COURUI DO1 'Big Head' (Black/GRAY NOW AVAILABLE) $29.99 @ Gearbest ( use coupon: gbcourui) A long-throw modder's light!
already did
http://forum.fonarevka.ru/showpost.php?p=874747&postcount=241
http://forum.fonarevka.ru/showpost.php?p=875211&postcount=250
driver Indigo 5
http://forum.fonarevka.ru/showpost.php?p=449738&postcount=1
DealsMachine seems to have the black as of right now.
$24.99
thanks for the link
I have one Courui D01 with damaged reflector and it is sitting disassembled quite some time, maybe more than a year, who knows… I had some crazy ideas but after some time spent thinking about those i figured out that it would not be possible to do those things with reasonable cost, so do you guys have some suggestions what to do with the flashlight? I might just give up at the end but would love to see some suggestions, note that the stock reflector is not usable.
One of the crazy ideas was to do a short D01, with 4-5 S2+ reflectors and custom made spacer for the leds and driver socket, it is doable for someone who has lathe on their disposal but for me it would be to pricey, although it is not that hard if i nail the design of the pill and driver socket on first try, which to be honest will not be possible.
It would look like this
Dude, fasttech has some cheap large reflectors for sale, even those mega size zooming convex lens is available for this light but will probably need some serious diamond file sanding to fit perfectly to make this mega jaxman. i scoop up some large reflectors along with those xpl hi during a sale . Always good to have some new leds around for upgrading of lights. yea , i have a xplhi v4 waiting to go into this super thrower with just a simple emitter swop.
Ok im late to the party here, i just got 2 units of this.The quality is close to typical ultrafire budget light but the specification of 3 cell compact body and 68mm large reflector makes it hard to beat as a perfect easy host for modding.
One of which i changed to xpl hi which makes it an incredible compact long thrower with long runtime. The beam gets super narrow but it has tri petal aura around it and is not as nice as a perfect circle. nonetheless the ultra tight beam profile still looks good and better than the stock and throws like crazy.
The other i plan to pop in xhp35 hi with kd 1amp single cell driver which makes it easier to mod it than a conversion to series.this will require more work to machine a holder for the smaller driver pcb to fit the host :+1:
if you can get this : Courui D01 contact board V3 will make your life easier
For anyone interested in a better driver for these, I made a Texas Avenger for the D01, it has not been test fitted yet but should work with minor sanding at worst.
You can see all the details here: Texas Avenger "TA" Driver series - Triple channel + Bistro or Narsil + Clicky or E-switch - The Ultimate open source driver!
If there is enough interest (at least 7-8 drivers worth) I can make up a batch of them to sell. Price would be about $17.50 - $20 each depending on quantity.
Or naturally with an open source project like this, you are welcome to do it yourself, please do post your results in the TA thread if you do!
Any source to buy D01 ?
I ordered one of these about a week ago : https://www.aliexpress.com/item/2016-New-Courui-D01-2000Lm-CREE-XM-L2-3-Mode-Super-bright-LED-Flashlight-Torch-3/32646564107.html?ws_ab_test=searchweb0_0,searchweb201602_2_422,searchweb201603_1&btsid=50dac44a-26bc-444b-b115-fdd504388fdc
It shipped the next day, guess I will see when it shows up.
I found this too , i was hoping for a better price.
Thanks
I got mine from a online re seller but the QC was poor and inconsistent, a lottery buy . Aliexpress would be a better source.
New Courui D01 XP-L V6
:) I think I did a nice mod underwater mod…
After cutting 0,5mm of the bottom of reflector we have a nice focus:
Then I made just a tiny modification :wink:
Tested in local swimming pool:
I’m going to use it for deep scuba diving…
^ Awesome under water video! :+1:
Looks amazing with a lot of work Mieciu. Any chance of a build thread?
Wait there’s a xpl hi v4? Where did you see or find that. As far as I know v3 is the highest bined xpl hi
I don’t know if this is the case with the one Fatlight bought, but sometimes Cree will make a higher bin in cold white only, like 10,500K white! I’ve seen this a few times. It’s sort of unofficial, undocumented, and only available at one or two places.
Hi MRsDNF
I did not document the build process… It took me almost a year to finish it.
I had a limited access to a small hobby lathe and other things in my life were more important…
Nevertheless last weekend I took it to 130ft/40m and it survived without leaks :slight_smile:
starting from 2nd minute - test of my custom software to prevent accidental short piezo pressed, accepts only longer signals.
and with some cute animals:
Thanks for the picture and video. It sure is another world down there. :+1:
