Nitecore EA45S Review. Lots of Pics.
UPDATED / 11-1-2016
What do these results indicate so far?
Just the parasitic drain with the light on “Lock Out” and zero light use.
What I was asking is do the numbers tell you anything yet? The drain can’t be too bad, right?
My bad ‘arow55’………. :wink:
Looks like in six weeks of being on “Lock Out” with absolutely zero use, the average loss per battery is 0.08525v.
That seems like a pretty minuscual loss to me.
We will see what happens with more time though…. but I am thinking it will be nothing drastic. :wink:
  • Light Nitecore / EA45S
  • Batteries / Eneloop ‘PRO XX’ AA _ (HR-3UWX min 2400mAh / 11-05-EE) _ Batteries fully charged, rested over 24 hrs. then installed.
Date…9-19-2016……10-3-2016……11-1-2016
Time…08:00…………16:10………….11:35…………
  1. … 1.387v…………1.326v…………1.304v
  2. … 1.388v…………1.328v…………1.305v
  3. … 1.391v…………1.326v…………1.303v
  4. … 1.391v…………1.327v…………1.304v
Thanks for reporting the parasitic drain. Mine still on the way.
UPDATED / 11-14-2016
You can calculate the mAh drop from the voltage drop by knowing the discharge curve, no? Then parasitic drain in mA is easy
Probably, but I have no clue how to do it……. :wink:
Received mine on the weekend. It turned on one day and does not turn on anymore. Tried numerous batteries and no-go.
Anyone encounter issues with their EA45S?
Mario
Ottawa
MarioP, I have had no issues with the latest EA45S’s I have bought. But that being said, in the last few days the first one I bought, about a year ago IIRRC; developed a problem.
It comes ‘On’ in ‘Low’ when the ‘Off/On switch’ is pressed. But when the ‘Mode switch’ is pressed it turns ‘Off ’. :frowning: :question:
I assume something has gone wrong with the switch, but that is just a guess.
I have the reflector out, all the solder joints & wires I can see appear OK. I am now trying to figure out how to get the switch, boards, LED, & the rest of the “innards” out (without destroying them) to check what I can’t see.
This is the first Nitecore of many I have ever had any problem with at all.
So, when I get the “innards” out and check them maybe I’ll know more.
As far as your’s goes, sorry; I have no idea my friend. :frowning: Good luck though.
IF I find out what is wrong with mine I’ll report back. Maybe that might help you.
Please keep me informed. I too assume something in the switch went bad….but I am not knowledgeable (or brave) enough to take it apart.
Mario
It might be in lockout mode. Try pressing both switches at the same time.
Mike
That is a good point ‘mikeyx’! :+1:
Thanks Mike. Already tried it, but it may be stuck in lock out. I can’t get anything, no battery indicator…nothing.
Any other secret switch combination?
Mario
Try cleaning battery contact points. Has worked for me on other lights.
Taking the batteries out and then putting them back in (or just taking the tail cap off and then back on) should clear any lockout mode. Let it sit for a while without cells to make sure any caps drain down, then try it again. Good Luck.
tried everything…not only does it not work, batteries are completely drained within 24 hrs……
That ain’t good………. :person_facepalming:
Keep us posted on the outcome ‘MarioP’, good luck. :+1:
UPDATED / 11-23-2016
