sure that this is the whole kit right?
How about the M1 quad copper spacer? Can I order the whole kit as well?
Thanks!
What do you mean by “whole kit”? With leds and pcb?
Do you already have M2 host?
Sorry, I mean the optic, spacer, and liner for both the M1 and M2.
Yes, I have both host.
No, optics is extra cost.
I dont have Khatod lens for M1.
Could you please check your M2 how it is described upper Low-cost copper pills, spacers, optics, drop-ins (Updated 23/10/2022)) - #330 by kiriba-ru ?
which optics are they ?
