I am not subscribed to this or any thread but make a conscious effort to check this thread pretty often . This has happened before and I’m starting think in some cases it’s other family members opening mail and not realizing what DC-fix looks like . It can look like there is nothing in the envelope at all . Recently I have started writing DC-fix on the back of the sheets just to avoid this issue. But I think in the future I’ll add some odd shaped samples of other diffuser material i have over here and wrap it all up in a letter thanking people and explaining what it is for the moms / wives who like opening mail and tossing stuff out . I could write “important flashlight material enclosed ”……but in some homes that might be reason for a divorce .
private message me StevenS with your address again so i can double check it ….and I’ll send you some more DC-FIX.
This is great stuff, saved one expensive light for me and made a couple others really nice for task lighting. I’d like to try it on a few more but i seemed to have misplaced my envelope. I wonder if at some point i thought it was empty and through it out. I may need to buy more. It’s great to see it’s still available.
Look at the lens in that photo. It isn’t very hot. Only the “wooden surface” that the light is shining on is getting so hot. In fact, I’m almost certain that most of the heat showing in the lens area, is actually being read from the reflector behind the lens, and not the lens itself. I know the DC-fix will absorb more light (and heat) than a clear lens, but I think the DC-fix will be okay for at least that light.
I already re- sent it . I wanted to make sure there weren’t any problems. You said in your PM that the delay might be in your mailing system …. But I didn’t want you to have to wait any longer than you already had .
Let me know when you get it / or don’t get it …thanks again
Thermal imaging doesn’t work on glass or other reflective surfaces. It just reflects the temperature as if it was a mirror. If you take a thermal image of a window straight on, you don’t see the temperature of the glass or anything behind it but your own body heat.
Well, but the wooden surface absorbs the light/heat while DC-Fix lets it pass, at least most of it. I’m using DC-Fix “Static premium transparent” (static means without glue) in a UF13 with MT-G2, powered at about 60 watts maximum, about 3000 lumens. This DC-Fix eats only about 7% of the light (my rough measurement), no problems here up to now.
Maybe find a “disposable” lens to try it on, just in case it does trap heat.
And yeah, I forgot about that tiny detail of thermal imaging and glass. I was really not even thinking about glass. Most lenses in lights that I own are plastic.
