HaikeLite Preview for MINI Triple-XHP70 prototypes--Discussion thread
It looks perfect in that colour. Good choice.
Knurling can get dirty. The peaks get ragged. Do a quick skim cut to knock the tops off. Personally I don’t care about the anodizing attracting dirt because that means it’ll probably be less slippery when wet and oily.
I find aesthetically the reflector of the X7 and the TN 36 nicer.
Thanks for the update. “Devourer” is a nice name, but it doesn’t really roll off the tongue nicely… or is it just me?
It’s not just you.
Yeah, but at least there’s “MT03” that’s easier to say.
Hello Haikelite,
I’m getting mixed signals here. Is the turbo mode part of the lowlow-low-mid-high-(turbo?) sequence or not? It seems that this is the case for the MT03, but for the thrower model MT07 it seems that turbo is a memorised hidden mode only… Can you please enlighten me? Thanks!
MT03
Low low-low-mid-High-Turbo (Press and hold switch) in Sequence with last mode memory ; Double click to access turbo in any status
MT07
Low low-low-mid-High-Turbo (single click) in Sequence with last mode memory ; Double click to access turbo in any status
Ah ok, thanks! Too bad for me but ah well…
You finally sell the MT03 with 9500 lumen output on amazon.de e.g.;
do you really have tested this or are these ‘china-lumen’!??
:question:
I would like to know what cells you are selling with your lights. Your website says timed temperature step down. How long can it last on Turbo?
Best regards,
Tom
Ah wow, the light can already be ordered! I missed that. Over 9000 of neutral lumens sound very attractive…
What kind of shipping is there to the Netherlands?
Hey guys turbo mode is 2.5 minutes then after that it is temperature regulated stepdown if the light is over 56 degrees Celsius it will step down slowly. The light will be tested in a professional integrated sphere. Numbers will be posted here. 9500-10000 lumen sounds about right running 3 XHP70 @ 12 amps.
Is there any possibility of a BFF discount coupon? I’m seriously wanting to buy one of this monsterlight, but the price range is off my budget.
Thanks for any “help”.
Does the final driver 12.0 amps to the leds!? HaikeLite self says something around 10.8 amps (8500~9000 Lumen) max. … :weary:
Hello Haikelite. Have you guys made a official release yet with production pictures? You mention it’s for sale already, I’m really curious because you’ve definitely been one of the more responsive companies in this forum. Thanks.
Hi KutKhemist
The pictures are from Prototype I II and III. First picture is close to final product.
Final products will be ready this weekend. Will release official final pictures by then.
Thanks
HaikeLite
Not 12A… Driver amp 11A to Leds
Total Watts on a full batteries charge will be around 88 watts so divide that by 3? 8.4 volts with two full cells but we will call it at 8 volts flat. So 8 times 11 is 88 watts
Cree states that a XHP70 needs 32 watts each to achieve 4k lumens each emitter in this light will be getting about 29.3 watts so fairly close to the target of 32 watts.
This set up should achieve around 11k lumen at the LEDs? With loses around 9500-1000k lumens?
the output and UI is sounding very very good. lets hope the host has good heatsinking properties to have it run on turbo more than 2 minutes….
