Low temperature (<0*C) Alkaline, NiMH or NiCD?
6 posts / 0 new
vex_zg
Last seen: 4 years 7 months ago
looking for something to keep in car that will work well if needed even around -20*C, in a compact flashlight, up to SkyRayKing size.
Which chemistry would you choose from above listed?
pilotdog68
pilotdog68's picture
Last seen: 3 months 2 days ago
For battery chemistry, you want lithium primaries.
They are pricey however. In each of my vehicles I have one light with Energizer Lithiums and a spare set of batteries for emergencies only, and one other light with either Alkalines or rechargeables for normal usage. I think whatever chemistry eneloops are is supposed to be decent with the cold as well.
keengeorge
Last seen: 1 year 11 months ago
+1,000,000  smile
Ronin42
Ronin42's picture
Last seen: 3 years 3 months ago
Category : Primary Lithium Cells / Batteries
Primary Lithium batteries feature with high energy density and long shelf life. They are excellent for smoke alarm, LED lighting and outdoor devices. However they are not rechargeable and totally different with Li-Ion batteries. There are three types of chemistry in Lithium primary battery, which result in different voltage as the follows:
Li-Fe-S 1.5V AA 2900mAh, AAA 1100mAh
Li-MnO2 3.0V CR123A, Button cells
Lithium thionyl chloride 3.6V AA, 1/2AA, 2/3AA, C, D, DD size
from
http://www.batteryspace.com/primarylithiumcells.aspx
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
brad
brad's picture
Last seen: 12 min 56 sec ago
Eneloops work down to -20c although with shorter run time, but that could be helped by putting them in your pants pockets for a few minutes, and then the holding of a flashlight in your hands.
Regardless though, even in a full worse case, totally cold, -20c battery needed immediately, at least you can get some use.
“· Superior performance at 0 ℃ and works in temperatures as low as -20 ℃ (*2)
(*2) Operation time is shorter than that at room temperature regardless of appliance used.”
Not what we have but what we enjoy, constitutes our abundance.
hank
hank's picture
Last seen: 3 days 6 hours ago
Quote:
http://data.energizer.com/PDFs/lithiuml91l92_appman.pdf
Lithium iron disulfide (LiFeS2) batteries have a much lower sensitivity to temperature
… The recommended operating temperature range is -40°C to +60°C (-40°F to +140°F). .
…LiFeS2 batteries can deliver approximately full
rated capacity at -40°C if they are discharged at 25 mA. Thus, at these rates, the
batteries give comparable performance over the entire 100°C operating range.
