Tom E, please check M4D M4X´s deals thread. There's a groovy discount code for the LiitoKalas at Banggood which, combined with the volume discounts, makes it the best deal nearly all of the times. Make it your mantra: 975e07, 975e07, 975e07…
unknown00101, nothing new with buck drivers. Understand, please, that a buck driver can have (and usually have) a long voltage differential between input and output, making the batteries' internal resistance much less meaningful versus overall capacity. For buck drivers fed by 2S li-ions driving 2S emitters, it should be noticeable.
Ahhh - I knew bout that deal before I forgot bout it (huh?), well, that's me. But thanks!!! They are not shown in stock, due Nov 16th, but still worth while getting an order in for another 4 @$19.62 shipped and don't have to use any points! Excellent deal for sure... Thanks Again!!
teacher, thanks for sharing that Bing link, just noticed it actually works pretty well in my unnormal computing device (rooted Android, custom desktop browser user agent, tweaked dpi setting, etc). Comparatively, using Google image search results in the freakin' thing relocating the shown images dynamically as the stuff loads and it does so in a pestering and nauseating way with image showing pop-ups re-adjusting my browser's zoom and page scroll level, ffs. Here, look at this photo of myself yesterday after using it:
Cheers ^:)
Original post date: Wed, 11/23/2016 - 17:25. Grammar fix.
Yeah, from the “selfie”, it looks like using Google was a frustrating experience for you……
At least you have a chocolate chip cookie to ease the pain………
Fellows, I have good reasons to believe this cell can do a really nice 20A discharge curve and that, with a 2.8V cut-off, nearly 4.9Ah of capacity should be attained (maybe slightly more if the heating up of its internals results in a somewhat decrease on its internal resistance? Oops! Power output is what such a thing would drive up).
The good thing about Li26650 is that it combines great capacity and one of the lowest resistance values( maybe the best?) - thats is quite important to us especialy since we are using mostly fed dd drivers, speaking of this capacity comes second
As a digital smoker( already a year) i cant see its implement-its quite heavy and devices that uses it are heavy and not pocketable , maybe for home vaping yes but its quite another story
Mitko, with (personally estimated and in concordance with the CPF test) maybe slightly above 22mΩ of internal resistance, the Liito isn't the best in this regard.
However, capacity matters also. A lower IR helps with power delivery, but if the available capacity is a lesser one, the steeper discharge curve slope means the lower IR and lower capacity cell will end up delivering lesser power at some point and beyond.
This means that, even if certain quality 18650s like the VTC5 have slightly lower IR than a LiitoKala 26650-50A(B), soon they're stomped by the massive capacity and cooling performance advantage of these bigger cells.
Can anyone find cycle life specs for these cells… I agree that these cells are cheap, but I am thinking about using them in e-bike (14s2p) and to do this I have to do a lot of soldering, which would be too much work if they only lasted like 150 cycles (to 80%). Most of the time I will charge them to 4,1V (with 1,4A per cell) and discharge to 3,2V… I now use lipo Multistar 10Ah cells, which have low IR - no voltage sag (at a little over 1C discharge ) and are light, but cycle life is not that great and I notice they dont like cold (below 0 celsius). Would these Liitokala 26650 be any better in cold weather? I would only drain max 7A per cell (on average below 5A). Or is it better to buy well known NCR18650B and use them in 14s3p config (so around 4A current per cell)?
