OK, I'll try to understand the digikey thing (probably will have to use two browsers to figure it out, sounds like the links might be linked to cookies or something). I better add model numbers.
The input current doesn't pass through the input cap. It's in parallel to the battery contact, and the traces for the cap only need to handle the ripple current, not full DC current. I think it will help protect from all the stray field stuff you're worried about, among other things.
As for what's really needed, you thought 10uF was small, so I don't know what to say. x7r seems required, and I think 2X actual voltage is standard minimum and those specs lead you to 1210 or at least 1206. There's just nothing else. Plus that samsung one is really cheap.
I updated the digikey links in post 96. To get a good link you have to find the share button on the digikey product page. For my own links.. sometimes I have to re-enter the product number in the search to get the share button back.
Ah, ok now things clicked (been distracted recently and never really took the time to think this aspect through). For some reason I was picturing the input cap inline with the mosfet instead of parallel. Now everything makes perfect sense and 10uf should indeed work fine.
I will be placing an order with arrow in the next few days due to the free shipping they have going right now, so I might see if they carry these items and grab a set to have on hand.
It will work. Fine, well, you can get about a 3% efficiency boost for using 3 instead of 1 maybe more if real ESR at 1MHz is worse than predicted, or less if it's better. That's why it wouldn't hurt to add places for a few if there's no downside. $.30 for a percent more efficent? Enh, you now, I might do it, just because.
Yeah, in parallel is easy and there should be plenty of room, could even go with a larger form factor if there was a better option vs paralleling a few 10uf.
I will rearrange everything with the latest component list and see what the space looks like in the next few days.
This diode was literally the first thing I clicked on that had specs that should work, simply to see the form factor: http://www.digikey.com/short/39nh50
I still want to look over diode choice more soon. There might be things in more standard packaging without losing much.
Haven't searched for MOSFETs but on first glance that one looks pretty good. Still need to run reasonable numbers on switching losses when I get a minute for it.
Ok, I updated post 96 with a bunch of diode research. Basically there are good options in POWERDI5060-8, and in TO-263 (D2PAK). These can probably fit on the same pads if done right. Tiny heat sinks exist for the TO-263 which also need footprint and space consideration if used.
TO-220 through hole also has many options, in 2 or 3 pin. Those would certainly require some kind of heat sink, but are also easy to attach to one. If the surface mounts can handle the heat, it's probably better to use those instead. I see your point about the thermal pad being on the wrong side of the diode.
I think your SO-8 mosfet is almost certainly a fine footprint. So I think we're about all set for major components.
Now, about your circuit, I don't know about how C1in and R1Sense are arranged in the top right.
Edited: Never mind... I see Ti is actually intentionally reading ripple current, so it makes sense as is.
I'll start reading the manual more now. The constant off time and peak current control are interesting. It doesn't seem they change any of the fundamentals, just changes how frequency and current get controlled, so for instance in my table a particular frequency at one voltage output should probably imply a different particular frequency at another. I'll probably try to get familiar with it and re-arrange my tables instead of by frequency as by offtime RC constant. That will give a little better picture, but shouldn't impact parts selection I think.
So if we use full input range for current adjust, 1.24V max on IADJ corresponds to 248mV of sense voltage. At 15A, VI is nearly 4 watts across the sense resistor. We could use half the range for control (lose resolution a little). Or add an amplifier (seems a bit drastic to save 5% power maybe).
However there is also this funny business where the peak current to turn off the switch jumps up and down because they keep flipping the voltage comparator every two cycles. See figure 24 page 15 and the discussion. To me this seems nuts. They claim it makes a more accurate average current, but accurate compared to what? It seems keeping the fixed target would be just as consistent but with less ripple and without all the annoying caveats that come after it. Actual inductor ripple will be higher than what I calculate because of this effect.
Enough grumbling, the point is they claim you should maintain a minimum ripple current (see equation 11), bigger than the variation in their sensing setpoint (that they caused), which they esitmate as maybe 24mV. Using full scale 248mV sense range that's already 10% at full current, so going to a much smaller sense resistor and smaller voltages is maybe not a great idea. Note this is not output ripple voltage though. Mostly we care about this because if we try to keep ripple high at full current, it's even higher at low current, and goes into discontinuous mode earlier. We'd rather not have high ripple current.
You have to read details there to understand it. Actually though I think it's ok to have ripple lower than what they say, at high power and I'm not sure I'd worry about the degraded current control they say it causes. Peak current still won't ever go above the max cuttoff(s) and the net effect seems to be you'll just get an effectively double off-time followed by twice as long of an on time, in other words, higher ripple current anyway (kind of by way of effectively lower frequency), but no need to target higher ripple and damage the low current performance at the same time in my opinion. Basically I would ignore the constraint in equation 11. It could make ramping uneven as you cross the threshold for double or tripple off-time, creating jumps in ripple current, since it's peak current that's controlled, not average and higher ripple for same peak lowers the average. But any given mode should still stay pretty steady.
I suspect when all is said and done, there's about 5 more places with 1W losses that are just too detailed to find, and all this brings 7V output down to 80% efficient at high power. It's a good reason to fight a percent or two here and there where possible though, like the input caps.
for footprint, 5W, 7 to 15mohm resistors are available in D2Pak's (like the diodes I listed) or in sizes from 2818 up to 4527. Bigger pads, lose more heat anyway, so. Could also make it through hole and try to sink it to the case. The D2PAK's are about $2.00 and the standard flat resistors are about $1.35 for the cheapest. This driver won't be cheap. The D2Pak's are rated at very high power, like 35W so might stay cooler.
In a 4 by xp-l setup this is only heading toward about 1.5W at 6A per led if tuned for 248mV sense at max current give or take (1S or 4S doesn't matter, so long as you tuned the resistor that way for either, duty factor cancels the current change). It's just driving 4 x 12V xph35's that pushes it close to 4W.
The D2pak footprint is HUGE, almost as large as the inductor! It will not fit easily at all. I was able to fit 3x 2512 resistors in just over half the space of a D2pak.
I added more input and output caps in 1210 sizes. Obviously traces are still way undersized, I will fix that last. On the input caps, should they be before the sense reisstor like the datasheet shows or after so it is closer to the mosfet?
Very unfortunately, I haven't found one in a p-type. There might be some options for using it in n-type, constructing one etc, but probably not one-stop solutions :(.
The one in the data sheet is right. I was confused on this briefly, but this sense resistor can't be shielded from the switching ripple. It needs to sense the ripple. Looks like you have it as compact as it can get there.
This sense resistor thing is a pretty big deal too. Looks like you followed that based on those three big sense resistors. That's another 4 watts and another big heat load to clear. Those d2paks are big for a reason (somehow I was confused they are bigger than I though). Big heat in small space though, we'll need some clever sinking.
Maybe you can make the inductor pads super huge at some point with some through holes in the middle to test unshielded inductors. I guess that's a 17mm inductor yes? I'll have a look at it all more closely soon.
