True while we don’t need that much fin area, it also doesn’t add much space, they could be cut down for a sleeker design though but I am sure he plans to do something like that in a final design.
True but they also have far better thermal regulation then we do but I see your point.
That said I am sure some people will be swapping XHP70’s into this (should actually be quite nice with that large of a reflector) and then it would need every bit of cooling it could get. I think some more mild fins along the lines of the L6 would work fine though.
Too few fins and it gets that ugly plunger look IMO/
it’s all about the transitions. The TN40 is hideous because they just stretched out the top. The TN42 is beautiful IMO. I really like the smooth head close to the bezel. You should go with fins on the sloped sections.
I was personally thinking of something along the lines of the S70/L6 style, something in between would be nice I think. Mostly cause I don’t want to just straight up rip of Simon or I would say a larger L6.
I’m in. Would prefer plunger style with 6 or 8 batteries,for run time and any xhp led. Seems like we’d be going backward with any of the older leds. But anyway I’m in for one whatever you all decide. Will enjoy seeing this move along. Wish I could add something smart or interesting but alas I’ve got nuthin….
I’m interested as well. Would love to see 110-120mm head diameter, with an XHP-35 HI and powered by either a 4S driver regulated up to 2.5-2.9A (or a buck to have 4Sx2P at the same amperage); or a 2Sx2P boosted driver, boosted up to 2.5-2.9A, for which I know currently does not exist.
Have two big lights with long handles, the Fenix TK70 and the Supbeam X60, neither has ever been used except for testing because of their size. The second one with the short handle looks very unbalanced.
Who holds a light at eye level, never done that and never seen anyone else do it.
I’m aiming on this light till this topic came out… I hope they made the plunger type with longer body, the body on the proposed 3d drawing is a bit too short imo…
It is almost impossible for a human to hold and maneuver an oversized plunger type flashlight (without a handle) for extended periods, like during real life search & rescue. Please consider this and go with the box type, so we can actually use the light.
Why would a box be easier?
A plunger hold with thumb on switch has weight behind and in front of the hand a box has all the weight in front of hand
Side carry, arm down:
So a plunger will only need one to loosen the pinky or index finger for up and down, box needs constant strength to point forward or a bit up, plunger is easier
Shoulder carry, a plunger can be carried on the shoulder (ideal for reflections and have the beam go over anything lower then yoir shoulders. (I use all my lights like this when inspecting the grounds, ideal)
Again balanced because of the cell weight
A box maybe could be carried like this but again needs constant force to keep straight, so plunger is easier.
I think you’ve added something both interesting AND smart here. Yes I agree that using an older LED feels like going backwards, and surely any manufaturer would make something modern!
