Aggressor
(Aggressor)
September 8, 2016, 11:06am
96
What did you say?
Any idea when it will be released?
HKJ
(HKJ)
September 8, 2016, 11:16am
97
Aggressor:
What did you say?
That is a silly question :laughing:, I do usual not say no to chargers.
Soon, I did not ask for a schedule.
As can be seen here I am not running out of work soon! I have many chargers to test. The Xtar will not be last, but I have some I need to publish first.
angerdan
(angerdan)
October 19, 2016, 5:40pm
98
Please consider following chargers:
Xtar VP4 Plus
http://www.candlepowerforums.com/vb/showthread.php?422789-NEW-XTAR-DRAGON-VP4-Plus-analyzing-charger
https://www.xtardirect.com/products/xtar-vp4-plus-dragon-charger
Shop for Xtar VP4 Plus (ships to denmark too):
XTAR VP4 Plus "Dragon": 4-Schacht Li-Ion & NiMH Akkulader mit Display und Analysefunktion, 3 wählbare Ladeströme, USB Ausgang & Powerpack Funktion. Messen des Akku Innenwiderstands, Laden von 3s 11.1V Akkupacks und vieles mehr.
HKJ
(HKJ)
October 19, 2016, 5:45pm
99
I am already working on it.
angerdan
(angerdan)
October 28, 2016, 10:06pm
100
Found a new 8-slot Li-Io/NiMh/LiPo Charger:
GYRFALCON All - 88 Smart Battery Charger
http://www.gearbest.com/chargers/pp_365106.html
HKJ
(HKJ)
October 29, 2016, 12:58am
101
maukka
(maukka)
November 7, 2016, 5:20pm
103
HKJ
(HKJ)
December 20, 2016, 8:26pm
105
I cannot test advanced usb-c yet.
hank
(hank)
January 15, 2017, 6:00pm
106
Apparently there are a lot of Liitokala 100 clones being sold.
This answer claims they’re using a different circuit board:
Thank you for your inquiry regarding http://www.gearbest.com/m-goods-sn-189533001.htm
Your original question is “Which version number is printed on the circuit board? This appears to be a LiitoKala product relabeled (same misspelled word on the back, ”compalible”) but I know LiitoKala went through several revisionsl Which one is this?”
Here is the answer from Our Customer service Team:
Hello Hank,
It’s Colaier C20.
Hi Henrik
Any update on your test/review of the Olight Magnetic Charger.
Thanks
John.
HKJ
(HKJ)
January 22, 2017, 12:37pm
108
I have just finished it, but it will probably be about two weeks before I publish it.
ko4nrbs
(ko4nrbs)
January 28, 2017, 9:01pm
109
I’d like to request a review on this charging board:
http://www.ebay.com/itm/MAX1879-Lithium-Battery-Iron-phosphate-18650-A123-Charging-PCB-solar-power-/121267763283
Would be very interested if it was an ok charger for LiFePO4 cells as advertised.
Thank you,
Bill
ko4nrbs
(ko4nrbs)
January 29, 2017, 2:06pm
110
L4M4
(L4M4)
April 26, 2017, 4:54am
111
http://www.gearbest.com/chargers/pp_625423.html
Quite cheap one cell simple-charger, even cheaper than the Lii-100
ferongr
(ferongr)
April 26, 2017, 5:27am
112
It will most likely be junk like most *fire chargers. It’s not worth the time, really.
HKJ
(HKJ)
April 26, 2017, 5:36am
113
I have ordered one. It will go in the low priority queue, i.e. it can be a long time before I publish a review.
There is a big risk it is a bad charger, UltraFire often is.
L4M4
(L4M4)
May 16, 2017, 9:03pm
114
https://www.aliexpress.com/item/TP5100-double-single-lithium-battery-charge-management-compatible-2A-rechargeable-lithium-plate/32615889901.html
I found this while searching for a small but >1A charging circuit
This thing is interesting, because you can choose 4.2 or 8.2V - I think the charging current drops to 1A at 8.4V
also, the input-voltage can be pretty high.
If you are bored (lol)…
HKJ
(HKJ)
May 17, 2017, 3:37am
115
I have ordered one, but it will probably be a very long time before I get time to look at it.
