What is the preferred format / shape of the BLF Giga thrower
Yes, his is much better then mine.
This is a good point as well on the cost issue with the box style, it would cost more.
Although those talking maxabeam style light, be aware that reaching those numbers would need to use an HID like the maxabeam I have a feeling, that would raise the price even more and it would have no modes. It would be great fun but I doubt there is enoguh demand on BLF for a $200 light to justify making it. Maybe on CPF.
Now a multiemitter setup would be a lot cheaper then the HID but it would also not throw as far.
I agree, that was the idea with the 4 cells, give it a more balanced look.
Yeah it is hard to describe the shape, plunger kind of does :wink:
I’d still prefer 3 cells over 4 cells, I believe it’s more comfortable to hold for a longer time (because of the smaller diameter).
The issue is that the XHP35 needs 4S voltage, so it would need 4 cells in order to work.
True for the XHP35, but as I also mentioned in the other thread, I’d prefer a XP-L HI. :wink:
you could just hold it with the handle pointing down or sideways, so no arkward hand position going on
“Gangsta” style…
Box all the way, there are tons of plunger lights out there and very few box style. With the box style the heat sink can be as large as you want it and battery capacity can be 4, 6, 8, 12, or whatever we decide. Plenty of room to do what you want and you are not limited to the constraints of a tube.
+1 here! Also, even with a 4-cell tube, there is a limit to how large a diameter head would look decent. In the original thread, someone mentioned a 160mm reflector (or was it a lens?). I think that would look great in a box style light, but dorky in a plunger style, even with a 4-cell tube.
But, just off the top of my head, here’s an idea. How about a dual-tube “plunger” style? Make each tube two cells wide and two cells long, and set them a couple inches apart (inch or so off center each way), behind a huge head, housing a 160mm reflector/lens. The tubes would be wired 4S, but parallel to each other, so that only one tube would have to be filled for the light to work. Filling both would give you more run time. The tubes would be easy to grasp, and the light would have a more balanced look and feel (when loaded). The tubes might need to be connected at the back with a plate, so they couldn’t be pulled apart like a wishbone! This light would have almost all the benefits of both plunger and box style lights. Yet it would be totally unique and very effective. I’d expect a price point around $150 - $200 list, but $100 for the GB. :smiley:
Yeah discussing it in the team 120mm seemed like a tipping point
To that a plunger would work but bo larger reflector could be used
Bigger reflector would mean a box for sure
For tube just think two SRK tubes, nice and fat.
One nice thing about the classic setup is that we could reuse basically the entire Q8 design from the shelf down and then just simply design a new head/reflector to screw on the end of it.
Well, there’d have to be some work below the shelf if XHP-35 is used. Otherwise, you’d only get 2S4P from the tubes. It needs to be 4S voltage.
We designed an adjustable tailcap for the Q8 already that takes care of that, we are just not sure if thorfire used it. With that taipcap PCB in place it would be whatever we want.
Although it actually would need some work at the tailcap come to think of it as the cells have to be inserted from the rear. That in unless we decided to go with cell carriers instead. This is the easiest option for sure and would allow for the widest possible range of mods. Everything from 1S to 8s could be done with them if you had a driver to use it.
I dont know what im talking about :laughing: but a box looks awkward and dorky. I just like cool looking lights and a “box”, welllllllll…
You think a box looks dorky? Try a plunger light with a 2” handle and a 5” head! Unless you’re Andre The Giant, you’re gonna look like a total dweeb carrying that thing!
Edit: Just my opinion. Others will certainly disagree.
Happily!
For me it’s more than just looks too, a traditional shape is more useful for a thrower IMO.
I agree, holding a box light at eye level for a thrower would be uncomfortable.
Now a box flooder would be great!
Sign me up at those specs…heck yea!
Although….2 box lights might look cool as bookends on firefly mode :laughing:
What about this design?
