JAXMAN E3 Nichia 219B
I bought it from aliexpress and it goes by: JAXMAN E3 high CRI outdoor Flashlight Torch use AA alkaline or Ni-MH battery Nichia 219B series warm white (4000K)
here some pictures, dimensions and toughts
sorry not very much data, but maybe it ansvers some questions for somone
Inside box: E3 flashlight*1, O ring*2, Stainless Clip*1, Hand Strap*1, Keyring strap*1, manual (english and hieroglyph) and I think it some sort of warranty card
(battery was not included)
Here data from seller page and from user guide (comes on paper english and written in hieroglyph)
*Battery: 1*AA size battery, Alkaline or Ni-MH
*Switch: Tail switch
*Modes: Low-Middle-High,Max 200 lm. Max. current=700mA
*LED Type: Nichia 219B series High CRI led lamps, Ra=9050, Warm white (4000K) (can be obtained also Cool wihte (5700K))
*Lens: aluminium reflector, toughened mineral glass, AR coating and glowing O-ring (Like I understand manufacturer can change
glowing O-ring with non glowing if you beforehand mention it. Only cant understand why he dont say to me, that O-ring dimensions
was 17mm x 0.5mm but that says only that very hard to find exactly fitting)
*Body Material : T6 6061 Aluminum alloy CNC manufatured, Anodic Oxidation Coating >45 um.
*Tailstands: no (first ~5min standing and then starts fall)
*Price Paid: 23.20$ + 2.51$ shipping
*From: Aliexpress seller Suizhou Jaxman Electronics Co.,Ltd.
*Date Ordered: Sep. 26 2016
Lenght: ~95.4 mm
Outer diameter (head): ~19.6 mm
Inner diameter (battery tube): ~14.2 mm
Inner diameter (switch tube screw): ~18.2 mm
Switch tube lenght: ~14.1 mm
Battery tube lenght: ~51.2 mm
Head tube lenght: ~35.6 mm
Switch ring (some yellow metal) diameter: ~17.2 mm
Switch rig thickness: ~2.9 mm
Head tube inner diameter: ~17.2 mm
Driver and led lenght: ~10.7 mm
Driver and led diameter: ~12.6 mm
reflector lenght: ~12.1 mm
reflector diameter: ~12.1 mm
reflector lower hole: ~5 mm
lens diameter: ~17.1 mm
lens thickness: ~1.5 mm
lens glowing O ring diameter: ~17.2 mm
lens glowing O ring thickness: 0.5 mm
weight without clip and battery: ~44 g
clip weight: ~2 g
I measured temperature (celsius) over runtime (~1 h) with full mode
used eneloop
other setup
after 10 min
and full graph
bigger and brighter are Jaxman E3 full, smaller are Roche F12 (Cree XM-L T6-4C) low mode
I think it ~30m OK
I cant heard any sound in any mode
No PWM/pulsing so much what I can see (and through camera)
And when anybody wants pouch and clip then must count this
Nice review, thanks!
In the pic showing the LED, is that white stuff on the wires just glue? Is it simple, ordinary glue, like Elmer’s glue? Or is it some kind of special, thermal glue? Or is it something else entirely?
I dont know. It like harden clue (?)
I think, in forum are user jaxman You may try ask from him or seller in aliexpress
It is a thermal(-ish) glue that is often used by manufacturers (Fujik adhesive?). Works for fixing the ledboard and wires in place so that assembling is easier, and the light is more shockproof. Good for modding too because it is easy to remove.
I wish I had thought of that when I was fighting my wires in my first flashlight build. How exactly do you remove that thermal glue? Sooner or later, I’ll want to modify my existing flashlights that use this glue.
I’m also very interested in that light. What are the outputs for each level? Just approximate.
Some more pictures
from left: Roche F12 (Cree XM-L T6-4C 523-Lumen 1*18650 AMC7135*4) on lower, middle Astrolux A01 on max and right Jaxman E3
camera: ISO 100, Tv 1/500 s, Av 2
Jaxman E3 full
Jaxman E3 middle
Jaxman E3 lower
same settings, but ISO rised to 200
Thank you very much matik42!
Is Low mode of Jaxman E3 about the same as mid of Astrolux A01? Or slightly brighter/dimmer?
Camera settings here are changed and photos may be misleading so I put here picture what are taken with same camera settings like used in previous post
Tv=1/500 Av=2.0 ISO=100
Left Astrolux A01 low and right Jaxman E3 low
Av=2.0 Tv=1/8 ISO=100
white Balance: auto (awb)
Av=2,0 Tv=1/30 ISO=400
white Balance Fluorescent H (on my screen this gets bretty realistic colors)
thanks.
How long E3 works in 2 and 3rd modes ?
I hope measure it on weekend.
Tryed measure middle mode runtime yesterday evening. With eneloop (~1.46V and ~1807mAh) switched on ~18:15, when I fall in sleep ~23:00 it was lighted up. (Today morning eneloop ~0.92V)
And it runs cool, no temperature change at all and tail standing all time.
Runtimes:
full: ~1h
middle: ~8h
low: ~109h
used Sanyo Eneloop HR-3UTGB (3rd generation) ~1800mAh and charged to ~1.4V
Measured so, that switched on and if no visible light, so end.
Of course dont catch exact end. After full and middle battery was ~1.1V and after low (maybe 2-3h after “end”) was ~0.91V After high on ~70 min led was very low glowing.
It is veeery similar with Thorfire TG06…same body with different led?
Jaxman weights more (44g versus 37g), little longer (95mm versus 93mm), diameter are little smaller (20 mm versus 21mm) and by manufacturer takes only AA batterys.
All Thorfire TG06 numbers taken from banggood
Have light memory. Goes low -> middle -> high and starts last used.
It's the same host around 95mm in length
About lens glowing O ring
Ordered from FastTech Water-tight O-Ring Seals (5-Pack) 15mm * 1mm * 17mm
They dont fit
Now get from Jaxman not glowing O ring for E3 with my ordered M8 and that fits perfectly
