I want both, the plunger style with a normal single emitter setup would be great.
I would then love to do the box style with a multi emitter setup since it could handle the heat. Something like a quad or more xhp70 / xhp35 setup with a ~200mm total reflector size would be great. Put a fan on the back to handle the heat.
Personally I dont think we should choose now. There are only 2 (basic) designs.
Both designs has some pro’s and con’s.
The design can impact the amount of cell you need to use. (more options with box design)
Weight, overall dimensions. Center of gravity plays an importend roll. (with box design easier)
So, I think we should have some more designs of the traditional style and the box style before we can choose.
I like Djozz’s sketch - but I think it’s more useful with a high output flooder where casing get’s hot and a lot of battery capacity is needed. Being a thrower I believe its difficult to point it exactly to a target, and often I’d have to hold it uncomfortably high to shine over bushes or other obstacles.
I’ve wanted a Maxabeam ever since I spent so much of my teenage years watching the X-files. Still don’t have one, and now that I’m older I can’t justify the money.
I’m working on a simple design based on djozz his design. But it isn’t easy.
Also this traditional design is easier to machine than a box style light (I think that’s the reason they are from plastic). A box style will be to expensive I think.
This is a good point as well on the cost issue with the box style, it would cost more.
Although those talking maxabeam style light, be aware that reaching those numbers would need to use an HID like the maxabeam I have a feeling, that would raise the price even more and it would have no modes. It would be great fun but I doubt there is enoguh demand on BLF for a $200 light to justify making it. Maybe on CPF.
Now a multiemitter setup would be a lot cheaper then the HID but it would also not throw as far.
Box all the way, there are tons of plunger lights out there and very few box style. With the box style the heat sink can be as large as you want it and battery capacity can be 4, 6, 8, 12, or whatever we decide. Plenty of room to do what you want and you are not limited to the constraints of a tube.
