And Eagle Eye X7 spacers?
X7 Cu spacers, couple of P60 solid neck Al, couple of P60 solid neck Cu, second batch of M2 quad kits, few of F13 Cu spacers, few of P60 surefire-compatible RR quad drop-ins and S2+ Cu spacers are next to produce, I think this parts will be ready in the mid. of November.
Can you say more for the “solid neck p60 AL” ?
Is this for triple or quad ?
It is universal. Even single.
I wont show drawings because they do not show real proportions. Let it be made first.
Is the solid neck p60 aluminum,the same as the ones that dsche used to make?
No, it is different, but yes, idea is the same.
I have tried to make it most short. Copper insert have Convoy S threads (please take pills from this giveaway: ReyLight Titanium Triple Ti 1 host & ti Clip )
I want to get the Convoy M2 carclo quad copper spacer + brass liner. Just want to make sure that this is the whole kit right?
How about the M1 quad copper spacer? Can I order the whole kit as well?
Thanks!
What do you mean by “whole kit”? With leds and pcb?
Do you already have M2 host?
Sorry, I mean the optic, spacer, and liner for both the M1 and M2.
Yes, I have both host.
No, optics is extra cost.
I dont have Khatod lens for M1.
Could you please check your M2 how it is described upper Low-cost copper pills, spacers, optics, drop-ins (Updated 23/10/2022)) - #330 by kiriba-ru ?
which optics are they ?
10507 20mm triple and cute-3ss 35mm triple.
ill get some Carclo 10507 20mm triple Narrow Spot Plain on the next round order
If you can put together a kit for F13, I would like to get one from you.
What do you mean “kit”? Solder leds to pcb and pcb to the spacer? When I have parts in stock I offer such services for free.
Anyway next parts will not be ready earlier than 3 weeks after this message.
Nope, What I meant by kit was that I would like to buy complete set of parts.
Such as
MCPCB,
Copper Spacer,
Any rings for centering if needed
Optics.
I can do the build myself.
Yes, when XP32 board is in stock
Yes, when spacers are ready
I dont like when glass lens are pressed with the tir lens and when this is the only way to give pressure between o-ring and host, but X7 trasfotmation was designed this way. If it wont work and somebody will broke glass lenses, I will make rings between head top and bezel.
Yes, if CUTE-3 optics will be still in stock.
You (and other members too) can simply reserve parts when they are in stock. I will take plastic box, write your nick over and parts that were in stock at this moment will be waiting until you order could be full completed.
I got some of those pills and they are great, i realy like the b158 one
Thanks m8!
I think its about a time for you to start offering custom hosts
I just built 2x XP-G3 S2+ lights with your spacers, they work great! I am sure I will be ordering more.
Mixed tint triple = amazing.
